Огромное контекстное меню
samplitude
18 мар 2018, 08:01
Добрый всем день! В некоторых приложениях стало просто огромное меню (в терминале, в XViewer) см. скрины. ОС Linux Mint 18.1 Serena Mate. Проявилось вроде после установки nvidia-settings. Если в Nvidia-Prime переключать карту с Intel на Nvidia все также большое. Как же починить?
Скриншоты:
No LSB modules are available.
Distributor ID:	LinuxMint
Description:	Linux Mint 18.1 Serena
Release:	18.1
Codename:	serena
Железо:
System: Host: dexp-w56 Kernel: 4.13.16-041316-generic x86_64 (64 bit gcc: 7.2.0)
Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.1)
Distro: Linux Mint 18.1 Serena
Machine: System: Notebook (portable) product: W65_67SF
Mobo: Notebook model: W65_67SF
Bios: American Megatrends v: 1.03.04 date: 08/25/2014
CPU: Dual core Intel Core i5-4200M (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9976
clock speeds: max: 3100 MHz 1: 2494 MHz 2: 2494 MHz 3: 2494 MHz
4: 2494 MHz
Graphics: Card-1: Intel 4th Gen Core Processor Integrated Graphics Controller
bus-ID: 00:02.0
Card-2: NVIDIA GM108M [GeForce 840M] bus-ID: 01:00.0
Resolution: 1366x768@60.00hz
GLX Renderer: Mesa DRI Intel Haswell Mobile
GLX Version: 3.0 Mesa 17.4.0-devel - padoka PPA Direct Rendering: Yes
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
driver: snd_hda_intel bus-ID: 00:03.0
Sound: ALSA v: k4.13.16-041316-generic
Network: Card-1: Realtek RTL8723BE PCIe Wireless Network Adapter
driver: rtl8723be port: d000 bus-ID: 03:00.0
driver: r8169 v: 2.3LK-NAPI port: c000 bus-ID: 04:00.2
IF: enp4s0f2 state: down mac: <filter>
Drives: HDD Total Size: 500.1GB (53.5% used)
ID-1: /dev/sda model: HGST_HTS545050A7 size: 500.1GB
Partition: ID-1: / size: 30G used: 7.0G (25%) fs: ext4 dev: /dev/sda7
ID-2: /home size: 308G used: 240G (82%) fs: ext4 dev: /dev/sda5
ID-3: swap-1 size: 3.22GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
Sensors: System Temperatures: cpu: 56.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 197 Uptime: 2:00 Memory: 1081.3/3833.0MB
Client: Shell (bash 4.3.461) inxi: 2.2.35
Проблему решил:
Это все было из-за значков Colored-Plastic которые я установил с noobslab. Поменял значки в теме - все исправилось.
18 мар 2018, 08:59
samplitude, а на дефолтном стиле так-же?
samplitude
18 мар 2018, 09:31
Да, di_mok, на любой из тем, если ставить иконки Colored-Plastic то такая ерунда. Наверное просто не подходят))
18 мар 2018, 09:43
samplitude, ну решение же на поверхности - не использовать эти иконки. Такая же бяка, помню, была с FS-Icons. На Ubuntu 14\Mint 17 они отображались нормально, а на U18\LM18 ломали не только меню, но и файловый менеджер
Вернуться в «Mate»
