Как устроить включение LinuxMint 19.1
Whowka
Благодарил (а): 777 раз
#41
14 май 2019, 18:10
Obamacyborg1975 писал(а):
14 май 2019, 16:29
Вот мой выхлоп:
Дык то ж по дебиану, а не по минту.
Вот мой выхлоп в минте:
Startup finished in 8.203s (kernel) + 23.698s (userspace) = 31.902s
А вот железо:
Host: Whowka Kernel: 4.15.0-48-generic x86_64 bits: 64 compiler: gcc
v: 7.3.0 Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Desktop Mobo: Gigabyte model: G41M-ES2L v: x.x serial: <filter>
BIOS: Award v: F6 date: 11/04/2009
Topology: Quad Core model: Intel Core2 Quad Q9400 bits: 64 type: MCP
arch: Penryn rev: A L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 21331
Speed: 2000 MHz min/max: 2000/2667 MHz Core speeds (MHz): 1: 2000 2: 2000
3: 2000 4: 2000
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 390.116 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1280x1024~60Hz
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116
vendor: Gigabyte GA-D525TUD driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte
Sound Server: ALSA v: k4.15.0-48-generic
vendor: Gigabyte driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 03:00.0
Device-2: Ralink RT3060 Wireless 802.11n 1T/1R
vendor: D-Link System DWA-525 driver: rt2800pci v: 2.3.0 port: d000
bus ID: 04:01.0
IF: wlp4s1 state: down mac: <filter>
Local Storage: total: 773.18 GiB used: 28.18 GiB (3.6%)
ID-1: /dev/sda vendor: Western Digital model: WD5002ABYS-01B1B0
ID-2: /dev/sdb vendor: Seagate model: ST380815AS size: 74.53 GiB
ID-3: /dev/sdc vendor: Seagate model: ST3250312AS size: 232.89 GiB
ID-1: / size: 27.37 GiB used: 11.79 GiB (43.1%) fs: ext4 dev: /dev/sdc2
ID-2: /home size: 52.00 GiB used: 16.39 GiB (31.5%) fs: ext4
dev: /dev/sdc3
ID-3: swap-1 size: 2.79 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc1
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): cpu: 1603 fan-2: 0 gpu: nvidia fan: 33%
Voltages: 12v: N/A 5v: 3.02 3.3v: N/A vbat: 3.18
Processes: 178 Uptime: 4m Memory: 3.85 GiB used: 1.07 GiB (27.7%)
Достаточно далеко от 80-ти секунд, даже на моём старье.(Дебиан грузится лишь на 10 сек быстрее) :smile:
Благодарил (а): 128 раз
#42
14 май 2019, 19:32
Whowka писал(а):
14 май 2019, 18:10
Ну так ж логично. Я им и пользуюсь. У вас ssd?
Whowka
#43
14 май 2019, 20:44
Мииинуточку, хде ж "логично"?
13 май 2019, 20:54
Я раньше тоже минтом пользовался...меньше 80 сек. времени загрузки, добиться не смог.
и
14 май 2019, 16:29
Debian GNU/Linux 9.9 (stretch)
14 май 2019, 19:32
У вас ssd?
Неее... ssd, по нонешним ценам (и временам), это гусарство, или производственная необходимость :smile:
hdd, sata II
FreeStyler
Решено: 7
Благодарил (а): 772 раза
#44
15 май 2019, 10:48
Whowka писал(а):
14 май 2019, 20:44
:blink2: все наоборот говорят что ссд совсем в цене упали - теперь почти любой может себе позволить, а уж б/у тем более.
ИМХО гусарством это было в начале 10ых. Собственно так же как и все остальные комплектующие в начале зарождения и выпуска первых сериек - ЖК мониторы, например, и качеством по сравнению с текущими были не очень и стоили как космолёт.
ССД скоро таки станут больше по продажам чем хдд. https://3dnews.ru/986948?from=related-g ... rce=986391
https://3dnews.ru/986391
https://3dnews.ru/987153
+ большие объёмы появились https://3dnews.ru/986622 не для смертных, но всё же. Всё равно со временем и они начнут дешеветь...
deadmau5 - Harmonic Mix
#45
15 май 2019, 10:52
Whowka писал(а):
14 май 2019, 20:44
Да ладно...сейчас цены очень даже ничего
Griga211
Благодарил (а): 9 раз
#46
15 май 2019, 13:11
asa писал(а):
14 май 2019, 11:25
Так вы говорите о каких цыфрах
Я говорю о kernel+user space, вот об этом
asa писал(а):
14 май 2019, 11:25
5.945 s
Griga211
#47
15 май 2019, 14:21
Whowka писал(а):
14 май 2019, 20:44
цены на ссд уже как на флешки. Вполне себе можно прикупить. Я брал за 6500 на 240. Вот это ещё можно отнести к гусарству, а текущие цены вполне себе отличные
Whowka писал(а):
14 май 2019, 18:10
А вот железо
Я ставил ссд на похожее железо, только чуть слабее. И я скажу даже с сата 2 разница по сравнению с обычным ххд на лицо. Я ставил в качестве теста. Тот кто пользуется доволен как слон, я ему оставил и ту ос на хдд, но он в неё больше не загружался, сказал что это какой то ад и не понимает как он раньше в ней работал.
