X11Forwarding
X11Forwarding
16 авг 2019, 01:12
Всем привет!
Имеется 2 машины (обе ноуты одной фирмы).
Пусть будут сервер и клиент в данном кейсе.
Сервер
dja@dja-work:~$ фе
                                       dja@dja-work
 MMMMMMMMMMMMMMMMMMMMMMMMMmds+.        OS: Mint 19.2 tina
 MMm----::-://////////////oymNMd+`     Kernel: x86_64 Linux 4.15.0-58-generic
 MMd      /++                -sNMd:    Uptime: 1d 12h 3m
 MMNso/`  dMM    `.::-. .-::.` .hMN:   Packages: 2433
 ddddMMh  dMM   :hNMNMNhNMNMNh: `NMm   Shell: bash
     NMm  dMM  .NMN/-+MMM+-/NMN` dMM   Resolution: 3200x1080
     NMm  dMM  -MMm  `MMM   dMM. dMM   DE: GNOME
     NMm  dMM  -MMm  `MMM   dMM. dMM   WM: Metacity (Marco)
     NMm  dMM  .mmd  `mmm   yMM. dMM   GTK Theme: Mint-Y [GTK2/3]
     NMm  dMM`  ..`   ...   ydm. dMM   Icon Theme: Mint-Y
     hMM- +MMd/-------...-:sdds  dMM   Font: Monospace 10
     -NMm- :hNMNNNmdddddddddy/`  dMM   CPU: Intel Core i7-4710HQ @ 8x 3.5GHz [44.0°C]
      -dMNs-``-::::-------.``    dMM   GPU: GeForce GTX 860M
       `/dMNmy+/:-------------:/yMMM   RAM: 3458MiB / 11451MiB
          ./ydNMMMMMMMMMMMMMMMMMMMMM
             \.MMMMMMMMMMMMMMMMMMM
dja@dja-work:~$ inxi -Fxz
System:    Host: dja-work Kernel: 4.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
           Desktop: MATE 1.22.0 Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine:   Type: Laptop System: ASUSTeK product: N551JM v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: N551JM v: 1.0 serial: <filter> UEFI: American Megatrends v: N551JM.204
           date: 10/06/2014
Battery:   ID-1: BAT0 charge: 31.5 Wh condition: 33.2/56.2 Wh (59%) model: ASUSTeK N551-52 status: Charging
CPU:       Topology: Quad Core model: Intel Core i7-4710HQ bits: 64 type: MT MCP arch: Haswell rev: 3
           L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 39907
           Speed: 1014 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1610 2: 1878 3: 1940 4: 1961 5: 1724
           6: 1606 7: 1860 8: 1669
Graphics:  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA GM107M [GeForce GTX 860M] vendor: ASUSTeK driver: nvidia v: 390.116
           bus ID: 01:00.0
           Display: server: X.Org 1.19.6 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
           resolution: 1920x1080~60Hz, 1280x1024~60Hz
           OpenGL: renderer: N/A v: N/A direct render: N/A
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel
           bus ID: 00:03.0
           Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus ID: 00:1b.0
           Sound Server: ALSA v: k4.15.0-58-generic
Network:   Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: AzureWave driver: ath9k
           v: kernel port: e000 bus ID: 04:00.0
           IF: wlp4s0 state: up mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
           v: 2.3LK-NAPI port: d000 bus ID: 05:00.1
           IF: enp5s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-3: IMC Networks Atheros AR3012 Bluetooth type: USB driver: btusb bus ID: 3-5:4
Drives:    Local Storage: total: 465.76 GiB used: 274.05 GiB (58.8%)
           ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
Partition: ID-1: / size: 19.29 GiB used: 10.13 GiB (52.5%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 9.78 GiB used: 5.84 GiB (59.7%) fs: ext4 dev: /dev/sda4
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 1800
Info:      Processes: 288 Uptime: 1d 12h 05m Memory: 11.18 GiB used: 3.64 GiB (32.5%) Init: systemd
           runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
dja@dja-work:~$
Конфиг /etc/ssh/sshd_config
dja@dja-work:~$ cat /etc/ssh/sshd_config
#	$OpenBSD: sshd_config,v 1.101 2017/03/14 07:19:07 djm Exp $
# This is the sshd server system-wide configuration file.  See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented.  Uncommented options override the
