как увеличить производительность виртуальной машины
pakistanec
Благодарил (а): 9 раз
13 дек 2018, 20:15
System:    Host: pk Kernel: 4.13.0-45-generic x86_64 (64 bit gcc: 5.4.0)
Machine:   System: HP product: HP Notebook v: Type1ProductConfigId
           Mobo: HP model: 82F7 v: 40.38 Bios: Insyde v: F.21 date: 10/27/2016
CPU:       Quad core AMD A6-7310 APU with AMD Radeon R4 Graphics (-MCP-) cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 15971
           clock speeds: max: 2000 MHz 1: 1702 MHz 2: 1634 MHz 3: 1666 MHz
           4: 1669 MHz
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics]
           bus-ID: 00:01.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
           bus-ID: 01:00.0
           Resolution: 1366x768@60.00hz
           GLX Renderer: AMD MULLINS (DRM 2.50.0 / 4.13.0-45-generic, LLVM 5.0.0)
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
           driver: snd_hda_intel bus-ID: 00:01.1
           Sound: Advanced Linux Sound Architecture v: k4.13.0-45-generic
Network:   Card-1: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: 3000 bus-ID: 02:00.0
           IF: mon0 state: unknown mac: <filter>
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           Card-3: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
Drives:    HDD Total Size: 500.1GB (23.0% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB
Partition: ID-1: / size: 14G used: 11G (81%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 441G used: 94G (23%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 4.00GB used: 0.52GB (13%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 50.0C mobo: 20.0C gpu: N/A,50.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 275 Uptime: 2 days Memory: 6320.3/6936.7MB
на виртуальной машине через virtualbox стоит kali
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
13 дек 2018, 21:03
Аппаратную виртуализацию процессор вроде бы поддерживает (флаг "svm" присутствует). Дополнительно можно проверить командой lscpu
Первое, нужно зайти в биос (пардон, уефи) и поискать там включение аппаратной виртуализации. И включить :) Хотя в ноутах такого может и не быть.
Второе, поискать в гостевой системе пакеты типа vitrualbox-guest-utils. И установить.
14 дек 2018, 06:56
Ара Магеддон писал(а):
13 дек 2018, 21:03
Даже искать ничего не нужно.
pakistanec, идешь в меню запущенной ВМ, Устройства, Подключить образ диска дополнений гостевой ОС. И потом ставишь эти дополнения.
pakistanec
16 дек 2018, 20:19
darkfenix, Не удалось подключить виртуальный оптический диск /home/pakistanec/.config/VirtualBox/VBoxGuestAdditions_5.1.38.iso к приводу машины kali.
Could not mount the media/drive '/home/pakistanec/.config/VirtualBox/VBoxGuestAdditions_5.1.38.iso' (VERR_PDM_MEDIA_LOCKED).
Код ошибки: NS_ERROR_FAILURE (0x80004005)
Компонент: ConsoleWrap
Интерфейс: IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
Вызванный интерфейс: IMachine {b2547866-a0a1-4391-8b86-6952d82efaa0}
16 дек 2018, 20:27
Покажи вывод
Благодарил (а): 212 раз
16 дек 2018, 20:59
pakistanec писал(а):
16 дек 2018, 20:19
При подключении дополнений в настройках боксы контроллер IDE пустой был?
pakistanec
17 дек 2018, 09:41
darkfenix, pakistanec adm cdrom sudo dip plugdev lpadmin sambashare
pakistanec
17 дек 2018, 09:43
AlexZ, нет
там оптический привод
17 дек 2018, 10:10
pakistanec, как минимум нужно добавить себя в группу vboxusers
sudo usermod -a -G vboxusers $USER
pakistanec
17 дек 2018, 10:35
darkfenix, все равно не хочет
Ара Магеддон
Решено: 18
17 дек 2018, 13:23
Всё равно не пойму, зачем возиться с образом, если есть пакеты. Что там такого интересного и уникального лежит?
https://hackware.ru/?p=490 (см. пункт №2)
Способ №2: https://download.virtualbox.org/virtualbox/
Заходите в папочку с вашей версией virtualbox и качаете подходящий .deb (смотря на чём ваша версия Kali основана)
ИМХО, первый вариант предпочтительней.
И опять же повторюсь, без включения аппаратной виртуализации в биосе - ничего быстро работать не будет.
18 дек 2018, 11:41
17 дек 2018, 09:43
нет
Понятно, что оптический привод, он должен быть пустой..
Иногда забывают изъять установочный образ из привода, т.е. вот так..
то при подключении образа Дополнений вылазит подобная ошибка о невозможности монтирования диска..
19 дек 2018, 07:11
А еще я бы посоветовал поставить VB версии посвежее - 5.2, к примеру. VirtualBox
20 дек 2018, 10:42
13 дек 2018, 21:03
Это конечно, как самой-собой разумеющиеся должно быть. Как и то, что ОС должна быть в УЕФИ установлена.
По самому названию топика и аппаратной конфигурации в выхлопе inxi смотрим - https://www.notebook-center.ru/processor_1093.html
Понятно, что не для виртуалок. И задавать глупые вопросы про увеличение производительности виртуальных ОС не нужно.
Далее - работа на свободных драйверах от АМД, да ещё и с ноутбучной конфигурацией - это не работа. Так, установить и загрузить ОС в графике для дальнейшей установки проприетари.
Чтобы кто, что не говорил за amdgpu, но для связки и нормальной работы AMD APU+дискретка нужен проприетарный драйвер, чтобы рендерила дискретка, выводила встройка, так задумано вообще-то вендором, а не переключать карты. Они должны работать обе всегда.
И никакие дополнения, новые версии VB вопроса не решат.
Нужно начинать с Минт 17.3 + fglrx.
pakistanec
25 дек 2018, 18:39
Unborn, спасибо но мало что понял сейчас буду разбираться)
27 дек 2018, 23:10
Unborn писал(а):
20 дек 2018, 10:42
Блин, ну в каждой теме, ей-богу.. :-D
Unborn писал(а):
20 дек 2018, 10:42
Ну конечно, древний минт на бук 2-х лет от роду..(date: 10/27/2016) :hoho: :-D
