При запуске игры из-под wine на отдельном x-сервере не появляется картинкаЗ
Модератор: WWolf
TreShk0
19 ноя 2018, 05:17
Запуская игру Fallout3 через этот скрипт
#!/bin/bash
cd "/home/timofey/.wine-fallout3/drive_c/Fallout 3"
xinit /usr/bin/wine FalloutLauncher.exe -- :1
Запускается черный экран и нет ни изображения, ни звука. Но если переключить Ctrl+Alt+F7, то звук запускается.
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
Current Operating System: Linux timofey-TWH 4.10.0-38-generic #42~16.04.1-Ubuntu SMP Tue Oct 10 16:32:20 UTC 2017 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.10.0-38-generic root=UUID=82df6476-86eb-403e-afcd-c1fd4c3e5aaf ro quiet splash vt.handoff=7
Build Date: 13 October 2017  01:57:05PM
xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.33.6
	Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.1.log", Time: Mon Nov 19 07:59:42 2018
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
xf86: found device 2
002a:err:xrandr:xrandr12_init_modes Failed to get primary CRTC info.
000d:err:xrandr:xrandr12_init_modes Failed to get primary CRTC info.
0009:err:xrandr:xrandr12_init_modes Failed to get primary CRTC info.
0009:fixme:win:EnumDisplayDevicesW ((null),0,0x33f944,0x00000000), stub!
0009:fixme:keyboard:X11DRV_ActivateKeyboardLayout 0x4190419, 0000: semi-stub!
[ 153.010]
[ 153.011] X Protocol Version 11, Revision 0
[ 153.011] Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
[ 153.011] Current Operating System: Linux timofey-TWH 4.10.0-38-generic #42~16.04.1-Ubuntu SMP Tue Oct 10 16:32:20 UTC 2017 x86_64
[ 153.011] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.10.0-38-generic root=UUID=82df6476-86eb-403e-afcd-c1fd4c3e5aaf ro quiet splash vt.handoff=7
[ 153.011] Build Date: 13 October 2017 01:57:05PM
[ 153.011] xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see http://www.ubuntu.com/support)
[ 153.011] Current version of pixman: 0.33.6
[ 153.011] Before reporting problems, check http://wiki.x.org
[ 153.011] Markers: (--) probed, (**) from config file, (==) default setting,
[ 153.011] (==) Log file: "/var/log/Xorg.1.log", Time: Mon Nov 19 07:59:42 2018
[ 153.011] (==) Using config file: "/etc/X11/xorg.conf"
[ 153.011] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 153.011] (==) ServerLayout "layout"
[ 153.011] (**) |-->Screen "nvidia" (0)
[ 153.011] (**) | |-->Monitor "<default monitor>"
[ 153.011] (**) | |-->Device "nvidia"
[ 153.012] (**) | |-->GPUDevice "nvidia"
[ 153.012] (==) No monitor specified for screen "nvidia".
[ 153.012] (**) |-->Inactive Device "intel"
[ 153.012] (==) Automatically adding devices
[ 153.012] (==) Automatically enabling devices
[ 153.012] (==) Automatically adding GPU devices
[ 153.012] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 153.012] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 153.012] Entry deleted from font path.
[ 153.012] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 153.012] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 153.012] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 153.012] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 153.012] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 153.012] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 153.012] (II) The server relies on udev to provide the list of input devices.
[ 153.012] (II) Loader magic: 0x560468a4edc0
[ 153.012] (II) Module ABI versions:
[ 153.012] X.Org ANSI C Emulation: 0.4
[ 153.012] X.Org Video Driver: 20.0
[ 153.012] X.Org XInput driver : 22.1
[ 153.012] X.Org Server Extension : 9.0
[ 153.013] (--) using VT number 3
[ 153.013] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 153.014] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 153.014] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 153.014] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[ 153.014] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 153.015] (--) PCI:*(0:0:2:0) 8086:0106:152d:0873 rev 9, Mem @ 0xd1400000/4194304, 0xc0000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[ 153.015] (--) PCI: (0:1:0:0) 10de:0df4:152d:0873 rev 161, Mem @ 0xd0000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 153.015] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 153.015] (II) "glx" will be loaded by default.
