Проблема с PlayOnLinux. Не отображаются виндовые установщики
Модератор: WWolf
Gwalf
14 ноя 2018, 08:13
Доброго времени суток!
Пользуюсь LM 19 Cinnamon x64.
System:    Host:GF72-8RE Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Micro-Star product: GF72 8RE v: REV:1.0 serial: N/A
           Mobo: Micro-Star model: MS-179E v: REV:1.0 serial: N/A
           UEFI [Legacy]: American Megatrends v: E179EIMS.107 date: 05/22/2018
Battery    BAT1: charge: 19.3 Wh 45.9% condition: 41.9/43.2 Wh (97%)
           model: MSI MS-179E status: Discharging
           hidpp__0: charge: 90% condition: NA/NA Wh
           model: Logitech M705 status: Discharging
CPU:       Quad core Intel Core i5-8300H (-MT-MCP-)
           arch: Skylake rev.10 cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 18432
           clock speeds: max: 4000 MHz 1: 900 MHz 2: 900 MHz 3: 900 MHz
           4: 900 MHz 5: 900 MHz 6: 899 MHz 7: 900 MHz 8: 900 MHz
Graphics:  Card-1: Intel Device 3e9b bus-ID: 00:02.0
           Card-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] bus-ID: 01:00.0
           drivers: modesetting,nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1920x1080@120.00hz
           OpenGL: renderer: GeForce GTX 1060/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.77 Direct Render: Yes
Audio:     Card Intel Device a348 driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Intel Device a370 driver: iwlwifi bus-ID: 00:14.3
           IF: wlo1 state: up speed: N/A duplex: N/A mac: <filter>
           Card-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet Controller
           driver: alx port: 3000 bus-ID: 02:00.0
Drives:    HDD Total Size: 1128.2GB (1.3% used)
           ID-1: /dev/sda model: SAMSUNG_MZNLN128 size: 128.0GB
           ID-2: /dev/sdb model: WDC_WD10SPZX size: 1000.2GB
Partition: ID-1: / size: 117G used: 14G (13%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 64.0C mobo: N/A gpu: 0.0:52C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 261 Uptime: 30 min Memory: 2505.2/7822.1MB
При установке игры через playonlinux вместо установщика появляется только вертикальная полоска шириной в один пиксель (на скриншоте). На панели запущенных программ установщик появляется, но такой же кривой. Пробовал на нескольких играх и приложениях - одно и тоже.
При кривом открытии окна отладчик PlayOnLinux пишет:
[POL_Wine] Message: Wine return: 1
Wine cannot find the FreeType font library.  To enable Wine to
use TrueType fonts please install a version of FreeType greater than
or equal to 2.0.5.
http://www.freetype.org
fixme:wininet:query_global_option INTERNET_OPTION_CONNECTED_STATE: semi-stub
Qurao
14 ноя 2018, 14:22
Братец, у меня тоже самое. Решения не нашел и писал сюда, но мб найдутся знающие. :tux:
Попробуй полностью удалить FreeType с удалением настроек и переустановить(у меня не помогло, мб тебе поможет). Есть еще способ удалить библиотеки, но у меня это тоже не прокатило.
https://www.linux.org.ru/forum/general/13328075
У нас армия пингвинов - у вас груда стекла.
https://linux-hardware.org/?probe=10abe11ae2
Qurao
17 ноя 2018, 19:49
Не знаю активна ли еще тема, но я нашел решение с помощью сообщества ЛОРА(Не в обиду). Может быть кому то будет полезным:
https://www.linux.org.ru/forum/general/ ... 2472792403
18 ноя 2018, 02:23
Qurao, на лоре вероятно больше пользователей PoL, я например его не очень сам перевариваю, исторически.
А в базовом вайне такой фигни не встречал пока)
DomeNight
19 дек 2019, 21:09
Я тоже с этим сталкивался, испробовал все что было на сайтах и переустанавливал 19.2 не хотела правильно отображать вайн окна пока не обновил Mint до 19.3. Я не программер и на линукс перешел не так давно и побороть данный недук не мог. Пишу для новичков!!!
Ядро 5.3.0-24
Минт 19.3
Вернуться в «Wine»
