HD Mobility 5145 AMD/ATI
Alentev Denis
07 июн 2019, 13:53
Здравствуйте. Имеется ноут Samsung R425 JS02 с ATI Mobility Radeon HD 5145.
inxi -F:
denis@R425Note:~$ inxi -Fxz
Host: R425Note Kernel: 4.15.0-51-generic x86_64 bits: 64 compiler: gcc
v: 7.3.0 Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: SAMSUNG product: R425/R525 v: N/A serial: <filter>
Mobo: SAMSUNG model: R425/R525 serial: <filter> BIOS: Phoenix v: 05NS
date: 07/03/2010
ID-1: BATT charge: 72.1 Wh condition: 72.1/73.3 Wh (98%)
model: SAMSUNG Electronics status: Full
Topology: Dual Core model: AMD Turion II Mobile M500 bits: 64 type: MCP
arch: K10 rev: 2 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 8778
Speed: 1100 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 1100 2: 800
Device-1: AMD RV710/M92 [Mobility Radeon HD 4530/4570/545v]
vendor: Samsung Co driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD RV710 (DRM 2.50.0 / 4.15.0-51-generic LLVM 7.0.0)
v: 3.3 Mesa 18.2.8 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Samsung Co driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
vendor: Samsung Co driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.15.0-51-generic
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Askey
driver: ath9k v: kernel port: 9000 bus ID: 02:00.0
Device-2: Marvell 88E8040 PCI-E Fast Ethernet vendor: Samsung Co
driver: sky2 v: 1.30 port: a000 bus ID: 04:00.0
Local Storage: total: 111.79 GiB used: 44.15 GiB (39.5%)
ID-1: /dev/sda model: SATA SSD size: 111.79 GiB
ID-1: / size: 109.53 GiB used: 44.15 GiB (40.3%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 63.4 C mobo: N/A
Processes: 160 Uptime: 7m Memory: 2.93 GiB used: 764.9 MiB (25.5%)
inxi: 3.0.27
По умолчанию в системе установлен свободный драйвер AMD, производительность меня совершенно не устраивает и нужно поставить проприетарный драйвер. Последняя версия проприетарного драйвера с оф. ресурса AMD - fglrx_15.201-0ubuntu1_amd64_UB_14.01, и в списке поддерживаемых устройств есть ATI Mobility Radeon™ HD 5000 Series.
При попытке установить пакет deb, появляется ошибка:
denis@R425Note:~/Загрузки$ sudo dpkg -i fglrx_15.201-0ubuntu1_amd64_UB_14.01.deb[sudo] пароль для denis:
Выбор ранее не выбранного пакета fglrx.
(Чтение базы данных … на данный момент установлено 326816 файлов и каталогов.)
Подготовка к распаковке fglrx_15.201-0ubuntu1_amd64_UB_14.01.deb …
Распаковывается fglrx (2:15.201-0ubuntu1) …
dpkg: зависимости пакетов не позволяют настроить пакет fglrx:
fglrx зависит от fglrx-core, однако:
Пакет fglrx-core не установлен.
fglrx зависит от libqtcore4 (>= 4:4.7.0~beta2), однако:
Пакет libqtcore4 не установлен.
dpkg: ошибка при обработке пакета fglrx (--install):
проблемы зависимостей — оставляем не настроенным
Обрабатываются триггеры для ureadahead (0.100.0-21) …
ureadahead will be reprofiled on next reboot
Обрабатываются триггеры для systemd (237-3ubuntu10.21) …
Обрабатываются триггеры для desktop-file-utils (0.23+linuxmint5) …
Обрабатываются триггеры для mime-support (3.60ubuntu1) …
fglrx
Я добавил репозитории: deb http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic main
deb-src http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic main
скомандовал apt-get update
apt-get upgrade
открыл менеджер драйверов в надежде увидеть хоть один драйвер, но окно как было пустым, так пустым и осталось...
Очень вас прошу, знающие люди, помогите пожалуйста установить проприетарник для AMD.
Решение slant » 07 июн 2019, 14:08
Alentev Denis писал(а):
07 июн 2019, 13:53
fglrx - заброшен. Последняя версия минта на которую его можно взгромоздить с помощью бубна - 18-ая, с даунгрейдом ядра и xorg (здесь на форуме было руководство от chokobo). На 19-ую - нереально.
07 июн 2019, 14:08
07 июн 2019, 13:53
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
07 июн 2019, 14:27
07 июн 2019, 13:53
Там только проприетарщина для nvidia. Для amd есть пара PPA со свежими свободными дровами, может они чуть побыстрее будут:
https://launchpad.net/~paulo-miguel-dia ... ter=bionic
https://launchpad.net/~oibaf/+archive/u ... ter=bionic
А amdgpu-pro эту карточку не поддерживает, я так понял.
07 июн 2019, 14:53
Ара Магеддон писал(а):
07 июн 2019, 14:27
Эта карточка и свободный amdgpu не поддерживает
Вернуться в «Видеокарты»
