Невозможно отобразить содержимое папки
abulaev2008
Благодарил (а): 24 раза
06 июл 2019, 08:55
Host: Lenovo Kernel: 5.1.16-050116-generic x86_64 bits: 64 compiler: gcc
v: 8.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 80XR v: Lenovo ideapad 320-15IAP
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter>
UEFI [Legacy]: LENOVO v: 5RCN36WW date: 08/06/2018
ID-1: BAT0 charge: 23.5 Wh condition: 23.5/30.0 Wh (78%)
model: SMP L16M2PB1 status: Charging
Topology: Quad Core model: Intel Pentium N4200 bits: 64 type: MCP
arch: Goldmont rev: 9 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8755
Speed: 1156 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 993 2: 995
3: 985 4: 991
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Integrated
Graphics
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 505 (Broxton)
v: 4.5 Mesa 19.0.2 direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:0e.0
Sound Server: ALSA v: k5.1.16-050116-generic
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 1000 bus ID: 02:00.0
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: 1000 bus ID: 03:00.0
Local Storage: total: 577.55 GiB used: 301.90 GiB (52.3%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-24VHAT0
ID-2: /dev/sdb vendor: Kingston model: SA400S37120G size: 111.79 GiB
temp: 25 C
ID-1: / size: 9.55 GiB used: 7.67 GiB (80.3%) fs: ext4 dev: /dev/sdb1
ID-2: /home size: 95.60 GiB used: 362.8 MiB (0.4%) fs: ext4 dev: /dev/sdb3
ID-3: swap-1 size: 4.39 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb2
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 206 Uptime: 29m Memory: 3.68 GiB used: 1012.2 MiB (26.9%)
inxi: 3.0.27
Есть два диска HDD(Win) и SSD(Mint), не получается открыть папку Загрузки на HDD из Минта, а из Вин не удается удалить этот файл.
Badbloks и Чекдиск долго, (пишет 27 часов на проверку). Есть что-то быстрее?
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
06 июл 2019, 09:48
А какой результат выдает быстрая проверка из-под винды?
abulaev2008
06 июл 2019, 11:44
"Устранение проблемы" и уже 2 часа.
Началось с того:
в винде увидел, что Касперский не запущен. запускаю сам, ругается на фраймнетворк 4. Скачиваю, устанавливаю... Уже установлен был (а кто бы сомневался. не догадался глянуть в программы). Переустановка Касперского тоже не помогла. Да и давно уже Винда крутиться. пора и переустановить..
Думаю форматну винт и захотел из загрузок для любимой оставить Игру пристолов (скопировать из HDD на SSD), а Минт не пускает в папку.. Ну и на ...
Ара Магеддон
Решено: 18
06 июл 2019, 15:47
abulaev2008 писал(а):
06 июл 2019, 11:44
Ну тоже вариант :) А SMART что говорит?
abulaev2008
06 июл 2019, 18:17
Ара Магеддон, Ошибка, Типа доступа к диску, Гпарт тоже ругался, пока не удалил все разделы.
06 июл 2019, 21:41
abulaev2008, с виндового live-cd запуститься и попробовать там
abulaev2008
16 авг 2019, 21:15
Переустановил все
