Не работает wi-fi
gecsagen
Не работает wi-fi
30 сен 2018, 09:30
Привет всем!
Установил linux mint 19 (64 bit). Система
:~$ inxi -Fxz
System:    Host: gecsagen-HP-Laptop-15-ra0xx Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: HP product: HP Laptop 15-ra0xx v: Type1ProductConfigId serial: N/A
           Mobo: HP model: 832C v: 25.43 serial: N/A
           UEFI: Insyde v: F.37 date: 05/02/2018
Battery    BAT1: charge: 21.2 Wh 69.2% condition: 30.6/31.1 Wh (99%)
           model: COMPAL PABAS0241231 status: Discharging
CPU:       Dual core Intel Celeron N3060 (-MCP-)
           arch: Airmont rev.4 cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 6400
           clock speeds: max: 2480 MHz 1: 786 MHz 2: 2139 MHz
Graphics:  Card: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller
           bus-ID: 00:02.0
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (Braswell)
           version: 4.5 Mesa 18.0.5 Direct Render: Yes
Audio:     Card Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Realtek Device d723 port: 2000 bus-ID: 02:00.0
           IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 03:00.0
           IF: eno1 state: down mac: <filter>
Drives:    HDD Total Size: 500.1GB (1.9% used)
           ID-1: /dev/sda model: WDC_WD5000LPCX size: 500.1GB
Partition: ID-1: / size: 96G used: 8.6G (10%) fs: ext4 dev: /dev/sda8
Sensors:   System Temperatures: cpu: 49.0C mobo: 27.8C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 191 Uptime: 10:26 Memory: 1713.4/3851.0MB
Нажимаю внизу на значок сеть левой клавишей мыши и вижу картину, что адаптер отключен (скрин приложил).
Сделал вывод:
~$ rfkill list
2: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
До этого с ubuntu была такая же проблема но в выводе не было yes на поле soft blocked. Просто не работал wi-fi в итоге после долгих плясок с бубном проблема решилась.
Просьба помочь разобраться в этом. Спасибо!
gecsagen
Не работает wi-fi
30 сен 2018, 11:01
Вот еще вывод:
$ lspci -k | grep -iA3 net
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device d723
	Subsystem: Hewlett-Packard Company Device 8319
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Kernel driver in use: r8169
	Kernel modules: r8169
Не работает wi-fi
30 сен 2018, 14:01
gecsagen писал(а):
30 сен 2018, 09:30
Сделал вывод:
Тут он тебе про синезуб пишет.
Вот почитай тему
Собственно тебе сюда
Qurao
Не работает wi-fi
30 сен 2018, 14:07
Пробовал поставить rtl8812au, rtl8821au?
На гитхабе исходники вроде как есть.
У нас армия пингвинов - у вас груда стекла.
https://linux-hardware.org/?probe=10abe11ae2
