System: Host: Whowka Kernel: 4.15.0-32-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara Machine: Device: desktop Mobo: Gigabyte model: G41M-ES2L v: x.x serial: N/A BIOS: Award v: F6 date: 11/04/2009 CPU: Quad core Intel Core2 Quad Q9400 (-MCP-) arch: Penryn rev.10 cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 21332 clock speeds: max: 2667 MHz 1: 1999 MHz 2: 2142 MHz 3: 2096 MHz 4: 1999 MHz Graphics: Card: NVIDIA G86 [GeForce 8500 GT] bus-ID: 01:00.0 Display Server: x11 (X.Org 1.19.6 ) drivers: nvidia (unloaded: modesetting,fbdev,vesa,nouveau) Resolution: 1280x1024@60.02hz OpenGL: renderer: N/A version: N/A Direct Render: N/A Audio: Card Intel NM10/ICH7 Family High Def. Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> Card-2: Ralink RT3060 Wireless 802.11n 1T/1R driver: rt2800pci v: 2.3.0 bus-ID: 04:01.0 IF: wlp4s1 state: down mac: <filter> Drives: HDD Total Size: 450.2GB (26.4% used) ID-1: /dev/sda model: WDC_WD1600JB size: 160.0GB ID-2: /dev/sdc model: ST3250312AS size: 250.1GB ID-3: /dev/sdb model: SAMSUNG_SP0411N size: 40.1GB Partition: ID-1: / size: 28G used: 8.1G (31%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 53G used: 15G (30%) fs: ext4 dev: /dev/sda6 ID-3: swap-1 size: 3.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda1 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 42.0C mobo: N/A gpu: 0.0:50C Fan Speeds (in rpm): cpu: 1584 mobo: 6026 Info: Processes: 178 Uptime: 7:47 Memory: 1689.1/3944.0MB Init: systemd runlevel: 5 Gcc sys: 7.3.0 Client: Shell (bash 4.4.191) inxi: 2.3.56
Gxneur, окно настроек.
Автор темы - Сообщения: 1899
- Решено: 13
У становил Gxneur из репозитория LM 19. В принципе, работает, но хотелось бы переназначить клавиши и исключить терминал из обрабатываемых приложений. При загрузке системы появляется флажок в панели на пару секунд и, если успеть на него нажать, то появляется контекстное меню (я даже пару раз успевал войти в "параметры" и увидеть окно настроек). Дальше, и значок, и окно пропадает. Пробовал прописать новую комбинацию в файл /etc/xneur/xneurrc — не переназначилось. Возможно ли из терминала вызвать окно настройки? Я так понимаю, что оно где-то в файлах существует, раз я его видел? И тот ли файл я пытался менять? В LM 17 в GXneur такого не было...
Решение
1 - а нужно ли это очередное виндозное поделие?
2 - из консоли надо вызывать не окно настроек, а саму софтину и смотреть что пишет во время краха.
Так же можно обратиться к логам и посмотреть что там на момент краха.
ЕМНИП, это основная ошибка, ставить надо отсюда: https://xneur.ru/ У меня на LMC19 все фурычит без проблем...
- Решено: 13
Dja, 1. если звёзды зажигают, значит это кому-то нужно?
И вопрос в догонку что такое "полки", и чем они полезны? Гугль внятного ответа не дал...
2. В логе загрузки от "user" (Как я понимаю, gxneur запускается уже от "user"( рабочий стол уже появляется)) только одна строчка: и, как я понимаю, краха нет, он стартовал и работает... Мож я не там ищу?
AlexelA,
В LM 17.3 gxneur из оф. репов работал , как швейцарские часы( относительно моих запросов)
И, я же видел графическое окно настроек... Оно существует в моём компе, но очень быстро исчезает, вместе с флагом в панели.
Whowka dbus-daemon[1347]: [session uid=1000 pid=1347] Activating service name='org.gnome.GConf' requested by ':1.39' (uid=1000 pid=2008 comm="gxneur " label="unconfined")
AlexelA,
ИМХО, в официальных репах версия, которая подогнана под установленную версию LM, или я в очередной раз заблуждаюсь?
И у меня фурычит. Но я не могу поменять комбинацию "Shift+Break" на более удобную (для меня) "Control+Super", и исключить терминал из списка обрабатываемых приложений.
