Установка тем
wayLANder
Благодарил (а): 6 раз
Установка тем
05 май 2019, 14:06
Характеристики:
  Host: senya-Satellite-L50-A-K2K Kernel: 4.15.0-20-generic x86_64 bits: 64
  compiler: gcc v: 7.3.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Laptop System: TOSHIBA product: Satellite L50-A-K2K
  v: PSKJNR-01M00URU serial: <filter>
  Mobo: Intel model: VG10F v: Type2 - Board Version serial: <filter>
  UEFI [Legacy]: Insyde v: 1.20 date: 05/15/2013
  ID-1: BAT0 charge: 28.9 Wh condition: 28.9/45.3 Wh (64%)
  model: TKBSS G71C000FP110 status: Full
  Topology: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20754
  Speed: 1197 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1197
  3: 1197 4: 1197
  Device-1: Intel 3rd Gen Core processor Graphics
  vendor: Toshiba America Info Systems driver: i915 v: kernel
  bus ID: 00:02.0
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: Toshiba America Info Systems driver: nouveau v: kernel
  bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: modesetting,nouveau
  unloaded: fbdev,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 18.2.8
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: Toshiba America Info Systems driver: snd_hda_intel v: kernel
  bus ID: 00:1b.0
  Sound Server: ALSA v: k4.15.0-20-generic
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Lite-On driver: ath9k v: kernel port: 3000 bus ID: 08:00.0
  IF: wlp8s0 state: up mac: <filter>
  Device-2: Qualcomm Atheros QCA8172 Fast Ethernet
  vendor: Toshiba America Info Systems driver: alx v: kernel port: 2000
  bus ID: 09:00.0
  IF: enp9s0 state: down mac: <filter>
  Local Storage: total: 931.51 GiB used: 134.07 GiB (14.4%)
  ID-1: /dev/sda vendor: Toshiba model: HDWJ110 size: 931.51 GiB temp: 33 C
  ID-1: / size: 28.71 GiB used: 8.68 GiB (30.2%) fs: ext4 dev: /dev/sda5
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 244 Uptime: 3h 18m Memory: 7.67 GiB used: 2.85 GiB (37.2%)
  inxi: 3.0.27
Пытаюсь, допустим, установить эту тему https://www.opendesktop.org/s/XFCE/p/1241688/
Устанавливаю её, кидая папку из под рута в /usr/share/themes/ , дальше во Внешнем виде выбираю тему - но она далеко не такая, как на скринах на сайте. Меняется только цветовая схема, но иконок программ, Свернуть/закрыть окно, например - нет. Работает где-то на 20%.
Подскажите, как правильно устанавливать темы? Может я не для той оболочки выбрал?
Решение FreeStyler » 05 май 2019, 20:56
wayLANder, надо наверное гайд написать с разными DE и темами...
Итак, обычно основные директории 2:
~/.themes - собственно туда кидать темы
~/.icons - значки (там же курсоры)
Если их нет - создать. ~ - домашняя директория.
Скачал тему - нормально установилась. Да, значков в ней нет, но ведь не сложно найти самому! -__-
Заходим на этом же сайте в раздел Icon Themes и вбиваем в поиске mac. https://www.opendesktop.org/s/XFCE/sear ... chText/mac
В итоге значки можно взять отсюда https://www.opendesktop.org/s/XFCE/p/1102582/ https://www.opendesktop.org/p/1102582/s ... e=23612428
или отсюда
https://www.opendesktop.org/s/XFCE/p/1013714/ https://www.opendesktop.org/p/1013714/s ... eme.tar.xz
Они отличаются.
Заголовок окна настраивается в Диспетчере окон.
Вот что в итоге у меня вышло.
LM19Xfce (Снимок 8) [Работает] - Oracle VM VirtualBox_2019.05.06_00-24-11.png
wayLANder писал(а):
05 май 2019, 14:20
сможете подсказать, как собрать всё воедино? внутри темы папки от gtk2,3 xfce, xfwm4. Что с ними делать? Как заставить тему работать в "полной красе"?:)
Ничего не делать, они уже собраны и если тема появилась в списке - значит она уже "подходит", нужно всего лишь её выбрать и применить. Если значки с ней не шли - искать самому или спросить у автора или в комментариях. В комментариях, кстати, могут написать где взять значки.
BadBird
Благодарил (а): 175 раз
Установка тем
05 май 2019, 14:12
Вид окон и иконки надо отдельно находить и ставить...
wayLANder
Установка тем
05 май 2019, 14:20
Спасибо, на примере этой темы https://www.opendesktop.org/p/1241688/s ... ize=809442 сможете подсказать, как собрать всё воедино? внутри темы папки от gtk2,3 xfce, xfwm4. Что с ними делать? Как заставить тему работать в "полной красе"?:)
Установка тем
05 май 2019, 14:24
wayLANder писал(а):
05 май 2019, 14:20
gtk2,3 xfce, xfwm4.
Плюнуть нафиг , это три разных понятия от слова вообще. Блин.
wayLANder
Установка тем
05 май 2019, 14:27
Я юзаю линукс буквально неделю, поэтому прошу сильно не бить:) Примерно понимаю, что это разные оболочки, если вкраце. Но какая подходит моей системе еще не понял, вроде gtk3... Так как собрать-то всё это дело?:)
alone
Установка тем
05 май 2019, 14:46
Одной папки темы не хватает. Надо либо искать всё по отдельности, или искать "тему" полностью собранную из всех 5 пунктов, ну или подбирать всё под себя. Если размер темы меньше 1Мб, значит иконок там точно нет.
FreeStyler
Решено: 7
Благодарил (а): 772 раза
Установка тем
05 май 2019, 20:56
или отсюда
Они отличаются.
wayLANder писал(а):
05 май 2019, 14:20
deadmau5 - Harmonic Mix
Вернуться в «Xfce»
