Добавить меню в Горячие уголы
Привет. Каким образом можно добавить меню Cinnamon в Горячие уголы, чтобы при навидении оно запускалось?
Linux Mint 19 "Tara" - Cinnamon (64-bit)
System: Host: server Kernel: 4.15.0-34-generic x86_64 bits: 64 gcc: 7.3.0
Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara
Machine: Device: laptop System: Acer product: Aspire A517-51G v: V1.12 serial: N/A
Mobo: KBL model: Dragonite_KL v: V1.12 serial: N/A UEFI: Insyde v: V1.12 date: 11/08/2017
Battery BAT1: charge: 50.1 Wh 100.0% condition: 50.1/48.9 Wh (102%) model: COMPAL PABAS0241231 status: Full
hidpp__0: charge: N/A condition: NA/NA Wh model: Logitech Wireless Mouse M560 status: Discharging
CPU: Quad core Intel Core i5-8250U (-MT-MCP-) arch: Kaby Lake rev.10 cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 14400
clock speeds: max: 3400 MHz 1: 900 MHz 2: 900 MHz 3: 900 MHz 4: 900 MHz 5: 900 MHz 6: 900 MHz
7: 900 MHz 8: 900 MHz
Graphics: Card-1: Intel UHD Graphics 620 bus-ID: 00:02.0
Card-2: NVIDIA GP108M [GeForce MX150] bus-ID: 01:00.0
Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting,nouveau (unloaded: fbdev,vesa)
Resolution: 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
version: 4.5 Mesa 18.0.5 Direct Render: Yes
Audio: Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
Sound: Advanced Linux Sound Architecture v: k4.15.0-34-generic
driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Card-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter driver: ath10k_pci bus-ID: 03:00.0
Drives: HDD Total Size: 1250.3GB (1.0% used)
ID-1: /dev/sda model: WDC_WD10SPZX size: 1000.2GB
ID-2: /dev/sdb model: Samsung_SSD_860 size: 250.1GB
Partition: ID-1: / size: 29G used: 11G (36%) fs: btrfs dev: /dev/sdb2
ID-2: /home size: 20G used: 1.4G (7%) fs: btrfs dev: /dev/sdb3
Sensors: System Temperatures: cpu: 50.0C mobo: 27.8C gpu: 36.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 301 Uptime: 35 min Memory: 1411.4/7851.1MB Init: systemd runlevel: 5 Gcc sys: 7.3.0
- Решено: 21
чтобы приложение указанное в горугле запускалось при наведении наверное надо в настройках указать чтобы запускалось при наведении. а чтобы запускалось циннамоновоменю то очевидно надо указать в настройках команду запуска этого меню (ну или возможно -команду на запуск скрипта ,открывающего меню)...Каким образом можно добавить меню Cinnamon в Горячие уголы, чтобы при навидении оно запускалось?
а вот найти какой командой его можно запустить... вот это вопрос.
Пару лет назад на старом форуме аналогичный вопрос задавался в теме - http://mintlinux.ru/forum/thread12286.html
решения там не озвучено но есть варианты направлений для решения...
Чуть позже обсуждалось подобное и здесь - Восстановление окна терминала из Горячих углов Но там несколько другое направление.
Погодь... А наведение на значёк меню без клика не спасёт отца русской демократии? По сути - равнозначные действия
- Решено: 21
была мысля такая же ,но вопрос был про горячий угол
а в приципе ... почему бы и нет? и апплет на панелях в любой из 4-х углов засунуть можно , но апплет привязан к панельке, а ТС-у может быть не нужна там панель.
ну и ещё как вариант ... запускать через горячий угол не циннамоново меню, а какое другое альтернативное , кайрудок например, или чего попроще типа wbar
Я хочу убрать панель полностьюdi_mok писал(а): ↑29 сен 2018, 19:30Чуть позже обсуждалось подобное и здесь - Восстановление окна терминала из Горячих углов Но там несколько другое направление.
Думал об этом, и даже делал. Просто это какой-то как костыль, а поэтому хотелось именно родноеcolonel писал(а): ↑29 сен 2018, 19:51была мысля такая же ,но вопрос был про горячий угол
- Решено: 21
родное - это настройка открытия меню при " наведении на значёк меню без клика"
Кастомизация должна же быть. Как-то меню же запускается. Наверняка это команда
aptitud, не знаю как там в пресловутой корице, в крысе
возможно стоит поискать что-то вроде
в вашем случае apt search menu и там будет что-то типа cinnamon-menu или что-то в этом духе.
Ну и элементарно... на клавише Win - меню. Идем в параметры - клавиатура - сочетания и смотрим какая команда закреплена за левой Win.
Если в корице нет "сочетания", то вообще непонятно для кого её пилят и что курят когда пилят.
xfce4-popup-whiskermenu
dja-laptop ~ $ apt search whisker i xfce4-whiskermenu-plugin - Alternate Xfce menu
- Решено: 21
любезный , видать сказанное в #3 в одно влетело в другое вылетело и прошло мимо ... или вы не удосужились посмотреть по ссылке
повторяю, "Пару лет назад на старом форуме аналогичный вопрос задавался в теме - http://mintlinux.ru/forum/thread12286.html
решения там не озвучено но есть варианты направлений для решения... "
про то что в крысе имеется и что искать в корице что-то вроде сказано пару лет назад- и напомнено в #3
- "чтобы запускалось циннамоновоменю то очевидно надо указать в настройках команду запуска этого меню (ну или возможно -команду на запуск скрипта ,открывающего меню) "
и если нет прямой команды - то как варианты - или "писать скрипт для взаимодействия с апплетом через вызов его команд"
или в скрипт вкатить команду терминала эмулирующую нажатие горячих клавиш назначенных для открытия меню.
ну как это нет сочетания ..? есть и в настройках несложно может быть назначено , переназначено , отключено ... но вот с показом прямой команды запуска меню вроде посложнее.
- Решено: 217
Что-то мне подсказывает что там моё сообщение
Сперва хотел тут предлжить эмуляцию клавиши Super, как первый вариант пришедший в голову потом глянул по ссылке и увидел примерно тот же текст, что вертится в голове
Ну а чтоб завершить мысль:
xdotool key Super
Любезный, зачем этот костыль? Для того чтобы открыть меню нужно писать скрипт? Вы все проблемы таким образом решаете? «Keep it simple, stupid».
Я делал так. Видимо, придётся остановиться на этом решении. Я думал, что команда запуска меню известна всем, кроме меня, а тут эво как
- Решено: 21
очень даже может быть так
просто помню что аналогичный вопрос был на старом форуме ...
помнится было время когда менюшку можно было просто вызвать командом гноме-меню , а сейчас главное меню гномовое толи то выпилили из тригнома толи из цмона. в мате форк этого меню присутствует (главное меню мате) хоть апплет ставь на панель, хоть хоткеем( по дефолту альт+Ф1) вызывай. но вот командой запустить тож засада
варианты эмуляций ещё имеются , но согласен что иксдотуловый вариант и прост , да и вроде по дефолту в системе есть
то как я решаю свои проблемы вас не касается.
проблемы не у меня а у вас , вы спрашивали - вам ответили что можно сделать для решения.
не нравится не ешьте. делать или не делать ваше дело . можете писать скрипт, можете не писать( вас насильно никто не заставляет), а просто вставить иксдотуловую команду эмуляции в настройки горячих углов. это не принципиально и это всё тот же костыль - вид сбоку (но до вас кажется это ещё не дошло )
Сейчас этот форум просматривают: Google [Bot] и 0 гостей