# default value.
Port 2203
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_ecdsa_key
#HostKey /etc/ssh/ssh_host_ed25519_key
# Ciphers and keying
#RekeyLimit default none
# Logging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin prohibit-password
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
#PubkeyAuthentication yes
# Expect .ssh/authorized_keys2 to be disregarded by default in future.
#AuthorizedKeysFile	.ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none
#AuthorizedKeysCommandUser nobody
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes
#PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
#GSSAPIStrictAcceptorCheck yes
#GSSAPIKeyExchange no
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
X11DisplayOffset 10
X11UseLocalhost no
#PermitTTY yes
PrintMotd no
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS no
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
#VersionAddendum none
# no default banner path
#Banner none
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
# override default of no subsystems
Subsystem	sftp	/usr/lib/openssh/sftp-server
# Example of overriding settings on a per-user basis
#Match User anoncvs
#	X11Forwarding no
#	AllowTcpForwarding no
#	PermitTTY no
#	ForceCommand cvs server
Клиент
dja@dja-laptop:~$ фе
                                       dja@dja-laptop
 MMd      /++                -sNMd:    Uptime: 3h 35m
 MMNso/`  dMM    `.::-. .-::.` .hMN:   Packages: 2449
     NMm  dMM  -MMm  `MMM   dMM. dMM   DE: MATE 1.22.0
     NMm  dMM  .mmd  `mmm   yMM. dMM   GTK Theme: 'Mint-X-Teal' [GTK2/3]
     NMm  dMM`  ..`   ...   ydm. dMM   Icon Theme: gnome-noble
     hMM- +MMd/-------...-:sdds  dMM   Font: Ubuntu 12
     -NMm- :hNMNNNmdddddddddy/`  dMM   CPU: Intel Core i3-6006U @ 4x 2GHz [45.0°C]
      -dMNs-``-::::-------.``    dMM   GPU: GeForce 920MX
       `/dMNmy+/:-------------:/yMMM   RAM: 1943MiB / 7858MiB
dja@dja-laptop:~$ inxi -Fxz
System:    Host: dja-laptop Kernel: 4.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Machine:   Type: Laptop System: ASUSTeK product: X541UVK v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: X541UVK v: 1.0 serial: <filter> UEFI: American Megatrends v: X541UVK.308
           date: 01/30/2018
Battery:   ID-1: BAT0 charge: 29.9 Wh condition: 29.9/34.6 Wh (86%) model: ASUSTeK ASUS Battery
           status: Not charging
CPU:       Topology: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake rev: 3
           L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15936
           Speed: 500 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA GM108M [GeForce 920MX] vendor: ASUSTeK driver: nvidia v: 390.116 bus ID: 01:00.0
           Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
           OpenGL: renderer: GeForce 920MX/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: 2.3LK-NAPI
           port: d000 bus ID: 02:00.2
           IF: enp2s0f2 state: up speed: 100 Mbps duplex: full mac: <filter>
           Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: AzureWave driver: rtl8723be
           v: kernel port: c000 bus ID: 03:00.0
           IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
Drives:    Local Storage: total: 931.51 GiB used: 602.79 GiB (64.7%)
           ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
Partition: ID-1: / size: 47.81 GiB used: 9.07 GiB (19.0%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 191.57 GiB used: 34.22 GiB (17.9%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 8.79 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 43 C
Info:      Processes: 239 Uptime: 3h 35m Memory: 7.67 GiB used: 2.08 GiB (27.0%) Init: systemd runlevel: 5
