Установка драйвера на Radeon R9 380X
nightpatrol
Благодарил (а): 11 раз
23 авг 2018, 17:26
Подскажите пожалуйста, как установить драйвер на видеокарту Radeon R9 380X в Linux Mint 19, ядро 4.15
nightpatrol
23 авг 2018, 17:29
night@nightpatrol:~$ inxi -Fxz
System:    Host: nightpatrol Kernel: 4.15.0-32-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: desktop Mobo: ASUSTeK model: PRIME Z270-K v: Rev X.0x serial: N/A
           UEFI: American Megatrends v: 1207 date: 06/22/2018
CPU:       Quad core Intel Core i7-7700 (-MT-MCP-)
           arch: Skylake rev.9 cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 28800
           clock speeds: max: 4200 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz
           4: 800 MHz 5: 800 MHz 6: 800 MHz 7: 800 MHz 8: 800 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Tonga XT / Amethyst XT [Radeon R9 380X / R9 M295X]
           bus-ID: 01:00.0
           drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa,radeon)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: AMD Radeon R9 380 Series (TONGA / DRM 3.23.0 / 4.15.0-32-generic, LLVM 6.0.0)
           version: 4.5 Mesa 18.0.5 Direct Render: Yes
Audio:     Card-1 Intel 200 Series PCH HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3
           Card-2 Advanced Micro Devices [AMD/ATI] Tonga HDMI Audio [Radeon R9 285/380]
           Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic
Network:   Card-1: Intel Ethernet Connection (2) I219-V
           driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: down mac: <filter>
           Card-2: Realtek RTL8812AU 802.11a/b/g/n/ac WLAN Adapter
           usb-ID: 003-004
           IF: N/A state: N/A mac: N/A
Drives:    HDD Total Size: 1256.3GB (2.5% used)
           ID-1: /dev/sda model: TS256GSSD370S size: 256.1GB
           ID-2: /dev/sdb model: ST1000DM003 size: 1000.2GB
Partition: ID-1: / size: 41G used: 12G (28%) fs: btrfs dev: /dev/sda5
           ID-2: /home size: 99G used: 9.2G (10%) fs: btrfs dev: /dev/sdb6
           ID-3: swap-1 size: 10.00GB used: 0.00GB (0%)
           fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 55.0
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 322 Uptime: 1:04 Memory: 2449.6/7919.0MB
nightpatrol
23 авг 2018, 18:36
нашёл решение на англоязычном форуме. Как тут спойлеры делать? В упор не вижу этот тег :sad:
I've been looking for a statement by AMD to verify that but still haven't found one, so you will be testing an installation that may fail, but first change the word linuxmint back to ubuntu in the amdgpu-pro-install script. I’ll explain why later. I recommend a new installation. Otherwise, there will probably be an error message about unmet dependencies when you attempt a second installation. Use this command to try to fix that: sudo apt install --fix-broken
With the release of the Radeon Software for Linux 18.30 package, AMD has added another obstacle to the installation for Mint users who want to install the AMDGPU-Pro driver. With previous versions, the amdgpu-pro-install script was edited by changing the word ubuntu to linuxmint. That won’t work with the newest version. After the installation, if you view the installer log in the Terminal window, you will probably see these 3 lines at the end
Errors were encountered while processing:
/tmp/apt-dpkg-install-VlDLjr/08-amdgpu-core_18.30-633530_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1
Looking deeper in the log, you will see these lines
ERROR: This package can only be installed on Ubuntu 18.04.
dpkg: error processing archive /tmp/apt-dpkg-install-VlDLjr/08-amdgpu-core_18.30-633530_all.deb (--unpack):
new amdgpu-core package pre-installation script subprocess returned error exit status 1
If the amdgpu-pro-18.30-633530.tar.xz package is extracted and then the amdgpu-core_18.30-633530_all.deb package within it is extracted and then the control.tar.xz package within it is extracted, then the preinst script can be viewed
CODE: SELECT ALL
#!/bin/bash
set -e
. /etc/os-release
if [ "$VERSION_ID" != "18.04" ] ; then
>&2 echo "ERROR: This package can only be installed on Ubuntu 18.04."
exit 1
fi
exit 0
This script will run before the amdgpu-core package is installed. It checks in the system’s /etc/os-release file for a VERSION_ID="18.04" line, which is the latest version of Ubuntu. If that is not found, then the amdgpu-core package will not be installed, the error message will be seen in the installer log and the installation will fail.
The solution I found is to edit the /etc/os-release file. Use this command to open itxed admin:///etc/os-release
CODE: SELECT ALL
NAME="Linux Mint"
VERSION="19 (Tara)"
ID=linuxmint
ID_LIKE=ubuntu
PRETTY_NAME="Linux Mint 19"
VERSION_ID="19"
HOME_URL="https://www.linuxmint.com/"
SUPPORT_URL="https://forums.ubuntu.com/"
BUG_REPORT_URL="http://linuxmint-troubleshooting-guide. ... en/latest/"
PRIVACY_POLICY_URL="https://www.linuxmint.com/"
VERSION_CODENAME=tara
UBUNTU_CODENAME=bionic
Change the word linuxmint to ubuntu in line 3 and change the number 19 to 18.04 in line 6. After the installation, you can change these back. The amdgpu-pro-install script does not have to be edited.
Proceed with the installation by right clicking on the downloaded amdgpu-pro-18.30-633530.tar.xz package and selecting Extract Here. Open the amdgpu-pro18.30-633530 folder. Right click in the empty space and select Open in Terminal. Use the command ./amdgpu-pro-install
If you also want to install the OpenCL component, then use this command for Vega10 and newer cards:
./amdgpu-pro-install --opencl=pal
Or this command for Pre Vega10 cards: ./amdgpu-pro-install --opencl=legacy
Reboot
iVTEC
22 окт 2018, 09:48
вы ставили проприетарный драйвер для чего если не секрет? монитор при запуске системы уходил в сон или какая то другая причина?
Вернуться в «Видеокарты»
