smartctl 6.6 2016-05-31 r4324 [i686-linux-4.15.0-39-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke,
www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Maxtor DiamondMax 21
Device Model: MAXTOR STM3250310AS
Serial Number: 6RY6ZYGH
Firmware Version: 3.AAF
User Capacity: 250 059 350 016 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Tue Feb 5 09:45:49 2019 MSK
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 430) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 92) minutes.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 253 006 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 097 097 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 099 099 020 Old_age Always - 1475
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 7
7 Seek_Error_Rate 0x000f 079 060 030 Pre-fail Always - 87557588
9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 8998
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 099 099 020 Old_age Always - 1477
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 059 053 045 Old_age Always - 41 (Min/Max 16/47)
194 Temperature_Celsius 0x0022 041 047 000 Old_age Always - 41 (0 16 0 0 0)
195 Hardware_ECC_Recovered 0x001a 079 066 000 Old_age Always - 194402621
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 178 000 Old_age Always - 889
200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0
202 Data_Address_Mark_Errs 0x0032 100 253 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 353 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 353 occurred at disk power-on lifetime: 8282 hours (345 days + 2 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 00 00 00 00 e0 Error: ABRT at LBA = 0x00000000 = 0
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
29 20 38 c0 dc 82 e0 00 03:02:16.550 READ MULTIPLE EXT
29 20 3a c6 86 83 e0 00 03:02:16.544 READ MULTIPLE EXT
29 20 06 c0 86 83 e0 00 03:02:16.537 READ MULTIPLE EXT
29 20 39 87 86 83 e0 00 03:02:16.618 READ MULTIPLE EXT
29 20 07 80 86 83 e0 00 03:02:16.611 READ MULTIPLE EXT
Error 352 occurred at disk power-on lifetime: 8281 hours (345 days + 1 hours)
84 51 00 47 e0 06 e0 Error: ICRC, ABRT at LBA = 0x0006e047 = 450631
25 00 08 40 e0 06 e0 00 02:21:59.298 READ DMA EXT
25 00 08 38 e0 06 e0 00 02:21:59.298 READ DMA EXT
25 00 08 30 e0 06 e0 00 02:21:59.298 READ DMA EXT
25 00 08 28 e0 06 e0 00 02:21:59.297 READ DMA EXT
25 00 08 20 e0 06 e0 00 02:21:59.297 READ DMA EXT
Error 351 occurred at disk power-on lifetime: 8281 hours (345 days + 1 hours)
84 51 97 61 e2 06 e0 Error: ICRC, ABRT 151 sectors at LBA = 0x0006e261 = 451169
25 00 48 b0 e1 06 e0 00 02:21:58.265 READ DMA EXT
27 00 00 00 00 00 e0 00 02:21:58.263 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 02:21:58.261 IDENTIFY DEVICE
ef 03 42 00 00 00 a0 00 02:21:58.261 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 02:21:58.258 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 350 occurred at disk power-on lifetime: 8281 hours (345 days + 1 hours)
84 51 07 f1 e2 06 e0 Error: ICRC, ABRT 7 sectors at LBA = 0x0006e2f1 = 451313
25 00 48 b0 e1 06 e0 00 02:21:56.779 READ DMA EXT
35 00 10 98 37 c9 e0 00 02:21:56.258 WRITE DMA EXT
27 00 00 00 00 00 e0 00 02:21:56.258 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 02:21:56.256 IDENTIFY DEVICE
ef 03 42 00 00 00 a0 00 02:21:56.254 SET FEATURES [Set transfer mode]
Error 349 occurred at disk power-on lifetime: 8281 hours (345 days + 1 hours)
84 51 cf e1 de 06 e0 Error: ICRC, ABRT 207 sectors at LBA = 0x0006dee1 = 450273
25 00 00 b0 de 06 e0 00 02:21:55.125 READ DMA EXT
ec 00 00 00 00 00 a0 00 02:21:56.258 IDENTIFY DEVICE
ef 03 42 00 00 00 a0 00 02:21:56.256 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 02:21:56.254 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
SMART Self-test log structure revision number 1
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
