Вопрос о правах и группах
saft
31 авг 2019, 20:25
Доброго времени суток уважаемые знатоки.
ОС: LinuxMint 19.2 (Tina) x64.
System: Host: papa-linux Kernel: 4.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.3
Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine: Type: Desktop System: Acer product: Veriton ES2710G v: N/A serial: <filter>
Mobo: Acer model: H11H4-AI(KBL) v: V:1.0 serial: <filter> UEFI: Acer v: R01-A4 date: 11/28/2017
CPU: Topology: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24000
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
Graphics: Device-1: Intel HD Graphics 630 vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2) v: 4.5 Mesa 19.0.8 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Acer Incorporated ALI Sunrise Point-H
Sound Server: ALSA v: k4.15.0-58-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: 2.3LK-NAPI port: e000 bus ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.20 TiB used: 249.27 GiB (20.3%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD3200KS-00PFB0 size: 298.09 GiB
Partition: ID-1: / size: 291.92 GiB used: 15.51 GiB (5.3%) fs: ext4 dev: /dev/sdb2
Sensors: System Temperatures: cpu: 41.5 C mobo: 29.8 C
Info: Processes: 192 Uptime: 7h 44m Memory: 7.25 GiB used: 2.16 GiB (29.8%) Init: systemd runlevel: 5 Compilers:
gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Вопрос вот в чем:
Есть программатор для прошивки микроконтроллеров. Работает он под управлением программы AVRDude. У этой программы есть файл avrdude.conf и находится он по пути /etc/avrdude.conf. Мне нужно поправить этот файл, чтобы заработал мой программатор. Как получить права на этот файл?
P.S. В эту директорию, этот файл закинул установщик Eclipse (AVRDude в него встроена).
31 авг 2019, 20:38
Из консоли: sudo xed /etc/avrdude.conf и можно править.
saft
31 авг 2019, 20:39
Вопрос вот в чем:
P.P.S Разумеется искал, читал и понял, что с практически нулевым опытом в Linux завалю систему.
Помогите пожалуйста.
abulaev2008
Благодарил (а): 24 раза
31 авг 2019, 21:49
Любой файловый менеджер и ПКМ, только не жми на файл или папку
" Открыть как root"
31 авг 2019, 21:53
abulaev2008 писал(а):
31 авг 2019, 21:49
Далеко не любой. Например в caja (mate) такого нету. В cinnamon, если память не изменяет, оно появляется только если установлен соответствующий пакет. Так что с консоли - универсальнее. Оно всегда работает, а xed - стандартный редактор для минта.
abulaev2008
31 авг 2019, 21:59
slant, это МИНТ, там вроде Немо, и это стандарт
31 авг 2019, 22:05
Немо - это в cinnamon. А в mate - caja. У каждого DE свой файловый менеджер, и набор функций в них разный.
abulaev2008
31 авг 2019, 22:32
slant, Ну---да. Как так, Linux и без TERMINAL :hi2:
Whowka
Благодарил (а): 777 раз
31 авг 2019, 22:44
31 авг 2019, 21:53
Искаропки :smile: , но, согласен. из консоли— универсальнее
saft, А если лениво набирать путь до файла, то sudo nemo(Ну или какой там у вас файловый менеджер) и уже там, мышой добираться до файла(только аккуратно, чтобы случайно не ткнуть куда-то и не удалить чего-то...)
Последний раз редактировалось пользователем 1 Whowka; всего редактировалось раз: 31
Whowka
31 авг 2019, 22:51
31 авг 2019, 22:32
Ну фсяко быват... Я, к примеру, так и не смог добиться этого пункта в меню, ни в Nautilus, ни в Thunar( Правда в Debian10 xfce),и решил: В консоли проще. :smile:
abulaev2008
31 авг 2019, 22:53
Whowka, :-D
Поставь МС и будет все....
Whowka
31 авг 2019, 23:07
31 авг 2019, 22:53
Ты имеешь ввиду Midnight Commander или Microsoft Corporation :smile:
abulaev2008
31 авг 2019, 23:25
Whowka писал(а):
31 авг 2019, 23:07
Midnight Commander
Вернуться в «Безопасность»
