Как убрать пользователя libvirt-qemu из окна входа в систему ?
SNIKERSMRG
16 янв 2019, 18:42
Добрый вечер всем !
Мои характеристики компьютера такие:
  Host: computer Kernel: 4.15.0-43-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Desktop Mobo: Micro-Star model: B350 PC MATE (MS-7A34) v: 2.0
  serial: <filter> UEFI [Legacy]: American Megatrends v: A.H0
  date: 11/01/2018
  Topology: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
  rev: 2 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 81596
  Speed: 1379 MHz min/max: 1550/3400 MHz Core speeds (MHz): 1: 1379 2: 1449
  3: 1510 4: 1462 5: 1381 6: 1532 7: 1379 8: 1383 9: 1412 10: 1482 11: 1502
  12: 1474
  Device-1: NVIDIA GK106 [GeForce GTX 660] vendor: Palit Microsystems
  driver: nvidia v: 390.77 bus ID: 1c:00.0
  Display: server: X.Org 1.19.6 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 660/PCIe/SSE2 v: 4.6.0 NVIDIA 390.77
  Device-1: NVIDIA GK106 HDMI Audio vendor: Palit Microsystems
  driver: snd_hda_intel v: kernel bus ID: 1c:00.1
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 1e:00.3
  Sound Server: ALSA v: k4.15.0-43-generic
  vendor: Micro-Star MSI driver: r8169 v: 2.3LK-NAPI port: f000
  bus ID: 19:00.0
  IF: enp25s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Local Storage: total: 1.54 TiB used: 83.76 GiB (5.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB
  ID-2: /dev/sda vendor: Western Digital model: WD10EFRX-68FYTN0
  size: 931.51 GiB temp: 33 C
  ID-3: /dev/sdb vendor: Kingston model: SV300S37A120G size: 111.79 GiB
  temp: 27 C
  ID-4: /dev/sdc vendor: Western Digital model: WD3200AAJS-00L7A0
  size: 298.09 GiB temp: 38 C
  ID-1: / size: 228.23 GiB used: 11.90 GiB (5.2%) fs: ext4
  dev: /dev/nvme0n1p1
  ID-2: /home size: 915.89 GiB used: 65.65 GiB (7.2%) fs: ext4
  dev: /dev/sda1
  ID-3: swap-1 size: 7.63 GiB used: 23.2 MiB (0.3%) fs: swap dev: /dev/sdb1
  System Temperatures: cpu: 28.5 C mobo: N/A gpu: nvidia temp: 42 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
  Processes: 321 Uptime: 1h 54m Memory: 7.80 GiB used: 1.85 GiB (23.7%)
  inxi: 3.0.27
Коротко об ОС:
Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa on base: Ubuntu 18.04 bionic
После установки следующих пакетов:
qemu-kvm libvirt-bin bridge-utils virt-manager
На экране выбора пользователя для входа в систему появился пользователь "libvirt-qemu".
Скажите пожалуйста как его убрать из списка пользователей на вход в компьютер, не удаляя самого пользователя ?
SNIKERSMRG
16 янв 2019, 19:35
Проблема выглядит так:
colonel
Решено: 21
16 янв 2019, 19:36
SNIKERSMRG писал(а):
16 янв 2019, 18:42
... На экране выбора пользователя для входа в систему ..... пользователь "libvirt-qemu".
....как его убрать из списка пользователей на вход в компьютер, не удаляя самого пользователя ?
в старых mdm это было несложно сделать и в графических настройках, в последних версиях мдм можно было сделать редактированием конфига mdm.conf
в вашем случае скорее всего надо искать как отредактировать запись в конфигах LightDM (может в /etc/lightdm/lightdm.conf , а может в /etc/lightdm/users.conf ) точнее не скажу , т.к. не пользую LightDM
гугл в помощь - ТЫЦ>>>
16 янв 2019, 20:41
SNIKERSMRG, Меню - Параметры системы - Окно входа в систему.
Включите там пункты "скрыть список пользователей" и "разрешить вход в систему вручную".
А вообще обычно на экране входа не показываются пользователи чей UID меньше 1000.
colonel
Решено: 21
16 янв 2019, 20:54
zuzabrik писал(а):
16 янв 2019, 20:41
... Включите там пункты "скрыть список пользователей" и "разрешить вход в систему вручную".
ТС-у не надо скрывать список пользователей, ему надо скрыть только один аккаунт, ненужный ему в окне входа.
уже говорил что в мдм это сделать несложно. в LightDM скорее всего также возможно редактированием конфигов
17 янв 2019, 06:43
colonel писал(а):
16 янв 2019, 20:54
Тогда самый простой способ имхо - понизить UID пользователя qemu меньше 1000, вроде ничего криминального в этом действии нет.
А здесь рецепт через конфиги для LightDM - https://ubuntugeeks.com/questions/654/h ... gin-screen
colonel
Решено: 21
17 янв 2019, 11:54
zuzabrik писал(а):
17 янв 2019, 06:43
...здесь рецепт через конфиги для LightDM -(ссылка на ubuntugeeks)...
собсно о том же сказано было в #3 и по ссылке в гуглу с названием "ТЫЦ>>> " на первой же странице присутствует ссыль(линк) на вами указанную страничку в инете
zuzabrik писал(а):
17 янв 2019, 06:43
...самый простой способ имхо - понизить UID пользователя ...
простой не значит хороший , но возможно что так , в такого рода частном случае когда скрываемый пользователь - "libvirt-qemu".
не знаю что он из себя представляет в реале , этот библиотечновиртуальный юзер( т.к. не "виртуалы" не юзаю) , и какие внезапчики могут вылезти, но для реальных аккаунтов пользователей таковой способ небольшими нежданчиками очень даже вполне может обрадовать.
