LibreDWG
abulaev2008
Благодарил (а): 24 раза
LibreDWG
16 фев 2019, 20:20
Linux 4.15.0-45-generic #48-Ubuntu SMP Tue Jan 29 16:28:13 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
inxi -Fxz:
andrey@andrey-HP-Pavilion:~/Загрузки/libredwg-0.7.1608$ inxi -Fxz
Host: andrey-HP-Pavilion Kernel: 4.15.0-45-generic x86_64 bits: 64
compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.9
Type: Laptop System: Hewlett-Packard
product: HP Pavilion dv6500 Notebook PC v: Rev 1 serial: <filter>
Mobo: Quanta model: 30CF v: 85.26 serial: <filter> BIOS: Hewlett-Packard
v: F.34 date: 03/22/2011
ID-1: BAT0 charge: 14.2 Wh condition: 41.1/55.1 Wh (75%)
model: Hewlett-Packard Primary status: Charging
Topology: Dual Core model: AMD Athlon 64 X2 TK-55 bits: 64 type: MCP
arch: K8 rev.F+ rev: 1 L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 svm bogomips: 7200
Speed: 1800 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 1800 2: 1800
Device-1: NVIDIA C67 [GeForce 7150M / nForce 630M] vendor: Hewlett-Packard
driver: nouveau v: kernel bus ID: 00:12.0
Display: x11 server: X.Org 1.19.6 driver: nouveau
unloaded: fbdev,modesetting,vesa resolution: 1280x800~60Hz
OpenGL: renderer: NV67 v: 2.1 Mesa 18.2.2 direct render: Yes
Device-1: NVIDIA MCP67 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:07.0
Sound Server: ALSA v: k4.15.0-45-generic
Device-1: NVIDIA MCP67 Ethernet vendor: Hewlett-Packard driver: forcedeth
v: kernel port: 30f8 bus ID: 00:0a.0
IF: enp0s10 state: down mac: <filter>
Device-2: Broadcom Limited BCM4311 802.11b/g WLAN vendor: Hewlett-Packard
driver: wl v: kernel port: 30f8 bus ID: 03:00.0
Local Storage: total: 149.05 GiB used: 11.80 GiB (7.9%)
ID-1: /dev/sda vendor: Toshiba model: MK1637GSX size: 149.05 GiB
ID-1: / size: 145.71 GiB used: 11.80 GiB (8.1%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 64.0 C mobo: N/A gpu: nouveau temp: 64 C
Processes: 194 Uptime: 1h 05m Memory: 3.61 GiB used: 1.03 GiB (28.5%)
inxi: 3.0.27
Не получается установить LibreDWG.
пробовал по ссылке: https://medium.com/@gaganjyot/libredwg- ... 1cf9a2fdff,
на команде:
./configure --enable-trace
и так
andrey@andrey-HP-Pavilion:~/Загрузки/libredwg-0.7.1608$ ./configure && make && make install
как понял ругается на Python
Что мешает?
Вообщем, как посмотреть dwg в Linux?
Благодарил (а): 212 раз
LibreDWG
16 фев 2019, 20:34
abulaev2008 писал(а):
16 фев 2019, 20:20
LibreCAD.. https://ualinux.com/en/stream/seriya-vi ... v-librecad
abulaev2008
LibreDWG
16 фев 2019, 23:45
AlexZ, AlexZ, Принципиально не смотрю в поиске своего вопроса Yotube-видео (это край, когда нет ответа), а у тебя, там к тому же установка в Win. Там и так знаю. Даже не стал досматривать.
LibreDWG
17 фев 2019, 00:07
16 фев 2019, 23:45
Он там ссылается на недоступность сайта в тот момент.
А что не так-то? Думаешь LibreOffice не ставят в винду?
Или в линукс не можешь установить?
alex@acer:~$ apt policy librecad
librecad:
Установлен: (отсутствует)
Кандидат: 2.1.2-1
Таблица версий:
2.1.2-1 500
500 http://mirror.yandex.ru/ubuntu bionic/universe amd64 Packages
alex@acer:~$ sudo apt install librecad
[sudo] пароль для alex:
libmuparser2v5 libqt5printsupport5 librecad-data
Следующие НОВЫЕ пакеты будут установлены:
libmuparser2v5 libqt5printsupport5 librecad librecad-data
Обновлено 0 пакетов, установлено 4 новых пакетов, для удаления отмечено 0 пакетов, и 0 пакетов не обновлено.
