Просит ввести неведомый мне пароль
elenass
30 окт 2019, 21:16
Здравствуйте. ОС Tina 19.2 i386, cinnamon.
Host: SAMSUNG-R510-Elena Kernel: 4.15.0-54-generic i686 bits: 32
compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.4
Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Type: Laptop System: SAMSUNG product: R510/P510 v: N/A serial: <filter>
Mobo: SAMSUNG model: R510/P510 serial: <filter> BIOS: Phoenix
v: 06LI.MP00.20080919.SCY date: 09/19/2008
ID-1: BAT1 charge: 15.3 Wh condition: 16.6/44.4 Wh (37%)
model: SAMSUNG Electronics status: Charging
Topology: Dual Core model: Intel Core2 Duo T5850 bits: 64 type: MCP
arch: Core Merom rev: D L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 8644
Speed: 998 MHz min/max: 1000/2166 MHz Core speeds (MHz): 1: 997 2: 998
Device-1: NVIDIA G98M [GeForce 9200M GS] vendor: Samsung Co driver: nvidia
v: 340.107 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1280x800~60Hz
OpenGL: renderer: GeForce 9200M GS/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107
Device-1: Intel 82801I HD Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Device-1: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter
vendor: Askey driver: ath5k v: kernel port: 2000 bus ID: 02:00.0
Device-2: Marvell 88E8055 PCI-E Gigabit Ethernet vendor: Samsung Co
driver: sky2 v: 1.30 port: 5000 bus ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 193.53 GiB used: 47.76 GiB (24.7%)
ID-1: /dev/sda vendor: Fujitsu model: MHZ2200BH G2 size: 186.31 GiB
temp: 53 C
ID-2: /dev/sdb type: USB model: USB DISK 2.0 size: 7.21 GiB
ID-1: / size: 182.38 GiB used: 45.90 GiB (25.2%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 72.0 C mobo: 72.0 C gpu: nvidia temp: 79 C
Processes: 206 Uptime: 34m Memory: 1.96 GiB used: 1.28 GiB (65.3%)
inxi: 3.0.32
При включении я ввожу пароль. Затем когда я открываю любую программу меня останавливают:
Пароль неверный введи его...
Я ввожу правильный пароль. И тут система кричит: НЕПРАВИЛЬНО! да как к чёрту неправильно если я 3 раза менял этот пароль на тот который ввел!
подскажите пожалуйста как от этого ада избавиться я закрываю отменой но так дальше не пойдёт.
30 окт 2019, 21:45
elenass писал(а):
30 окт 2019, 21:16
Тут надо разбираться сначала с данным поведением. Пароль система должна просить только при административных действиях требующих привилегий root, а не при запуске любой программы. Если просит при запуске именно любой программы - что-то серьезно не так, и уже как бы пофигу правильный пароль там или нет. К сожалению по вашему описанию картину происходящего составить не получается. Журнал системы покажите, для начала, после того как у вас это происходит. Получить его можно командой journalctl -b > system.log. Полученный файл system.log прикрепите к сообщению или если получится слишком большой - выложите где-нить на обменник, чтоб можно было скачать. Команду давать обязательно после того как случай левого запроса произошел.
P.S. паролей или другой подобной информации лог не содержит, только данные об успешности авторизации, и что именно ее запросило.
warning
Решено: 7
Благодарил (а): 161 раз
30 окт 2019, 22:41
я думаю, ТС говорит про keyring, который выпытывает пароль. Хотя это всего-лишь догадка
hw-probe: тыц!
31 окт 2019, 10:14
WARNING, эм...не должно быть если вход в систему не настроен автоматический, т.е. ТС в систему входит, вводя сам лично пароль. А судя по словам ТС
elenass писал(а):
30 окт 2019, 21:16
Так оно и есть.
elenass
15 ноя 2019, 16:24
WARNING писал(а):
30 окт 2019, 22:41
да вы правы. Это какая-то связка ключей
elenass
15 ноя 2019, 16:35
31 окт 2019, 10:14
elenass писал(а):
30 окт 2019, 21:16
Так оно и есть.
Уважаемый(ая) Тёмный Феникс! В настройках стоит авто-вход. Но я ввожу пароль всё равно :(
15 ноя 2019, 17:02
elenass писал(а):
15 ноя 2019, 16:35
Наверняка при входе в браузер или ещё какую прогрммулину. Вам поможет морская лошадь.
elenass
15 ноя 2019, 17:04
etamax писал(а):
15 ноя 2019, 17:02
elenass писал(а):
15 ноя 2019, 16:35
Что такое морская лошадь?
15 ноя 2019, 17:08
apt install seahorse
15 ноя 2019, 23:11
А лучше отключите автовход и входите по-нормальному и не будут вам докучать паролями :vic:
19 ноя 2019, 09:09
Галочку "шифровать домашнюю папку" при установке не ставили?
