Тачпад manjaro
L1bre
Тачпад manjaro
Сообщение L1bre » 02 апр 2019, 11:43
  Host:........ Kernel: 4.19.32-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.1 Desktop: Cinnamon 4.0.9 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Aspire A315-41 v: V1.11
  serial: <filter>
  Mobo: RR model: Metapod_RR v: V1.11 serial: <filter> UEFI: Insyde v: 1.11
  date: 10/30/2018
  ID-1: BAT1 charge: 32.3 Wh condition: 32.3/37.0 Wh (87%)
  model: PANASONIC 41,50,31,36,4D,35,4A status: Full
  Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 31948
  Speed: 1449 MHz min/max: 1600/2000 MHz Core speeds (MHz): 1: 1441 2: 1498
  3: 1435 4: 1371 5: 1523 6: 1422 7: 1369 8: 1370
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
  vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 03:00.0
  Display: x11 server: X.Org 1.20.4 driver: amdgpu FAILED: ati
  unloaded: modesetting tty: N/A
  OpenGL: renderer: AMD RAVEN (DRM 3.27.0 4.19.32-1-MANJARO LLVM 7.0.1)
  v: 4.5 Mesa 18.3.5 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
  bus ID: 03:00.1
  Device-2: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 03:00.6
  Sound Server: ALSA v: k4.19.32-1-MANJARO
  vendor: Acer Incorporated ALI driver: r8168 v: 8.045.08-NAPI port: ...........
  bus ID: 01:00.1
  IF: enp1s0f1 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lite-On driver: ath10k_pci v: kernel port: .......... bus ID: 02:00.0
  Local Storage: total: 577.56 GiB used: 93.05 GiB (16.1%)
  ID-1: /dev/sda vendor: Seagate model: ST500LM012 HN-M500MBB
  ID-2: /dev/sdb vendor: Western Digital model: WDS120G2G0B-00EPW0
  ID-1: / size: 59.81 GiB used: 16.54 GiB (27.7%) fs: ext4 dev: /dev/sdb5
  System Temperatures: cpu: 55.4 C mobo: N/A gpu: amdgpu temp: 55 C
  Processes: 230 Uptime: 6h 04m Memory: 6.77 GiB used: 1.57 GiB (23.1%)
  Init: systemd Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0 inxi: 3.0.32
кто может подсказать как настроить мультетач на Manjaro cinnamon 18.0.4 ядро 4.19
ссылку ну или программу какую можно поюзать.
а то там в настройках нечего путного. только по горизонтали или по вертикали прокрутка
а охота чтоб громкость + - . переключать треки и т.д. т.п.
а то сложно две кнопки нажимать :D да и в темноте не всегда видно где там эта клавиша нужная :)
а клавиатуру с подсветкой нет смысла пока покупать
так как ноут ещё на гарантий
Благодарил (а): 803 раза
Тачпад manjaro
Сообщение rogoznik » 02 апр 2019, 15:03
L1bre, думаю это поможет
L1bre
Тачпад manjaro
Сообщение L1bre » 02 апр 2019, 20:31
а проще есть что?
Тачпад manjaro
Сообщение rogoznik » 03 апр 2019, 03:26
L1bre писал(а):
02 апр 2019, 20:31
а проще есть что?
Нет(точнее я не нашел)
L1bre
Тачпад manjaro
Сообщение L1bre » 03 апр 2019, 04:41
эх спасибо :)