- Решено: 19
Dja, краха, как такового, нет
Это, по идее, глобальные настройки программы. Если у тебя в хомяке есть такой же файл
xneurrc
или скрытый (с точкой в начале) .xneurrc
, то править надо в нем, т.к. он будет перебивать глобальные настройки. Если же нету, то и тот файл, что ты правишь - сойдет.Для проверки я у себя держу запасного пользователя (подсмотрел где-то такой совет и у меня это прижилось) на котором проверяю всякие теории, настройки. Также в нем играю в игры, собираю ядра (т.к. в хомяке запасного гораздо свободнее, основной же пользователь дюже замусорен) и т.п. Ну и на случай краха основного пользователяимею возможность попытаться зайти запасным.
Т.е. мое предложение заведи второго пользователя (gamer, destroyer, kernel) и посмотри, как в нем работает вожделенный джиикснеур.
Последний раз редактировалось пользователем 2 StarMAUGLI; всего редактировалось раз: 21
- Решено: 19
с чего ты взял, что поделие "виндозное"? Библиотеки линуксовые. Исходные коды доступны. Лицензия ГПЛ. Что тебе мешает воспринимать это приложение как линуксовое?
Ну давай все браузеры скопом, обзовем виндовзными, потому что где-то есть интернет эксплорер. Или все ФМ, потому что кто-то на планете пользует эксплорер. Или (замахнусь на святое) консоль, потому, что майкрософт в каждой своей сборке "командную строку" делает.
Ох, лисааа...
- Решено: 17
Всё верно. А то так можно договорится до того, что Windows - ось, Linux - ось. Значит Linux - это очередное виндозное поделие.StarMAUGLI писал(а): ↑21 окт 2018, 14:13с чего ты взял, что поделие "виндозное"? Библиотеки линуксовые. Исходные коды доступны. Лицензия ГПЛ. Что тебе мешает воспринимать это приложение как линуксовое?
- Решено: 13
StarMAUGLI Насчёт 2-го пользователя— спасибо! Я уже, как-то, стал забывать о вероятности краха...
ЕМНИП я нашёл, а "полки виндовз" мне показывает изделие из ДСП на стенку.(скока раз такие делал... Теперь буду заказчиков убивать фразой: "А давайте сюда сделаем "полки виндовз") Ну так это -же не те "полки"? Вдруг мне пригодятся?
Почему
Последний раз редактировалось пользователем 2 Whowka; всего редактировалось раз: 21
Введи в терминале
dpkg -L xneur
или dpkg -L gxneur
и увидишь, где лежат файлы...Для того, чтобы ничего не делать, надо уметь делать все! (©) (А.Лебедь)
- Решено: 13
AlexelA,
Увидел... Как я понимаю, настройки отображения значка в трее и графического меню прописаны в /usr/bin/xneur? Остальное там — библиотеки, маны, лицензии, словари, xneurrc и какой-то overrides. Если так, то там я вряд-ли разберусь...
НЯП, у тебя-то проблема не с настройками, а с самим GUI-ем, который не хочет быть юзер-френдли и схлопывается...
- Решено: 13
AlexelA,
Ну с настройками я пробовал ,но, кажись, сам косякнул... Не перезапустил после изменений... Попробую скопировать к себе и там поменять. Вот только не найду команду для перезапуска, xneur stop, restart не работают, только перезагрузка системы.
Через системный монитор...
- Решено: 13
Перепробовал разные варианты: создал файл xneurrc в home... На замену кнопок плюёт и перестаёт реагировать на кнопки "по умолчанию", в /etc ... зопа та-же:"Вид сбоку". Восстанавливаешь настройки в /etc..., через системный монитор перезапускаешь— фсё работает. Но ведь в LM 17.3 было по другому
И иконка в трее висела, и меню графическое было, и параметры менялись...
Ждать 19.1?
Ждать 19.1?
Whowka, я бы забил на это поделие, т.к. последняя версия была 2 года назад и с тех пор не обновлялась. Так что есть вероятность что обновились используемые этой поделкой библиотеки, а разарботчик ее не обновляет - вот и проблемы при использовании в новых дистрах. Так что хватит заниматься некромантией.
Как адвокат дьявола могу сказать, что сие поделие у меня исправно работало(ет) и на LMC 18.х, и на 19, и на LM XFCE...darkfenix писал(а): ↑22 окт 2018, 06:12я бы забил на это поделие, т.к. последняя версия была 2 года назад и с тех пор не обновлялась. Так что есть вероятность что обновились используемые этой поделкой библиотеки, а разарботчик ее не обновляет - вот и проблемы при использовании в новых дистрах. Так что хватит заниматься некромантией.
