Как сделать кастомные уведомления на python 3 linux?
L0sted mind
Благодарил (а): 6 раз
#21
11 апр 2018, 20:54
11 апр 2018, 20:18
попробуй для начала разрулить конфликты
pip3 install dbus
Нет такой библиотеки
losted_mind@losted-mind-G41M-ES2L ~ $ sudo -H pip3 install dbus
Collecting dbus
  Could not find a version that satisfies the requirement dbus (from versions: )
No matching distribution found for dbus
но после пол минуты гугла я нашёл что надо писать не 'dbus' а 'dbus-python'... но всё равно это не дало ни каких результатов
losted_mind@losted-mind-G41M-ES2L ~ $ sudo pip3 install dbus-python
The directory '/home/losted_mind/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/losted_mind/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting dbus-python
  Downloading dbus-python-1.2.4.tar.gz (612kB)
    100% |████████████████████████████████| 614kB 957kB/s
Installing collected packages: dbus-python
  Running setup.py install for dbus-python ... error
    Complete output from command /usr/bin/python3.6 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-5vl_b0nb/dbus-python/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-zih7md2k-record/install-record.txt --single-version-externally-managed --compile:
    running install
    running build
    creating /tmp/pip-build-5vl_b0nb/dbus-python/build
    creating /tmp/pip-build-5vl_b0nb/dbus-python/build/temp.linux-x86_64-3.6
    checking whether make supports nested variables... yes
    checking whether to enable maintainer-specific portions of Makefiles... no
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking whether UID '0' is supported by ustar format... yes
    checking whether GID '0' is supported by ustar format... yes
    checking how to create a ustar tar archive... gnutar
    checking build system type... x86_64-pc-linux-gnu
    checking host system type... x86_64-pc-linux-gnu
    checking for native Windows host... no
    checking how to print strings... printf
    checking for style of include used by make... GNU
    checking for gcc... gcc
    checking whether the C compiler works... yes
    checking for C compiler default output file name... a.out
    checking for suffix of executables...
    checking whether we are cross compiling... no
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for gcc option to accept ISO C89... none needed
    checking whether gcc understands -c and -o together... yes
    checking dependency style of gcc... gcc3
    checking for a sed that does not truncate output... /bin/sed
    checking for grep that handles long lines and -e... /bin/grep
    checking for egrep... /bin/grep -E
    checking for fgrep... /bin/grep -F
    checking for ld used by gcc... /usr/bin/ld
    checking if the linker (/usr/bin/ld) is GNU ld... yes
    checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
    checking the name lister (/usr/bin/nm -B) interface... BSD nm
    checking whether ln -s works... yes
    checking the maximum length of command line arguments... 1572864
    checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
    checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
    checking for /usr/bin/ld option to reload object files... -r
    checking for objdump... objdump
    checking how to recognize dependent libraries... pass_all
    checking for dlltool... no
    checking how to associate runtime and link libraries... printf %s\n
    checking for ar... ar
    checking for archiver @FILE support... @
    checking for strip... strip
    checking for ranlib... ranlib
    checking command to parse /usr/bin/nm -B output from gcc object... ok
    checking for sysroot... no
    checking for a working dd... /bin/dd
    checking how to truncate binary pipes... /bin/dd bs=4096 count=1
    checking for mt... mt
    checking if mt is a manifest tool... no
    checking how to run the C preprocessor... gcc -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking for dlfcn.h... yes
    checking for objdir... .libs
    checking if gcc supports -fno-rtti -fno-exceptions... no
    checking for gcc option to produce PIC... -fPIC -DPIC
    checking if gcc PIC flag -fPIC -DPIC works... yes
    checking if gcc static flag -static works... yes
    checking if gcc supports -c -o file.o... yes
    checking if gcc supports -c -o file.o... (cached) yes
    checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
    checking whether -lc should be explicitly linked in... no