[ 153.015] (II) LoadModule: "glx"
[ 153.015] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 153.027] (II) Module glx: vendor="NVIDIA Corporation"
[ 153.027] compiled for 4.0.2, module version = 1.0.0
[ 153.027] Module class: X.Org Server Extension
[ 153.027] (II) NVIDIA GLX Module 384.130 Wed Mar 21 02:54:48 PDT 2018
[ 153.027] (II) LoadModule: "nvidia"
[ 153.027] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 153.028] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 153.028] compiled for 4.0.2, module version = 1.0.0
[ 153.028] Module class: X.Org Video Driver
[ 153.028] (II) LoadModule: "modesetting"
[ 153.028] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 153.028] (II) Module modesetting: vendor="X.Org Foundation"
[ 153.028] compiled for 1.18.4, module version = 1.18.4
[ 153.028] ABI class: X.Org Video Driver, version 20.0
[ 153.028] (II) NVIDIA dlloader X Driver 384.130 Wed Mar 21 02:29:29 PDT 2018
[ 153.028] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 153.028] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 153.357] (II) Loading sub module "fb"
[ 153.357] (II) LoadModule: "fb"
[ 153.358] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 153.358] (II) Module fb: vendor="X.Org Foundation"
[ 153.358] compiled for 1.18.4, module version = 1.0.0
[ 153.358] ABI class: X.Org ANSI C Emulation, version 0.4
[ 153.358] (II) Loading sub module "wfb"
[ 153.358] (II) LoadModule: "wfb"
[ 153.358] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 153.359] (II) Module wfb: vendor="X.Org Foundation"
[ 153.359] compiled for 1.18.4, module version = 1.0.0
[ 153.359] ABI class: X.Org ANSI C Emulation, version 0.4
[ 153.359] (II) Loading sub module "ramdac"
[ 153.359] (II) LoadModule: "ramdac"
[ 153.359] (II) Module "ramdac" already built-in
[ 153.359] (WW) Falling back to old probe method for modesetting
[ 153.360] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 153.360] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 153.360] (==) NVIDIA(0): RGB weight 888
[ 153.360] (==) NVIDIA(0): Default visual is TrueColor
[ 153.360] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 153.360] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[ 153.360] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
[ 153.360] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[ 153.360] (**) NVIDIA(0): Enabling 2D acceleration
[ 153.370] (II) NVIDIA(0): NVIDIA GPU GeForce GT 540M (GF108) at PCI:1:0:0 (GPU-0)
[ 153.370] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 153.370] (--) NVIDIA(0): VideoBIOS: 70.08.53.00.10
[ 153.370] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 153.370] (II) NVIDIA(0): Validated MetaModes:
[ 153.370] (II) NVIDIA(0): "NULL"
[ 153.370] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 153.370] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 153.370] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 153.370] (--) Depth 24 pixmap format is 32 bpp
[ 153.371] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 153.371] (II) NVIDIA: access.
[ 153.391] (II) NVIDIA(0): Setting mode "NULL"
[ 153.395] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 153.395] (==) NVIDIA(0): Backing store enabled
[ 153.395] (==) NVIDIA(0): Silken mouse enabled
[ 153.396] (==) NVIDIA(0): DPMS enabled
[ 153.396] (II) Loading sub module "dri2"
[ 153.396] (II) LoadModule: "dri2"
[ 153.396] (II) Module "dri2" already built-in
[ 153.396] (II) NVIDIA(0): [DRI2] Setup complete
[ 153.396] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 153.396] (--) RandR disabled
[ 153.400] (II) SELinux: Disabled on system
[ 153.401] (II) Initializing extension GLX
[ 153.401] (II) Indirect GLX disabled.
