При обновлении получаю ошибку
Модератор: WWolf
Roman1105
#61
04 апр 2018, 11:51
03 апр 2018, 18:42
запустить winecfg и поставить в настройках WinXp - каждый раз нужно напоминать?
Это я делаю на автомате!!!
03 апр 2018, 18:42
Покажи inxi -r
Да вот :
s-klad@sklad-Lenovo-ideapad-110-15IBR ~ $ winecfg
s-klad@sklad-Lenovo-ideapad-110-15IBR ~ $ inxi -r
Repos: Active apt sources in file: /etc/apt/sources.list.d/additional-repositories.list
deb https://dl.winehq.org/wine-builds/ubuntu/ xenial main
Active apt sources in file: /etc/apt/sources.list.d/google-chrome.list
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
Active apt sources in file: /etc/apt/sources.list.d/noobslab-apps-xenial.list
deb http://ppa.launchpad.net/noobslab/apps/ubuntu xenial main
deb-src http://ppa.launchpad.net/noobslab/apps/ubuntu xenial main
Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
deb http://packages.linuxmint.com sylvia main upstream import backport #id:linuxmint_main
deb http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ xenial-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu/ xenial partner
Active apt sources in file: /etc/apt/sources.list.d/oibaf-graphics-drivers-xenial.list
deb http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu xenial main
deb-src http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu xenial main
Active apt sources in file: /etc/apt/sources.list.d/steam.list
deb [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
deb-src [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
#62
04 апр 2018, 12:00
Roman1105 писал(а):
04 апр 2018, 11:51
Открыть файл sudo любимый_редактор /etc/apt/sources.list.d/additional-repositories.list и оставить только одну строчку из 5, т.к. они идентичны.
Roman1105 писал(а):
04 апр 2018, 11:51
Это вообще для Ubuntu 12.04. Вместо precise должно быть xenial (Давно стимом не баловался, если я не прав поправьте знающие)
Вроде больше ничего криминального не вижу
Roman1105
#63
04 апр 2018, 12:32
04 апр 2018, 12:00
Тут оставил Первую строку остальные удалил
04 апр 2018, 12:00
Тут заменил precise на xenial
пробую запустить !
Roman1105
#64
04 апр 2018, 12:35
Не Работает получаю критическую ошибку
и установка не идет дальше. winecfg - тут стоит Win Xp
Roman1105
#65
04 апр 2018, 12:52
darkfenix,
Все проверил но ни с сайта гугл не устанавливаеться ни с файла который тут выше дали
29 мар 2018, 16:35
Решено Пожаловаться на это сообщение Цитата Поблагодарить #34 Сообщение Chocobo » 29 мар 2018, 16:35
Roman1105, попробуй лучше вот этот инсталлер
https://dl.google.com/dl/adwords_editor ... editor.msi
и в winecfg выставь WinXP
не хочет работать.
Если пробую скачаный с Гугла то при установке пишет сто нет интернета (хотя он есть и не куда не пропадал ) , а с файла полученный тут пишет критическая ошибка и просто закрывается.
Что еще не так ему???
Roman1105
#66
04 апр 2018, 13:05
Roman1105 писал(а):
04 апр 2018, 12:52
darkfenix,
А вот еще !!!
Я исправил как вы и сказали
04 апр 2018, 12:00
Roman1105 писал(а): ↑Сегодня, 11:51
обратил внимание что на менеджере обновлений показывает ошибку нажал попробовал проверить обновления и получил вот такое - Скрин
#67
04 апр 2018, 13:31
Roman1105 писал(а):
04 апр 2018, 13:05
Так я же написал что не уверен что для репы стима нужно это делать. Верни как было, они действительно такой реп используют
Roman1105
#68
04 апр 2018, 14:16
04 апр 2018, 13:31
Вернул все назад
А что по Вайну что там можно сделать чтоб он заработал???
а то но так и не заводится
Roman1105
#69
04 апр 2018, 16:54
svtv1 писал(а):
03 апр 2018, 01:24
Попробуй так (в файловом менеджере) показать скрытые файло, удали папку wine и ещё там же, в скрытых файло local-share-applications. Удали от туда весь wine, ну а потом заново установи .
Удачи.
Уже наверно все перепробовал удалял -ставил пробовал разные варианты но не как не получается установить и запустить работу WINE - Что я не так делаю????? :dash2: :dash2:
svtv1
Благодарил (а): 39 раз
#70
04 апр 2018, 17:43
А так пробовал:
sudo apt-get --fix-broken install
sudo rm /var/lib/apt/lists/* -vf
sudo apt-get clean
sudo apt-get update
sudo apt-get autoclean
sudo apt-get autoremove
Ну а дальше попробуй установи. (после этих команд хуже не будет).
Roman1105
#71
04 апр 2018, 18:10
svtv1 писал(а):
04 апр 2018, 17:43
А так пробовал:
sudo apt-get clean
sudo apt-get update
ввел все команды но ни чего не помогло Скрин
Попробовал поставить вот эту оболочку https://losst.ru/ustanovka-programm-che ... winewizard
но она не помогла ни как Скрин
Пишет что нет интернета хотя все есть :dash2:
svtv1
#72
04 апр 2018, 18:33
reboot пробовал?
Roman1105
#73
05 апр 2018, 14:48
svtv1 писал(а):
04 апр 2018, 18:33
reboot пробовал?
Нет не делал. Так еще ни разу если подскажете как то сделаю
Вернуться в «Wine»