    checking dynamic linker characteristics... GNU/Linux ld.so
    checking how to hardcode library paths into programs... immediate
    checking whether stripping libraries is possible... yes
    checking if libtool supports shared libraries... yes
    checking whether to build shared libraries... yes
    checking whether to build static libraries... no
    checking for inline... inline
    checking whether /usr/bin/python3.6 version is >= 2.6... yes
    checking for /usr/bin/python3.6 version... 3.6
    checking for /usr/bin/python3.6 platform... linux
    checking for /usr/bin/python3.6 script directory... ${prefix}/lib/python3.6/site-packages
    checking for /usr/bin/python3.6 extension module directory... ${exec_prefix}/lib/python3.6/site-packages
    checking for python3.6-config... no
    checking for python-config... no
    configure: error: cannot find python3.6-config or python-config in PATH
    Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-5vl_b0nb/dbus-python/setup.py", line 106, in <module>
        'build_ext': BuildExt,
      File "/usr/local/lib/python3.6/dist-packages/setuptools/__init__.py", line 129, in setup
        return distutils.core.setup(**attrs)
      File "/usr/lib/python3.6/distutils/core.py", line 148, in setup
        dist.run_commands()
      File "/usr/lib/python3.6/distutils/dist.py", line 955, in run_commands
        self.run_command(cmd)
      File "/usr/lib/python3.6/distutils/dist.py", line 974, in run_command
        cmd_obj.run()
      File "/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/lib/python3.6/distutils/command/install.py", line 589, in run
        self.run_command('build')
      File "/usr/lib/python3.6/distutils/cmd.py", line 313, in run_command
        self.distribution.run_command(command)
        cmd_obj.run()
      File "/tmp/pip-build-5vl_b0nb/dbus-python/setup.py", line 62, in run
        cwd=builddir)
      File "/usr/lib/python3.6/subprocess.py", line 291, in check_call
        raise CalledProcessError(retcode, cmd)
    subprocess.CalledProcessError: Command '['/tmp/pip-build-5vl_b0nb/dbus-python/configure', '--disable-maintainer-mode', 'PYTHON=/usr/bin/python3.6', '--prefix=/tmp/pip-build-5vl_b0nb/dbus-python/build/temp.linux-x86_64-3.6/prefix']' returned non-zero exit status 1.
    Error in sys.excepthook:
      File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
        from apport.fileutils import likely_packaged, get_recent_crashes
      File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
        from apport.report import Report
      File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module>
        import apport.fileutils
      File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module>
        from apport.packaging_impl import impl as packaging
      File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 23, in <module>
        import apt
      File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module>
        import apt_pkg
    ModuleNotFoundError: No module named 'apt_pkg'
    Original exception was:
        dist.run_commands()
        cmd_obj.run()
        cmd_obj.run()
        cwd=builddir)
Command "/usr/bin/python3.6 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-5vl_b0nb/dbus-python/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-zih7md2k-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-5vl_b0nb/dbus-python/
#22
11 апр 2018, 21:36
Опять же дефицит :)
L0sted mind писал(а):
11 апр 2018, 20:54
Давай чтоль сравним с дефолтным списком модулей из базовой поставки 18.3
$ pip3 list
apt-clone (0.2.1)
apt-xapian-index (0.47)
apturl (0.5.2)
blinker (1.3)
Brlapi (0.6.4)
chardet (2.3.0)
command-not-found (0.3)
cryptography (1.2.3)
defer (1.0.6)
dirspec (13.10)
httplib2 (0.9.1)
idna (2.0)
louis (2.6.4)
lxml (3.5.0)
Mako (1.0.3)
MarkupSafe (0.23)
oauthlib (1.0.3)
onboard (1.2.0)
oneconf (0.3.9)
pexpect (4.0.1)
Pillow (3.1.2)
pip (8.1.1)
piston-mini-client (0.7.5)
psutil (3.4.2)
ptyprocess (0.5)
pyasn1 (0.1.9)
pycrypto (2.6.1)
pycups (1.9.73)
pycurl (7.43.0)
pygobject (3.20.0)
PyICU (1.9.2)
PyJWT (1.3.0)
python-apt (1.1.0b1)   #apt_pkg живет тут
python-debian (0.1.27)
python-xapp (1.0.0)
pyxdg (0.25)
reportlab (3.3.0)
requests (2.9.1)
sessioninstaller (0.0.0)
setproctitle (1.1.8)
six (1.10.0)
system-service (0.3)
thin-client-config-agent (0.8)
ubuntu-drivers-common (0.0.0)
ufw (0.35)
urllib3 (1.13.1)
virtkey (0.63.0)
xkit (0.0.0)