[ 153.463] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 153.463] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 153.463] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 153.463] (II) LoadModule: "libinput"
[ 153.464] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 153.465] (II) Module libinput: vendor="X.Org Foundation"
[ 153.465] compiled for 1.18.4, module version = 0.18.0
[ 153.465] Module class: X.Org XInput Driver
[ 153.465] ABI class: X.Org XInput driver, version 22.1
[ 153.465] (II) Using input driver 'libinput' for 'Power Button'
[ 153.465] (**) Power Button: always reports core events
[ 153.465] (**) Option "Device" "/dev/input/event3"
[ 153.465] (**) Option "_source" "server/udev"
[ 153.465] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[ 153.465] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[ 153.480] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 153.480] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 153.480] (**) Option "xkb_model" "pc105"
[ 153.480] (**) Option "xkb_layout" "us,ru"
[ 153.480] (**) Option "xkb_variant" ","
[ 153.480] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 153.509] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[ 153.509] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[ 153.509] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 153.509] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 153.509] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 153.509] (II) Using input driver 'libinput' for 'Video Bus'
[ 153.509] (**) Video Bus: always reports core events
[ 153.509] (**) Option "Device" "/dev/input/event6"
[ 153.509] (**) Option "_source" "server/udev"
[ 153.510] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[ 153.510] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[ 153.532] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:02/input/input8/event6"
[ 153.532] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 153.532] (**) Option "xkb_model" "pc105"
[ 153.532] (**) Option "xkb_layout" "us,ru"
[ 153.532] (**) Option "xkb_variant" ","
[ 153.532] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 153.533] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[ 153.533] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[ 153.535] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 153.535] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 153.535] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 153.535] (II) Using input driver 'libinput' for 'Video Bus'
[ 153.535] (**) Video Bus: always reports core events
[ 153.535] (**) Option "Device" "/dev/input/event5"
[ 153.535] (**) Option "_source" "server/udev"
[ 153.536] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[ 153.536] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[ 153.556] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2a/LNXVIDEO:01/input/input7/event5"
[ 153.556] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 153.556] (**) Option "xkb_model" "pc105"
[ 153.556] (**) Option "xkb_layout" "us,ru"
[ 153.556] (**) Option "xkb_variant" ","
[ 153.556] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 153.557] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[ 153.557] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[ 153.558] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 153.558] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 153.559] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 153.559] (II) Using input driver 'libinput' for 'Power Button'
[ 153.559] (**) Power Button: always reports core events
[ 153.559] (**) Option "Device" "/dev/input/event0"
[ 153.559] (**) Option "_source" "server/udev"
[ 153.559] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[ 153.559] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[ 153.572] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 153.572] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 153.572] (**) Option "xkb_model" "pc105"
[ 153.572] (**) Option "xkb_layout" "us,ru"
[ 153.572] (**) Option "xkb_variant" ","
[ 153.572] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 153.573] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[ 153.573] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[ 153.574] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 153.574] (II) No input driver specified, ignoring this device.
[ 153.574] (II) This device may have been added with another device file.
[ 153.575] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 153.575] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 153.575] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 153.575] (II) Using input driver 'libinput' for 'Sleep Button'
[ 153.575] (**) Sleep Button: always reports core events
[ 153.575] (**) Option "Device" "/dev/input/event1"
[ 153.575] (**) Option "_source" "server/udev"
[ 153.576] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 153.576] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[ 153.596] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 153.596] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 153.596] (**) Option "xkb_model" "pc105"
[ 153.596] (**) Option "xkb_layout" "us,ru"
[ 153.596] (**) Option "xkb_variant" ","
[ 153.596] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 153.597] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 153.597] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[ 153.598] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 153.598] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 153.598] (II) LoadModule: "modesetting"
[ 153.599] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 153.599] (II) Module modesetting: vendor="X.Org Foundation"
[ 153.599] compiled for 1.18.4, module version = 1.18.4
[ 153.599] Module class: X.Org Video Driver
[ 153.599] ABI class: X.Org Video Driver, version 20.0
[ 153.599] (II) UnloadModule: "modesetting"
[ 153.599] (II) Unloading modesetting
[ 153.599] (II) Failed to load module "modesetting" (already loaded, 22020)
[ 153.599] (II) modeset(G0): using drv /dev/dri/card0
[ 153.599] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 153.599] (==) modeset(G0): RGB weight 888
[ 153.599] (==) modeset(G0): Default visual is TrueColor
[ 153.599] (II) Loading sub module "glamoregl"
[ 153.599] (II) LoadModule: "glamoregl"
[ 153.599] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 153.608] (II) Module glamoregl: vendor="X.Org Foundation"
[ 153.608] compiled for 1.18.4, module version = 1.0.0
[ 153.608] ABI class: X.Org ANSI C Emulation, version 0.4
[ 153.608] (II) glamor: OpenGL accelerated X.org driver based.
