Chromium долгий запуск
broken
Благодарил (а): 21 раз
07 апр 2018, 00:37
С недавнего времени заметил, что Chromium стал медленно открываться.
От машины не зависит, поскольку на двух разных машинах (комп и ноут) наблюдается одно и то же (медленный запуск).
Запуск в консоли.
$ chromium-browser
Using PPAPI flash.
--disable-new-tab-first-run --enable-user-scripts --ppapi-flash-path=/usr/lib/adobe-flashplugin/libpepflashplayer.so --ppapi-flash-version=
ATTENTION: default value of option force_s3tc_enable overridden by environment.
[6213:6213:0406/202026.531632:ERROR:sandbox_linux.cc(375)] InitializeSandbox() called with multiple threads in process gpu-process.
[1:17:0406/202029.042948:ERROR:adm_helpers.cc(73)] Failed to query stereo recording.
[6155:6197:0406/202039.844804:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[6155:6197:0406/202040.109166:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[6155:6197:0406/202040.134242:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[6155:6197:0406/202040.737755:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[6213:6213:0406/202318.042983:ERROR:gles2_cmd_decoder.cc(18268)] [.DisplayCompositor-0x55c50d4f5b40]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
[6213:6213:0406/202318.043359:ERROR:gles2_cmd_decoder.cc(10094)] [.DisplayCompositor-0x55c50d4f5b40]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
[6213:6213:0406/202318.043788:ERROR:gles2_cmd_decoder.cc(18268)] [.DisplayCompositor-0x55c50d4f5b40]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
[6213:6213:0406/202318.043894:ERROR:gles2_cmd_decoder.cc(10094)] [.DisplayCompositor-0x55c50d4f5b40]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
$ chromium-browser
Using PPAPI flash.
Вот здесь была пауза секунд в 30. Не меньше.
Фразу ATTENTION: default value of option force_s3tc_enable overridden by environment. гугл перевел как ВНИМАНИЕ: значение по умолчанию параметра force_s3tc_enable переопределяется средой. Вроде ничего криминального.
А вот дальше он ругается на какие-то презентеры и майлбоксы.
      Запуск в сессии нового пользователя еще не пробовал.
Я один такой невезучий? Или имеются те, у кого такая же трабла? Может с обновами прилетело...
Real
07 апр 2018, 01:32
Извините за возможный оффтоп, но ИМХО это может быть полезно про хром/хромиум в любом случае https://geektimes.ru/post/299633/
BadBird
Благодарил (а): 175 раз
07 апр 2018, 01:39
Real писал(а):
07 апр 2018, 01:32
полезно
Выкладывал я тут:
В Ubuntu 18.04 ожидается отправка сведений о системе и режим минимальной установки
Хотя лично мне побоку на это...
broken
07 апр 2018, 01:43
Real, да вроде жутких тормозов не замечал. Да и повторное открывание происходит быстро. Это лишь первое открывание после релогина так долго.
А кто знает что означают эти сиси?
sandbox_linux.cc
07 апр 2018, 08:05
broken, довольно быстро запускается. Ну и вот чего в терминале ругается
darkfenix@darkfenix  ~  chromium-browser
Using PPAPI flash.
[6170:6213:0407/100410.267660:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[6170:6213:0407/100411.523593:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[6170:6213:0407/100411.847271:ERROR:upload_data_presenter.cc(73)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
Может какие дополнения у тебя его так загибают?
broken
08 апр 2018, 13:07
Вобщем это бага какая-то. Сейчас у меня примерно так же :-D
broken
08 апр 2018, 13:42
darkfenix, в любом случае он срет ошибками даже у тебя. Это напрягает, к сожалению :sad:
broken
08 апр 2018, 18:38
$ /usr/bin/google-chrome-stable
так же пауза 40 секунд
[3272:3272:0408/183440.359349:ERROR:sandbox_linux.cc(375)] InitializeSandbox() called with multiple threads in process gpu-process.
[3220:3220:0408/183445.351158:ERROR:navigation_entry_screenshot_manager.cc(135)] Invalid entry with unique id: 1
Стало быть не в хромиуме дело :sad:
broken
08 апр 2018, 18:50
ушел на opera. :close:
broken
08 апр 2018, 20:01
Это смешно, но
$ opera
всё те же 40 секунд...
[3475:3519:0408/195509.643187:ERROR:in_progress_cache_impl.cc(93)] Could not read download entries from file because there was a read failure.
[3547:3547:0408/195509.804524:ERROR:sandbox_linux.cc(375)] InitializeSandbox() called with multiple threads in process gpu-process.