dja@dja-laptop:~$
Конфиг /etc/ssh/ssh_config
dja@dja-laptop:~$ cat /etc/ssh/ssh_config
# This is the ssh client system-wide configuration file.  See
# ssh_config(5) for more information.  This file provides defaults for
# users, and the values can be changed in per-user configuration files
# or on the command line.
# Configuration data is parsed as follows:
#  1. command line options
#  2. user-specific file
#  3. system-wide file
# Any configuration value is only changed the first time it is set.
# Thus, host-specific definitions should be at the beginning of the
# configuration file, and defaults at the end.
# Site-wide defaults for some commonly used options.  For a comprehensive
# list of available options, their meanings and defaults, please see the
# ssh_config(5) man page.
Host *
#   ForwardAgent no
ForwardAgent yes
#   ForwardX11 no
ForwardX11 yes
#   ForwardX11Trusted yes
#   PasswordAuthentication yes
#   HostbasedAuthentication no
#   GSSAPIAuthentication no
#   GSSAPIDelegateCredentials no
#   GSSAPIKeyExchange no
#   GSSAPITrustDNS no
#   BatchMode no
#   CheckHostIP yes
#   AddressFamily any
#   ConnectTimeout 0
#   StrictHostKeyChecking ask
#   IdentityFile ~/.ssh/id_rsa
#   IdentityFile ~/.ssh/id_dsa
#   IdentityFile ~/.ssh/id_ecdsa
#   IdentityFile ~/.ssh/id_ed25519
#   Port 22
#   Protocol 2
#   Ciphers aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc
#   MACs hmac-md5,hmac-sha1,umac-64@openssh.com
#   EscapeChar ~
#   Tunnel no
#   TunnelDevice any:any
#   PermitLocalCommand no
#   VisualHostKey no
#   ProxyCommand ssh -q -W %h:%p gateway.example.com
#   RekeyLimit 1G 1h
    SendEnv LANG LC_*
    HashKnownHosts yes
    GSSAPIAuthentication yes
Строка проброса
ssh -XC dja@XXX.XXX.XXX.XXX -p 2203 xed
приводит к запуску xed на удаленной машине без проброса. Т.е. окно остается там.
Сам же ssh -vvv содержит кучу игноров (но при этом команды выполняет)
debug3: Ignored env LS_COLORS
debug3: Ignored env LESSCLOSE
debug1: Sending env LANG = ru_RU.UTF-8
debug2: channel 0: request env confirm 0
debug3: send packet: type 98
debug3: Ignored env GDM_LANG
debug3: Ignored env DISPLAY
debug3: Ignored env COMPIZ_CONFIG_PROFILE
debug3: Ignored env GTK_OVERLAY_SCROLLING
debug3: Ignored env COLORTERM
debug3: Ignored env XDG_VTNR
debug3: Ignored env SSH_AUTH_SOCK
debug3: Ignored env MANDATORY_PATH
debug3: Ignored env XDG_SESSION_ID
debug3: Ignored env XDG_GREETER_DATA_DIR
debug3: Ignored env USER
debug3: Ignored env DESKTOP_SESSION
debug3: Ignored env DEFAULTS_PATH
debug3: Ignored env QT_QPA_PLATFORMTHEME
debug3: Ignored env PWD
debug3: Ignored env HOME
debug3: Ignored env SSH_AGENT_PID
debug3: Ignored env QT_ACCESSIBILITY
debug3: Ignored env XDG_SESSION_TYPE
debug3: Ignored env XDG_DATA_DIRS
debug3: Ignored env MATE_DESKTOP_SESSION_ID
debug3: Ignored env XDG_SESSION_DESKTOP
debug3: Ignored env QT_SCALE_FACTOR
debug3: Ignored env GTK_MODULES
debug3: Ignored env CLUTTER_BACKEND
debug3: Ignored env TERM
debug3: Ignored env SHELL
debug3: Ignored env VTE_VERSION
debug3: Ignored env XDG_SEAT_PATH
debug3: Ignored env XDG_CURRENT_DESKTOP
debug3: Ignored env GPG_AGENT_INFO
debug3: Ignored env SHLVL
debug3: Ignored env LANGUAGE
debug3: Ignored env WINDOWID
debug3: Ignored env GDMSESSION
debug3: Ignored env LOGNAME
debug3: Ignored env DBUS_SESSION_BUS_ADDRESS
debug3: Ignored env XDG_RUNTIME_DIR
debug3: Ignored env XAUTHORITY
debug3: Ignored env XDG_SESSION_PATH
debug3: Ignored env QT_AUTO_SCREEN_SCALE_FACTOR
debug3: Ignored env XDG_CONFIG_DIRS
debug3: Ignored env PATH
debug3: Ignored env SESSION_MANAGER
debug3: Ignored env LESSOPEN
debug3: Ignored env _
Помнится в 18.3 всё сводилось к такому варианту. Но вот в 19.2 что-то никак... Опять сломали? В гугле был. Опции менял. Воз не двигается с места. Под какое колесо доски подложить? Подкоп куда делать? Буду рад рекомендациям! Если еще инфа нужна какая - спрашивайте.
vnc через ssh работает нормально. (remmina).
Решение vir0id » 16 авг 2019, 21:08
Dja,
Ну а плюсом ко всему параметр -XYC не то что нужно? Я так понимаю, тебе нужно лишь пробросить то самое окно в клиент?
