Не работает WI-FI
millon
Благодарил (а): 4 раза
Не работает WI-FI
08 ноя 2018, 15:08
Здравствуйте. Помогите разобраться ,совсем запутался, стоял XP установил mint. Всё вроде работает кроме вайфая
millon@millon-HP-635-Notebook-PC:~$ rfkill list all
0: hp-wifi: Wireless LAN
	Soft blocked: yes
	Hard blocked: yes
1: hp-bluetooth: Bluetooth
	Soft blocked: yes
	Hard blocked: yes
2: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
3: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: yes
millon@millon-HP-635-Notebook-PC:~$ inxi -Fxz
System:    Host: millon-HP-635-Notebook-PC Kernel: 4.15.0-38-generic i686
           bits: 32 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Hewlett-Packard product: HP 635 Notebook PC v: 058A100000004C10002600000 serial: N/A
           Mobo: Hewlett-Packard model: 3577 v: 24.36 serial: N/A
           BIOS: Hewlett-Packard v: F.34 date: 07/27/2011
Battery    BAT0: charge: 41.3 Wh 86.8% condition: 47.6/47.6 Wh (100%)
           model: HP status: Discharging
CPU:       Dual core AMD E-450 APU with Radeon HD Graphics (-MCP-)
           arch: Bobcat rev.0 cache: 512 KB
           flags: (lm nx pae sse sse2 sse3 sse4a ssse3 svm) bmips: 6585
           clock speeds: max: 1650 MHz 1: 1299 MHz 2: 1041 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6320]
           bus-ID: 00:01.0
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.03hz
           OpenGL: renderer: AMD PALM (DRM 2.50.0 / 4.15.0-38-generic, LLVM 6.0.0)
           version: 3.3 Mesa 18.0.5 Direct Render: Yes
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Wrestler HDMI Audio
           driver: snd_hda_intel bus-ID: 00:01.1
           Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network:   Card-1: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 06:00.0
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k bus-ID: 07:00.0
           IF: wlo1 state: down mac: <filter>
Drives:    HDD Total Size: 320.1GB (5.6% used)
           ID-1: /dev/sda model: ST320LT020 size: 320.1GB
Partition: ID-1: / size: 291G used: 15G (6%) fs: ext4 dev: /dev/dm-1
           ID-2: /boot size: 704M used: 142M (22%) fs: ext4 dev: /dev/sda1
           ID-3: swap-1 size: 1.72GB used: 0.00GB (0%)
           fs: swap dev: /dev/dm-2
Sensors:   System Temperatures: cpu: 39.0C mobo: N/A gpu: 41.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 186 Uptime: 28 min Memory: 675.2/1607.6MB
millon@millon-HP-635-Notebook-PC:~$  lspci -knn | grep Net -A2
07:00.0 Network controller [0280]: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
	Subsystem: Hewlett-Packard Company AR9285 Wireless Network Adapter (PCI-Express) [103c:1461]
	Kernel driver in use: ath9k
	Kernel modules: ath9k
	Soft blocked: yes
	Hard blocked: yes
	Soft blocked: yes
	Hard blocked: yes
2: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
	Soft blocked: no
	Hard blocked: yes
millon@millon-HP-635-Notebook-PC:~$ iwlist scann
wlo1      Failed to read scan data : Network is down
eno1      Interface doesn't support scanning.
lo        Interface doesn't support scanning.
Bill Williamson
Решено: 34
Благодарил (а): 288 раз
Не работает WI-FI
08 ноя 2018, 16:42
millon, судя по инструкции, на клавише должен гореть белым индикатор, показывающий работу WLAN. Такое наблюдается?
millon
Не работает WI-FI
08 ноя 2018, 18:11
да , вы правы , должен гореть но увы горит красным ,на клавишу вообще не реагирует .В меню сети ,после включения сразу возвращается в состояние выкл. :dash2:
Не работает WI-FI
08 ноя 2018, 18:13
millon, посмотри в BIOS может там есть что про wifi
millon
Не работает WI-FI
08 ноя 2018, 18:18
В BIOS ничего похожего не видел , да и скудненький он у меня какой то, почти ничего нет
millon
Не работает WI-FI
08 ноя 2018, 18:20
Спасибо за коррекцию
Не работает WI-FI
08 ноя 2018, 18:24
millon, надо включить саму вафлю иначе ничего не получиться. А двойной клик по клавише включения вафли ничего не дает?