Необходимо скачать 11,5 MB архивов.
После данной операции объём занятого дискового пространства возрастёт на 116 MB.
Хотите продолжить? [Д/н]
abulaev2008
LibreDWG
17 фев 2019, 00:46
16 фев 2019, 20:20
LibreDWG
А ты
AlexZ писал(а):
17 фев 2019, 00:07
librecad
не понял, в чем dwg открыть ?
Или от проектировщиков получать просто pdf?
colonel
Решено: 21
LibreDWG
17 фев 2019, 06:26
16 фев 2019, 23:45
правильно правильно нефиг смотреть всякую чушь , про то как установить программу, тем более что по той ссылке ставится для линукса из пакетов на ресурсе PPA
а там хоть дебку скачивай , хоть РРА репу подключай, ....
впрочем , ... можно просто для начала посмотреть наличие LibreCAD в стандартно подключенных репах (в минт17.3 например нашлись )
17 фев 2019, 00:46
вроде было конкретно сказано что LibreCAD
и поставить то несложно , тут только посмотреть надо насколько эти штуки ( LibreCad , или LibreDWG, или ...) будут открывать dwg сделанные под виндом в последних версиях "CAD"-программ ( или в чем там работают проектировщики)
если очень надо можно попробовать уже вроде платный BricsCAD - https://bricscad-russia.ru/ ( https://bricscad-russia.ru/blog/category/news/ )
"или от проектировщиков получать просто pdf "
Kurum
Благодарил (а): 193 раза
LibreDWG
17 фев 2019, 09:37
Ого, оказывается, есть LibreCAD :blink2:
16 фев 2019, 20:20
Я пока не смотрел LibreCAD, но советую DraftSight. Есть бесплатная версия этой программы, только регистрироваться на сайте нужно. Программа зачётная, только не поддерживает динамические блоки, но показывает их.
Linux - это свобода... :tux:
Текущая:
KDE Neon 5.2x
Предыдущая:
Linux Mint 19.1 Cinnamon
Железо:
demonlibra
Благодарил (а): 29 раз
LibreDWG
17 фев 2019, 10:19
Для просмотра dwg/dxf постоянно использую бесплатную программу VariCAD Viewer
Ранее пользовался программой ZWCAD Viewer.
Так же сделал конвертирование dwg/dxf в изображения и PDF через контекстное меню Nemo при помощи QCAD.
Последний раз редактировалось пользователем 4 demonlibra; всего редактировалось раз: 17
Контекстное меню Nemo
Kurum
LibreDWG
17 фев 2019, 10:34
Посмотрел LibreCAD. Программа ни о чём, зря только время потратил на изучение.
LibreDWG находится в альфе, судя по презентации данного продукта, даже тестировать смысла пока нету.
Текущая:
KDE Neon 5.2x
Предыдущая:
Железо:
abulaev2008
LibreDWG
17 фев 2019, 13:58
colonel писал(а):
17 фев 2019, 06:26
LibreCAD
при открытии dwg
colonel писал(а):
17 фев 2019, 06:26
вылетает
colonel
Решено: 21
LibreDWG
18 фев 2019, 19:09
17 фев 2019, 13:58
вылетает
не dwg, но dxf сделанное под виндом кадастровым инженером
и не вылетает.
а dwg старенькую чегой-то открывать не хочет
но не вылетает ...может чего не доустановлено?
говорил же "открывать dwg сделанные под виндом в последних версиях "CAD"-программ"
собсно , сказано не про то что сделанное в виндовых версиях не открывает, а про то что сделанное под виндом в новых версиях "автокада" может не открываться нормально в линуксовых программах и надо подбирать\искать ту программу которая будет открывать файлики разработчиков.
кстати , упомянутую выше DraftSightк лет 8 назад ставил знакомому (бесплатные и виндовую и линуксовую версии на разные компы ) неплохо справлялась , но не с dwg сделанными в крайней версии автокада на которую перешли разработчики.
однако по истечении некоторого времени программа отказалась работать и попросила купить её. но вроде пару лет если не больше проработала исправно.
abulaev2008
LibreDWG
22 фев 2019, 19:08
colonel писал(а):
18 фев 2019, 19:09
Все понятно, бесплатного ничего нет. А с платным не хочется экспериментировать.
Чтобы смотреть строительные проекты в Линукс, необходимо их перевести в pdf.
Вернуться в «Офис и документы»