Dja писал(а):
16 авг 2019, 01:12
X11Forwarding
16 авг 2019, 04:29
Dja писал(а):
16 авг 2019, 01:12
Попробуй сперва команду дать. На сервере
export DISPLAY=:0.0
или так
export DISPLAY=:0
Не знаю на сколько это одно и тоже.
X11Forwarding
16 авг 2019, 09:51
vir0id, с дисплеями всё ок. И на клиенте и на сервере по echo №DISPLAY
$ echo $DISPLAY
:0.0
Если бы всё было так просто. Проблема тут в другом. Опытным путем (не без помощи "большого брата") выяснили, что
dbus-launch команда
запускает проброс именно в том виде, в каком надо (в том плане, что окно прорисовывается на клиенте), однако и тут имеется проблема...
Закрываем приложение, а оно не совсем закрывается... вобщем приходится dbus киллить по ctrl+c и только потом можно корректно завершить ssh-сессию (и то... меня одолевают сомнения).
Вобщем ссылки на данный баг уходят корнями к 2009 году
:poet:
Сотни лет все беды возвращаются
Hа круги своя
X11Forwarding
16 авг 2019, 21:08
Dja,
Dja писал(а):
16 авг 2019, 01:12
X11Forwarding
17 авг 2019, 01:11
vir0id, потрясающе! Спасибо! :thumbs: Странно, что раньше не требовалось Y.
X11Forwarding
17 авг 2019, 07:13
Dja, Я рад что помог. :thumbs:
X11Forwarding
23 авг 2019, 19:12
Таки возвращаюсь к своим "баранам" :-D
Оказалось не всё так просто.
xed mate-terminal gimp virtualbox пробрасываются нормально.
caja не хочет :blink2:
X11Forwarding
23 авг 2019, 20:18
Dja писал(а):
23 авг 2019, 19:12
caja не хочет
А выхлоп какой?
X11Forwarding
23 авг 2019, 20:24
я бы сказал такой же как при пробросе. Только разница в том, что происходит закрытие тут же... но окно висит там.
Вот это xed
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: exec
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: Requesting X11 forwarding with authentication spoofing.
debug1: Requesting authentication agent forwarding.
debug1: Sending environment.
debug1: Sending command: xed
debug1: client_input_channel_open: ctype x11 rchan 4 win 65536 max 16384
debug1: client_request_x11: request from 127.0.0.1 40598
debug1: channel 1: new [x11]
debug1: confirm x11
debug1: client_input_channel_open: ctype x11 rchan 5 win 65536 max 16384
debug1: client_request_x11: request from 127.0.0.1 40600
debug1: channel 2: new [x11]
debug1: confirm x11
debug1: channel 2: FORCE input drain
debug1: channel 2: free: x11, nchannels 3
debug1: channel 1: FORCE input drain
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: client_input_channel_req: channel 0 rtype eow@openssh.com reply 0
debug1: channel 0: free: client-session, nchannels 2
debug1: channel 1: free: x11, nchannels 1
Transferred: sent 31216, received 114136 bytes, in 9.4 seconds
Bytes per second: sent 3329.9, received 12175.4
debug1: Exit status 0
debug1: compress outgoing: raw data 104116, compressed 21806, factor 0.21
debug1: compress incoming: raw data 1012400, compressed 108322, factor 0.11
А это caja
debug1: Sending command: caja
debug1: client_request_x11: request from 127.0.0.1 40604
debug1: confirm x11
debug1: client_request_x11: request from 127.0.0.1 40606
debug1: confirm x11
Transferred: sent 11700, received 5284 bytes, in 1.2 seconds
Bytes per second: sent 9973.2, received 4504.1
debug1: compress outgoing: raw data 45902, compressed 8774, factor 0.19
debug1: compress incoming: raw data 5149, compressed 2488, factor 0.48
Синие строки - на момент когда окно прорисовалось перед тем как я его закрыл.
X11Forwarding
23 авг 2019, 20:30
Dja, ну по идеи всё должно работать. Выхлоп впорядке. Конкретнее про каджу я не подскажу, не сталкивался.
X11Forwarding
23 авг 2019, 20:35
Главное
dbus-launch caja
работает. Странно это.
Ну да ладно. Не столь и нужно. Если уж приспичит запущу этой командой.
Вернуться в «Работа с сетью»