[ 153.629] (EE) modeset(G0): eglInitialize() failed
[ 153.630] (EE) modeset(G0): glamor initialization failed
[ 153.630] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[ 153.630] (II) modeset(G0): Output LVDS-1-1 has no monitor section
[ 153.634] (II) modeset(G0): Output VGA-1-1 has no monitor section
[ 153.643] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 153.643] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 153.656] (II) modeset(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 153.656] (==) modeset(G0): DPI set to (96, 96)
[ 153.656] (II) Loading sub module "fb"
[ 153.656] (II) LoadModule: "fb"
[ 153.656] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 153.656] (II) Module fb: vendor="X.Org Foundation"
[ 153.656] compiled for 1.18.4, module version = 1.0.0
[ 153.656] ABI class: X.Org ANSI C Emulation, version 0.4
[ 153.656] (II) Loading sub module "shadow"
[ 153.656] (II) LoadModule: "shadow"
[ 153.656] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 153.657] (II) Module shadow: vendor="X.Org Foundation"
[ 153.657] compiled for 1.18.4, module version = 1.1.0
[ 153.657] ABI class: X.Org ANSI C Emulation, version 0.4
[ 153.657] (==) modeset(G0): Backing store enabled
[ 153.657] (==) modeset(G0): Silken mouse enabled
[ 153.657] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 153.657] (==) modeset(G0): DPMS enabled
[ 153.657] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 153.657] (WW) modeset(G0): Option "IgnoreDisplayDevices" is not used
[ 153.937] (II) modeset(G0): Damage tracking initialized
[ 153.937] xf86: found device 2
[ 153.939] (II) config/udev: Adding input device USB Webcam (/dev/input/event15)
[ 153.939] (**) USB Webcam: Applying InputClass "evdev keyboard catchall"
[ 153.939] (**) USB Webcam: Applying InputClass "libinput keyboard catchall"
[ 153.939] (II) Using input driver 'libinput' for 'USB Webcam'
[ 153.939] (**) USB Webcam: always reports core events
[ 153.939] (**) Option "Device" "/dev/input/event15"
[ 153.939] (**) Option "_source" "server/udev"
[ 153.940] (II) input device 'USB Webcam', /dev/input/event15 is tagged by udev as: Keyboard
[ 153.940] (II) input device 'USB Webcam', /dev/input/event15 is a keyboard
[ 153.984] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input16/event15"
[ 153.984] (II) XINPUT: Adding extended input device "USB Webcam" (type: KEYBOARD, id 11)
[ 153.984] (**) Option "xkb_model" "pc105"
[ 153.984] (**) Option "xkb_layout" "us,ru"
[ 153.984] (**) Option "xkb_variant" ","
[ 153.984] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 153.985] (II) input device 'USB Webcam', /dev/input/event15 is tagged by udev as: Keyboard
[ 153.986] (II) input device 'USB Webcam', /dev/input/event15 is a keyboard
[ 153.986] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[ 153.986] (II) No input driver specified, ignoring this device.
[ 153.986] (II) This device may have been added with another device file.
[ 153.987] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[ 153.987] (II) No input driver specified, ignoring this device.
[ 153.987] (II) This device may have been added with another device file.
[ 153.988] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[ 153.988] (II) No input driver specified, ignoring this device.
[ 153.988] (II) This device may have been added with another device file.
