Установка драйвера AMD
wayLANder
Благодарил (а): 6 раз
07 май 2019, 00:05
Система:
  Host: senya-All-Series Kernel: 4.15.0-47-generic x86_64 bits: 64
  compiler: gcc v: 7.3.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
  Mobo: ASUSTeK model: H81M-K v: Rev X.0x serial: <filter>
  UEFI: American Megatrends v: 1104 date: 02/22/2016
  Topology: Dual Core model: Intel Core i3-4330 bits: 64 type: MT MCP
  arch: Haswell rev: 3 L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28000
  Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 921 2: 920
  3: 945 4: 941
  Device-1: AMD Curacao PRO [Radeon R7 370 / R9 270/370 OEM] vendor: ASUSTeK
  driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1024x768~60Hz
  OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 / 4.15.0-47-generic LLVM 6.0.0)
  v: 4.5 Mesa 18.0.5 direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
  Device-2: AMD Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k4.15.0-47-generic
  vendor: ASUSTeK driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 03:00.0
  IF-ID-1: enp0s20u2c4i2 state: up speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 1.32 TiB used: 11.91 GiB (0.9%)
  ID-1: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
  temp: 35 C
  ID-2: /dev/sdb vendor: Western Digital model: WDS120G2G0A-00JH30
  size: 111.80 GiB temp: 38 C
  ID-3: /dev/sdc vendor: Western Digital model: WD3200BPVT-35ZEST0
  size: 298.09 GiB temp: 33 C
  ID-4: /dev/sdd type: USB vendor: SanDisk model: Cruzer Blade
  ID-1: / size: 292.41 GiB used: 9.57 GiB (3.3%) fs: ext4 dev: /dev/sdc1
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 35 C
  Fan Speeds (RPM): cpu: 0
  Processes: 219 Uptime: 22m Memory: 7.73 GiB used: 2.02 GiB (26.1%)
  inxi: 3.0.27
Видеокарта:
*-display
       description: VGA compatible controller
       product: Curacao PRO [Radeon R7 370 / R9 270/370 OEM]
       vendor: Advanced Micro Devices, Inc. [AMD/ATI]
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
       configuration: driver=radeon latency=0
       resources: irq:27 memory:e0000000-efffffff memory:f7e00000-f7e3ffff ioport:e000(size=256) memory:c0000-dffff
Менеджер драйверов в упор не видит драйверов. На винде всё работает нормально, видеокарта целая, рабочая.
Как установить драйвер для минта?
При попытке установки скачанного драйвера (fglrx-15.302), консоль пишет следующее:
root@senya-All-Series:/home/senya# '/home/senya/Загрузки/fglrx-15.302/amd-driver-installer-15.302-x86.x86_64.run'
Created directory fglrx-install.CYG87J
Verifying archive integrity... All good.
Uncompressing AMD Proprietary Driver-15.302.....................................................................................................................................................................................................................................................................................
AMD Proprietary Driver Installer/Packager
error: Detected X Server version 'XServer 1.19.6_64a' is not supported. Supported versions are X.Org 6.9 or later, up to XServer 1.10 (default:v2:x86_64:lib:XServer 1.19.6_64a:none:4.15.0-48-generic:)
Installation will not proceed.
Removing temporary directory: fglrx-install.CYG87J
07 май 2019, 01:22
fglrx на mint 19 установить не получится. Там ядро и Xorg слишком новые, а драйвер заброшен. Последний минт на котором этот драйвер можно завести - 18.х, но и то с некоторой возней.
На новом минте используется amdgpu для карт AMD, но он старые карты не понимает... В прочем, за подробностями про AMD - это уже не ко мне, у меня их нету. Но тут на форме была тема.
07 май 2019, 06:39
wayLANder, попробуй так
Открыть файл /etc/default/grub(нужны права администратора)
В конец строки GRUB_CMDLINE_LINUX_DEFAULT добавить modprobe.blacklist=radeon radeon.si_support=0 amdgpu.si_support=1
Должно получиться примерно так
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash modprobe.blacklist=radeon radeon.si_support=0 amdgpu.si_support=1"
Дальше
sudo update-grub
Перезагрузка.
Потом проверь подцепился ли драйвер Должен увидеть такое drivers: ati,amdgpu
wayLANder
09 май 2019, 05:20
07 май 2019, 06:39
wayLANder,
  Device-1: AMD Curacao PRO [Radeon R7 370 / R9 270/370 OEM] driver: amdgpu
  v: kernel
  Display: x11 server: X.Org 1.19.6 driver: amdgpu,ati
  OpenGL: renderer: AMD Radeon HD8800 Series (PITCAIRN DRM 3.23.0
  4.15.0-48-generic LLVM 7.0.0)
  v: 4.5 Mesa 18.2.8
Драйвер, видимо, встал, но разрешение по-прежнему 1024x768, хотя разрешение дисплея 1366x768 :sad:
wayLANder
09 май 2019, 05:30
Поставил сначала драйвер X Org, перезагрузился - не изменилось разрешение, поставил fglrx, перезагрузился - так же. В менеджере пишет что проприетарный драйвер используется.. Но в приложении Дисплей у меня так же максимальное разрешение 1024х768..
Griga211
Благодарил (а): 9 раз
09 май 2019, 06:44
wayLANder писал(а):
09 май 2019, 05:30
Покажи вывод Способов как решить данную проблему много, но я бы сначала сконфигурировал заново иксы. Если бы оно не появилось, то ручками добавил бы в Xorg.conf.
wayLANder
09 май 2019, 17:19
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DVI-I-0 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768      60.00*
   800x600       60.32    56.25
   848x480       60.00
   640x480       59.94
DVI-D-1 disconnected (normal left inverted right x axis y axis)
11 май 2019, 17:56
wayLANder писал(а):
09 май 2019, 05:30
Вот только ты его не выбрал
wayLANder
11 май 2019, 22:49
11 май 2019, 17:56
wayLANder писал(а):
09 май 2019, 05:30
Как понять не выбрал? Я выбирал оба драйвера, но после перезагрузки он опять мне их предлагает, и ничего не меняется.
wayLANder
24 авг 2019, 18:09
Всё еще нужна помощь :sad:
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
24 авг 2019, 18:52
wayLANder писал(а):
07 май 2019, 00:05
Система:
  3: 945 4: 941
  temp: 35 C
  inxi: 3.0.27
Видеокарта:
*-display
       physical id: 0
       version: 00
       width: 64 bits
       clock: 33MHz
Захороните уже этот fgrlx как радиоактивные отходы. :reap: :dash:
Белый Кролик
Решено: 10
24 авг 2019, 19:12
wayLANder писал(а):
24 авг 2019, 18:09
Сноси все что наделал и ставь заново чистую систему, потом переключайся на AMDGPU как написали выше. Ничего устанавливать для AMD не надо, все свободные драйверы в ядре и в менеджере драйверов они не отображаются!
Читай внимательно, там разжевано дальше некуда:
viewtopic.php?p=83892#p83892 - пункты 3,4,5,8 пропускай.
Вернуться в «Видеокарты»
Сейчас этот форум просматривают: GPT[Bot] и 1 гость