А эту строку помню в хромиуме была... (сверху над этой)
[3475:3475:0408/195509.906005:ERROR:input_translator_internal.cc(272)] Wrong definition of keybinding.
[1:16:0408/195511.243268:ERROR:adm_helpers.cc(73)] Failed to query stereo recording.
Это что за приколы? :crazy: Пока адекватно себя ведет один FireFox.
Это я чего-то с движком напортачил что у меня хромоподобии хромают?
System:    Host: homer Kernel: 4.13.0-37-generic x86_64 (64 bit gcc: 5.4.0) Desktop: Xfce 4.12.3 (Gtk 2.24.28)
Machine:   Mobo: ASUSTeK model: P5G41T-M LX v: Rev X.0x Bios: American Megatrends v: 0404 date: 01/06/2010
CPU:       Quad core Intel Core2 Quad Q8200 (-MCP-) cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4_1 ssse3) bmips: 18666
           clock speeds: max: 2336 MHz 1: 2003 MHz 2: 2003 MHz 3: 2003 MHz 4: 2336 MHz
Graphics:  Card: NVIDIA GT216 [GeForce GT 220] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz, 1280x1024@60.02hz
           GLX Renderer: NVA5 GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
Audio:     Card-1 Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 NVIDIA GT216 HDMI Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           Sound: Advanced Linux Sound Architecture v: k4.13.0-37-generic
Network:   Card: Qualcomm Atheros AR8131 Gigabit Ethernet
           driver: atl1c v: 1.0.1.1-NAPI port: ec00 bus-ID: 02:00.0
Drives:    HDD Total Size: 1060.2GB (72.4% used) ID-1: /dev/sda model: KINGSTON_SKC300S size: 60.0GB
           ID-2: /dev/sdb model: ST1000DM003 size: 1000.2GB
Partition: ID-1: / size: 20G used: 13G (69%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 36G used: 12G (34%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 37.0C mobo: 37.0C
           Fan Speeds (in rpm): cpu: 2177 sys-1: 1442
Info:      Processes: 205 Uptime: 6 min Memory: 1233.4/7976.8MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
4.13.0-37-generic
zen
08 апр 2018, 20:21
попробуй запустить из терминала с флагом
chromium --disable-gpu
Ктулху
Благодарил (а): 19 раз
08 апр 2018, 20:41
Дело в Линукс Минте, разработчики знают об этом. Это проблемы не только с Хромиумом, а со многими программами. В следующем обновлении вроде как уже не будет таких проблем, работают над этим
08 апр 2018, 22:55
09 апр 2018, 01:38
Real писал(а):
07 апр 2018, 01:32
Вот только не надо мешать в кучу. Статья не относится к Chromium. Только к Chrome. Первый - имеет открытые исходники, и разрабатывается сообществом. А вот Хром - гугловская разработка на основе Хромиума, закрытая и с добавками своего кода.
Такая хрень в Хромиуме не получится - исходники открыты. Во всяком случае, там не пришлось бы гадать что и как работает.
Real
09 апр 2018, 01:57
09 апр 2018, 01:38
да-да-конечно, ожидаемый комментарий (в розовых очках) - https://geektimes.ru/post/299633/#comment_10701739
09 апр 2018, 12:46
Real писал(а):
09 апр 2018, 01:57
https://chromium.googlesource.com/chrom ... uctions.md
Объясните, как при наличии исходного кода, можно вообще гадать о том, что там есть а чего нету? За исключением случая, с отсутствием компетенции в вопросе?
Обращаю ваше внимание: я НЕ заявляю, что хромиум не связывается с серверами гугла, и не взаимодействует с ними. Там есть определенное взаимодействие. Но вот что именно, и как именно происходит, может посмотреть в исходниках любой желающий. Так что ситуация описанная по первой вашей ссылке (внезапно выяснилось...) в хромиуме невозможна - там о подобном добавлении функционала станет известно сразу любому интересующемуся. И есть возможность разобраться что именно добавлено.
Разница между этими броузерами не в том, что хромуиум вообще не "следит", а в том, что тут правила этой игры четко известны, и не могут быть скрытно изменены в одностороннем порядке.
broken
09 апр 2018, 13:47
Real, slant, нук не ругаться :evil: Вы не братья случаем? :crazy: Всю дорогу в какой бы теме ни пересекались без подковырок друг друга не обходитесь :write:
Я, вобщем, так и пологал, что минт виноват, ибо с моей то стороны никаких шаманств не было. Стало быть после какой-то обновы и прилетело. Почему я и не люблю обновляться :hm: Но на иногда тоже бывают редкие косяки, видимо. Подождем...
Real, slant флейм в личку :order:
Вернуться в «Работа с сетью»