[ 153.989] (II) config/udev: Adding input device Holtek USB Gaming Mouse (/dev/input/event7)
[ 153.989] (**) Holtek USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[ 153.989] (**) Holtek USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[ 153.989] (II) Using input driver 'libinput' for 'Holtek USB Gaming Mouse'
[ 153.989] (**) Holtek USB Gaming Mouse: always reports core events
[ 153.990] (**) Option "Device" "/dev/input/event7"
[ 153.990] (**) Option "_source" "server/udev"
[ 153.990] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is tagged by udev as: Keyboard
[ 153.991] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is a keyboard
[ 154.032] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:04D9:A067.0001/input/input9/event7"
[ 154.032] (II) XINPUT: Adding extended input device "Holtek USB Gaming Mouse" (type: KEYBOARD, id 12)
[ 154.032] (**) Option "xkb_model" "pc105"
[ 154.032] (**) Option "xkb_layout" "us,ru"
[ 154.032] (**) Option "xkb_variant" ","
[ 154.032] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 154.034] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is tagged by udev as: Keyboard
[ 154.034] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is a keyboard
[ 154.035] (II) config/udev: Adding input device Holtek USB Gaming Mouse (/dev/input/event8)
[ 154.035] (**) Holtek USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 154.035] (**) Holtek USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[ 154.035] (**) Holtek USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 154.035] (**) Holtek USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[ 154.035] (II) Using input driver 'libinput' for 'Holtek USB Gaming Mouse'
[ 154.035] (**) Holtek USB Gaming Mouse: always reports core events
[ 154.035] (**) Option "Device" "/dev/input/event8"
[ 154.035] (**) Option "_source" "server/udev"
[ 154.037] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is tagged by udev as: Keyboard Mouse
[ 154.037] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a pointer caps
[ 154.037] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a keyboard
[ 154.056] (II) libinput: Holtek USB Gaming Mouse: needs a virtual subdevice
[ 154.056] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:04D9:A067.0002/input/input10/event8"
[ 154.056] (II) XINPUT: Adding extended input device "Holtek USB Gaming Mouse" (type: MOUSE, id 13)
[ 154.057] (**) Option "AccelerationScheme" "none"
[ 154.057] (**) Holtek USB Gaming Mouse: (accel) selected scheme none/0
[ 154.057] (**) Holtek USB Gaming Mouse: (accel) acceleration factor: 2.000
[ 154.057] (**) Holtek USB Gaming Mouse: (accel) acceleration threshold: 4
[ 154.058] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is tagged by udev as: Keyboard Mouse
[ 154.058] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a pointer caps
[ 154.058] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a keyboard
[ 154.059] (II) config/udev: Adding input device Holtek USB Gaming Mouse (/dev/input/mouse0)
[ 154.059] (II) No input driver specified, ignoring this device.
[ 154.059] (II) This device may have been added with another device file.
