А вот как их под спойлер всунуть не сообразил.
я уже дома, потому это не кеды а корица. (В смысле у меня два компа - на работе КДЕ, дома Корица, на обоих свисток после обновы отвалился.)
(если снова проигноришь советы, то я умываю руки) да не игнорирую ж я!! не понимаю что от меня надо ).
на всякий случай с корицы процессы :
UNIT LOAD ACTIVE SUB DESCRIPTION
accounts-daemon.service loaded active running Accounts Service
acpid.service loaded active running ACPI event daemon
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
cgmanager.service loaded active running Cgroup management daemon
colord.service loaded active running Manage, Install and Generate Co
console-kit-daemon.service loaded active running Console Manager
cron.service loaded active running Regular background program proc
cups-browsed.service loaded active running Make remote CUPS printers avail
cups.service loaded active running CUPS Scheduler
dbus.service loaded active running D-Bus System Message Bus
getty@tty1.service loaded active running Getty on tty1
irqbalance.service loaded active running LSB: daemon to balance interrup
lvm2-lvmetad.service loaded active running LVM2 metadata daemon
mdm.service loaded active running MDM Display Manager
ModemManager.service loaded active running Modem Manager
NetworkManager.service loaded active running Network Manager
ntp.service loaded active running LSB: Start NTP daemon
polkitd.service loaded active running Authenticate and Authorize User
rsyslog.service loaded active running System Logging Service
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy S
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
lines 1-23...skipping...
systemd-udevd.service loaded active running udev Kernel Device Manager
lines 1-24...skipping...
thermald.service loaded active running Thermal Daemon Service
lines 1-25...skipping...
udisks2.service loaded active running Disk Manager
lines 1-26...skipping...
upower.service loaded active running Daemon for power management
lines 1-27...skipping...
user@1000.service loaded active running User Manager for UID 1000
lines 1-28...skipping...
lines 1-29...skipping...
LOAD = Reflects whether the unit definition was properly loaded.
lines 1-30...skipping...
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
lines 1-31...skipping...
SUB = The low-level unit activation state, values depend on unit type.
lines 1-32...skipping...
lines 1-33...skipping...
27 loaded units listed. Pass --all to see loaded but inactive units, too.
lines 1-34...skipping...
To show all installed unit files use 'systemctl list-unit-files'.
lines 1-35...skipping...
prusony@alexander-MINT ~ $