millon
Не работает WI-FI
08 ноя 2018, 18:25
Сей час смотрю вот это https://help.ubuntu.ru/wiki/broadcom но не уверен что это подойдёт мне.посмотрите пожалуйста
Благодарил (а): 1737 раз
Не работает WI-FI
08 ноя 2018, 18:26
millon писал(а):
08 ноя 2018, 15:08
millon писал(а):
08 ноя 2018, 15:08
sudo ifup wlo1 что говорит?
millon
Не работает WI-FI
08 ноя 2018, 18:28
darkfenix .Тереотически я это понимаю но как .Двойное нажатие тоже не катит
millon
Не работает WI-FI
08 ноя 2018, 18:31
WWolf. Unknown interface wlo1
Не работает WI-FI
08 ноя 2018, 18:34
millon, эм... ifconfig покажи
Не работает WI-FI
08 ноя 2018, 18:35
millon писал(а):
08 ноя 2018, 18:25
Сейчас тебе это не поможет, т.к. wifi физически не работает. Нужно ее включить, а уже потом разберемся что дальше делать.
millon
Не работает WI-FI
08 ноя 2018, 18:45
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.198  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::91e1:e4bd:ef6f:929e  prefixlen 64  scopeid 0x20<link>
        ether e4:11:5b:f9:9d:d7  txqueuelen 1000  (Ethernet)
        RX packets 12644  bytes 13240840 (13.2 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 12166  bytes 1277804 (1.2 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Локальная петля (Loopback))
        RX packets 1168  bytes 92565 (92.5 KB)
        TX packets 1168  bytes 92565 (92.5 KB)
millon
Не работает WI-FI
08 ноя 2018, 18:46
08 ноя 2018, 18:35
millon писал(а):
08 ноя 2018, 18:25
ok понятно
Не работает WI-FI
08 ноя 2018, 18:49
millon, а в лайве 18.3 работает?
Не работает WI-FI
08 ноя 2018, 18:50
millon, вот это -
millon писал(а):
08 ноя 2018, 15:08
Hard blocked: yes
означает, что карта выключена аппаратно. Кнопкой, их комбинацией или в БИОС. Тебе даже инструкцию по твоему ноуту дали.
Блютуз отключи сначала. Он включен вместо вафли -
millon писал(а):
08 ноя 2018, 15:08
hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
Да и не нужно Минт19 такому железу -
millon писал(а):
08 ноя 2018, 15:08
Устанавливай 17.3 + проприетарный драйвер АМД из Менеджера драйверов.
Карточка и так..., а на свободном radeon - вообще....
И с оставшимися
millon писал(а):
08 ноя 2018, 15:08
1607.6MB
тут и ДЕ нужно выкидывать, чтобы свободные мегабайты прибавить.
Callisto
Не работает WI-FI
08 ноя 2018, 18:55
та же проблема, почти такой же ноут HP650. Mind 19 со всеми обновлениями
все симптомы абсолютно идентичны. Хардблок и все.
vld_hp@HP650:~$ ifconfig -a
inet 192.168.0.102 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::3eb1:9749:8bcc:8860 prefixlen 64 scopeid 0x20<link>
ether b4:b5:2f:35:45:4c txqueuelen 1000 (Ethernet)
RX packets 22118 bytes 25576317 (25.5 MB)
TX packets 17124 bytes 1840343 (1.8 MB)
RX packets 1050 bytes 94578 (94.5 KB)
TX packets 1050 bytes 94578 (94.5 KB)
wlo1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 68:94:23:30:e8:99 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
Callisto
Не работает WI-FI
08 ноя 2018, 18:59
Unborn писал(а):
08 ноя 2018, 18:50
millon писал(а):
08 ноя 2018, 15:08
hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
видимо в другой теме инструкция? тут нет.
Не работает WI-FI
08 ноя 2018, 19:00
Callisto писал(а):
08 ноя 2018, 18:59
тут нет.
а это что Не работает WI-FI (Пост Bill Williamson #68332)