[ 154.061] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event9)
[ 154.061] (**) SIGMACHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 154.061] (**) SIGMACHIP USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 154.061] (II) Using input driver 'libinput' for 'SIGMACHIP USB Keyboard'
[ 154.061] (**) SIGMACHIP USB Keyboard: always reports core events
[ 154.061] (**) Option "Device" "/dev/input/event9"
[ 154.061] (**) Option "_source" "server/udev"
[ 154.062] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is tagged by udev as: Keyboard
[ 154.062] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is a keyboard
[ 154.080] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/0003:1C4F:0026.0004/input/input11/event9"
[ 154.080] (II) XINPUT: Adding extended input device "SIGMACHIP USB Keyboard" (type: KEYBOARD, id 14)
[ 154.080] (**) Option "xkb_model" "pc105"
[ 154.080] (**) Option "xkb_layout" "us,ru"
[ 154.080] (**) Option "xkb_variant" ","
[ 154.080] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 154.082] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is tagged by udev as: Keyboard
[ 154.082] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is a keyboard
[ 154.083] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event10)
[ 154.083] (**) SIGMACHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 154.083] (**) SIGMACHIP USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 154.083] (II) Using input driver 'libinput' for 'SIGMACHIP USB Keyboard'
[ 154.083] (**) SIGMACHIP USB Keyboard: always reports core events
[ 154.083] (**) Option "Device" "/dev/input/event10"
[ 154.083] (**) Option "_source" "server/udev"
[ 154.085] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is tagged by udev as: Keyboard
[ 154.085] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is a keyboard
[ 154.104] (II) libinput: SIGMACHIP USB Keyboard: needs a virtual subdevice
[ 154.104] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.1/0003:1C4F:0026.0005/input/input12/event10"
[ 154.104] (II) XINPUT: Adding extended input device "SIGMACHIP USB Keyboard" (type: MOUSE, id 15)
[ 154.104] (**) Option "AccelerationScheme" "none"
[ 154.104] (**) SIGMACHIP USB Keyboard: (accel) selected scheme none/0
[ 154.104] (**) SIGMACHIP USB Keyboard: (accel) acceleration factor: 2.000
[ 154.104] (**) SIGMACHIP USB Keyboard: (accel) acceleration threshold: 4
[ 154.105] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is tagged by udev as: Keyboard
[ 154.106] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is a keyboard
[ 154.106] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 154.107] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 154.107] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 154.107] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 154.107] (**) AT Translated Set 2 keyboard: always reports core events
[ 154.107] (**) Option "Device" "/dev/input/event4"
[ 154.107] (**) Option "_source" "server/udev"
[ 154.107] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[ 154.108] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[ 154.128] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 154.128] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[ 154.128] (**) Option "xkb_model" "pc105"
[ 154.128] (**) Option "xkb_layout" "us,ru"
[ 154.128] (**) Option "xkb_variant" ","
[ 154.128] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 154.129] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[ 154.129] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[ 154.130] (II) config/udev: Adding input device FSPPS/2 Sentelic FingerSensingPad (/dev/input/event11)
[ 154.130] (**) FSPPS/2 Sentelic FingerSensingPad: Applying InputClass "evdev pointer catchall"
[ 154.130] (**) FSPPS/2 Sentelic FingerSensingPad: Applying InputClass "libinput pointer catchall"
[ 154.130] (II) Using input driver 'libinput' for 'FSPPS/2 Sentelic FingerSensingPad'
[ 154.130] (**) FSPPS/2 Sentelic FingerSensingPad: always reports core events
[ 154.130] (**) Option "Device" "/dev/input/event11"
[ 154.131] (**) Option "_source" "server/udev"
[ 154.131] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is tagged by udev as: Mouse
[ 154.131] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is a pointer caps
[ 154.160] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event11"
[ 154.160] (II) XINPUT: Adding extended input device "FSPPS/2 Sentelic FingerSensingPad" (type: MOUSE, id 17)
[ 154.160] (**) Option "AccelerationScheme" "none"
[ 154.160] (**) FSPPS/2 Sentelic FingerSensingPad: (accel) selected scheme none/0
[ 154.160] (**) FSPPS/2 Sentelic FingerSensingPad: (accel) acceleration factor: 2.000
[ 154.160] (**) FSPPS/2 Sentelic FingerSensingPad: (accel) acceleration threshold: 4
[ 154.161] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is tagged by udev as: Mouse
[ 154.161] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is a pointer caps
[ 154.162] (II) config/udev: Adding input device FSPPS/2 Sentelic FingerSensingPad (/dev/input/mouse1)
[ 154.162] (II) No input driver specified, ignoring this device.
[ 154.162] (II) This device may have been added with another device file.