Griga211
#48
15 май 2019, 15:26
asa писал(а):
14 май 2019, 11:25
допустим есть такой выхлоп:
asa@lmc:~$ systemd-analyze
Запуск завершен в 3.234 s (ядро) + 2.710 s (пространство пользователей) = 5.945 s
графический.цель была достигнута после 2.707 в пользовательском пространстве
Для примера как раз можно использовать). Допустим у меня вот такой:
systemd-analyze
Startup finished in 2.056s (kernel) + 1.991s (userspace) = 4.048s
graphical.target reached after 1.990s in userspace
Вот это уже пример писькомерства.
А вот если как у автора
wwe2012 писал(а):
12 май 2019, 06:49
systemd-analyze
Startup finished in 7.238s (kernel) + 1min 41.177s (userspace) = 1min 48.415s
graphical.target reached after 43.505s in userspace
То это уже решение возможных проблем)
asa
Благодарил (а): 126 раз
#49
15 май 2019, 16:10
Griga211 писал(а):
15 май 2019, 15:26
:thumbs:
Но тогда получается у меня длинее :joke:
Griga211
#50
15 май 2019, 16:18
asa писал(а):
15 май 2019, 16:10
Именно это я 3 раза написал и 3 раза стер))))) :-D :-D :-D
#51
15 май 2019, 16:33
Whowka писал(а):
14 май 2019, 20:44
хде ж "логично"?
раньше было раньше. Я минт снес. Теперь пользуюсь Debian и жду Buster.
Whowka писал(а):
14 май 2019, 20:44
hdd
Как и у меня.
Whowka
#52
15 май 2019, 22:42
FreeStyler, darkfenix, Griga211, Охтыж накинулись!! :blink2: Виноват, был не прав, шутканул, готов искупить. ( но сущность моя, хохляцкая, кипит от возмущения: платить 2 тышши, за 240 гигов, которые можно взять за 200руб, с целью сэкономить 35 секунд на загрузке и по полсекунды на открытии страниц в браузере... :dash2:) :smile:
Griga211
#53
15 май 2019, 23:12
Whowka писал(а):
15 май 2019, 22:42
это как и где?
Whowka писал(а):
15 май 2019, 22:42
А 10 сек на открытии самого браузера? :-D. Тебе надо просто попробовать) Возьми у кого-нибудь на время) Это как с наркотиками, пока не попробовал зависимости нет, а потом как пойдет) :joke:
Whowka
#54
15 май 2019, 23:30
Griga211 писал(а):
15 май 2019, 23:12
это как и где?
Тю, Б/Ушный, в отличчном состоянии, с небольшим пробегом, один хозяин...ну как у меня стоит. Повёлся человек на 2Тб, а этот девать было некуда :smile:
Griga211 писал(а):
15 май 2019, 23:12
Вооот... А зависимость, это фсегда плохо. Только производственная необходимость(с последующей прибылью) может служить оправданием подобных, безумных трат :-D
Griga211
#55
16 май 2019, 06:44
Whowka писал(а):
15 май 2019, 23:30
ну хз, я бы хдд с рук у не знакомого человека не взял бы, остальное бы легко, а на хдд у меня какой то психологический блок. Перед покупкой надо смотреть наработку по часам как минимум. А у знакомого бесплатно да, но не за деньги)
wwe2012
#56
16 май 2019, 08:25
Теперь долго выключаеться ПК
Griga211
#57
16 май 2019, 08:46
wwe2012 писал(а):
16 май 2019, 08:25
:-D
Отключи сохранение сессии.
Whowka
#58
16 май 2019, 09:59
Griga211 писал(а):
16 май 2019, 06:44
Ну видно,что чел. по вечерам, после работы в тырнете сидел, да фильмы смотрел, + S.M.A.R.T сразу глянул, ну а дома "Викторией" пощупал. Я же написал: "один хозяин, маленький пробег"
Griga211 писал(а):
16 май 2019, 06:44
Зависимость, блок... Надо как-то расслабиться... Может "Папин йогурт" :smile: ?
Griga211
#59
16 май 2019, 16:00
Whowka писал(а):
16 май 2019, 09:59
Может "Папин йогурт" ?
хватит мне в этой жизни таких йогутов) У меня ощущение что я на 2 жизни алкоголя употребил. Уже больше 5 лет ничего крепче кваса не пил.