[ 154.172] (**) Holtek USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 154.172] (**) Holtek USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[ 154.172] (**) Holtek USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 154.172] (**) Holtek USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[ 154.172] (II) Using input driver 'libinput' for 'Holtek USB Gaming Mouse'
[ 154.173] (**) Holtek USB Gaming Mouse: always reports core events
[ 154.173] (**) Option "Device" "/dev/input/event8"
[ 154.173] (**) Option "_source" "_driver/libinput"
[ 154.173] (II) libinput: Holtek USB Gaming Mouse: is a virtual subdevice
[ 154.173] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:04D9:A067.0002/input/input10/event8"
[ 154.173] (II) XINPUT: Adding extended input device "Holtek USB Gaming Mouse" (type: KEYBOARD, id 18)
[ 154.173] (**) Option "xkb_model" "pc105"
[ 154.173] (**) Option "xkb_layout" "us,ru"
[ 154.173] (**) Option "xkb_variant" ","
[ 154.173] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 154.173] (**) SIGMACHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 154.173] (**) SIGMACHIP USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 154.173] (II) Using input driver 'libinput' for 'SIGMACHIP USB Keyboard'
[ 154.173] (**) SIGMACHIP USB Keyboard: always reports core events
[ 154.173] (**) Option "Device" "/dev/input/event10"
[ 154.173] (II) libinput: SIGMACHIP USB Keyboard: is a virtual subdevice
[ 154.173] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.1/0003:1C4F:0026.0005/input/input12/event10"
[ 154.173] (II) XINPUT: Adding extended input device "SIGMACHIP USB Keyboard" (type: KEYBOARD, id 19)
[ 250.852] (II) NVIDIA(0): Setting mode "NULL"
[ 251.146] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[ 251.147] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[ 251.147] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[ 251.147] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[ 251.148] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[ 251.148] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[ 251.148] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[ 251.148] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[ 251.149] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 251.149] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[ 251.150] (II) input device 'USB Webcam', /dev/input/event15 is tagged by udev as: Keyboard
[ 251.150] (II) input device 'USB Webcam', /dev/input/event15 is a keyboard
[ 251.150] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is tagged by udev as: Keyboard
[ 251.150] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is a keyboard
[ 251.151] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is tagged by udev as: Keyboard Mouse
[ 251.151] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a pointer caps
[ 251.151] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a keyboard
[ 251.152] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is tagged by udev as: Keyboard
[ 251.152] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is a keyboard
[ 251.152] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is tagged by udev as: Keyboard
[ 251.152] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is a keyboard
[ 251.153] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[ 251.153] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[ 251.153] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is tagged by udev as: Mouse
[ 251.153] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is a pointer caps
[ 258.628] (II) NVIDIA(0): Setting mode "NULL"
[ 258.932] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[ 258.932] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[ 258.932] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[ 258.932] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[ 258.933] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[ 258.933] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[ 258.934] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[ 258.934] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[ 258.934] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 258.934] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[ 258.935] (II) input device 'USB Webcam', /dev/input/event15 is tagged by udev as: Keyboard
[ 258.935] (II) input device 'USB Webcam', /dev/input/event15 is a keyboard
[ 258.935] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is tagged by udev as: Keyboard
[ 258.935] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event7 is a keyboard
[ 258.936] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is tagged by udev as: Keyboard Mouse
[ 258.936] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a pointer caps
[ 258.936] (II) input device 'Holtek USB Gaming Mouse', /dev/input/event8 is a keyboard
[ 258.937] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is tagged by udev as: Keyboard
[ 258.937] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event9 is a keyboard
[ 258.938] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is tagged by udev as: Keyboard
[ 258.938] (II) input device 'SIGMACHIP USB Keyboard', /dev/input/event10 is a keyboard
[ 258.938] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[ 258.938] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[ 258.939] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is tagged by udev as: Mouse
[ 258.939] (II) input device 'FSPPS/2 Sentelic FingerSensingPad', /dev/input/event11 is a pointer caps
[ 1038.072] (II) UnloadModule: "libinput"
[ 1038.073] (II) UnloadModule: "libinput"
[ 1038.088] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 1038.089] (II) Server terminated successfully (0). Closing log file.
HW-Probe: https://linux-hardware.org/?probe=4e9eb1114c
При запуске без X-сервера в оконном режиме все нормально
Благодарил (а): 845 раз
19 ноя 2018, 11:22
TreShk0, вот почитай может - Запуск двух X server на Linux Mint 18.1
Вернуться в «Wine»
