Не выключается/перезагружается система
spchw
#21
23 мар 2018, 23:26
23 мар 2018, 23:14
Давай ребутнись, поймав зависание, а после покажи что в самом низу (оно листается) journalctl --boot=-1
Выше много-много этой строки: "мар 23 23:16:44 root kernel: ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush"
мар 23 23:17:01 root CRON[6031]: pam_unix(cron:session): session opened for user root by (uid=0)
мар 23 23:17:01 root CRON[6032]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
мар 23 23:17:01 root CRON[6031]: pam_unix(cron:session): session closed for user root
мар 23 23:17:21 root cinnamon-session[1366]: WARNING: t+4677,30883s: Playing logout sound '/usr/share/mint-artwork-cinnamon/sounds/logout.ogg'
мар 23 23:17:21 root polkitd(authority=local)[998]: Unregistered Authentication Agent for unix-session:c2 (system bus name :1.56, object path /org/gnome/PolicyKit1/Auth
мар 23 23:17:21 root cinnamon-session[1366]: WARNING: t+4677,43170s: Finished playing logout sound
мар 23 23:17:21 root cinnamon-session[1366]: WARNING: t+4677,43183s: Resuming logout sequence...
мар 23 23:17:22 root cinnamon-session[1366]: GLib-GIO-CRITICAL: t+4678,37999s: g_dbus_connection_call_sync_internal: assertion 'G_IS_DBUS_CONNECTION (connection)' faile
мар 23 23:17:22 root cinnamon-session[1366]: WARNING: t+4678,38333s: Requesting system shutdown...
мар 23 23:17:22 root cinnamon-session[1366]: WARNING: t+4678,38372s: Attempting to shutdown using systemd...
мар 23 23:17:22 root systemd-logind[776]: System is powering down.
мар 23 23:17:22 root systemd[1]: Stopping Manage, Install and Generate Color Profiles...
мар 23 23:17:22 root bluetoothd[1597]: Terminating
мар 23 23:17:22 root systemd[1]: Stopping Bluetooth service...
мар 23 23:17:22 root systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
мар 23 23:17:22 root systemd[1]: Stopping Authenticate and Authorize Users to Run Privileged Tasks...
мар 23 23:17:22 root systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
мар 23 23:17:22 root systemd[1]: Stopped target Sound Card.
мар 23 23:17:22 root org.gtk.vfs.Daemon[1425]: A connection to the bus can't be made
мар 23 23:17:22 root bluetoothd[1597]: Stopping SDP server
мар 23 23:17:22 root bluetoothd[1597]: Exit
мар 23 23:17:22 root sudo[3997]: pam_unix(sudo:session): session closed for user root
мар 23 23:17:22 root systemd[1]: Stopping Session c2 of user spchw.
мар 23 23:17:22 root systemd[1]: Stopping ACPI event daemon...
мар 23 23:17:22 root systemd[1]: Stopped Stop ureadahead data collection 45s after completed startup.
мар 23 23:17:22 root systemd[1]: Stopped target Graphical Interface.
мар 23 23:17:22 root systemd[1]: Stopping Accounts Service...
мар 23 23:17:22 root systemd[1]: Stopping Light Display Manager...
мар 23 23:17:22 root systemd[1]: Stopped target Multi-User System.
мар 23 23:17:22 root systemd[1]: Stopping LSB: Record successful boot for GRUB...
мар 23 23:17:22 root systemd[1]: Stopping Regular background program processing daemon...
мар 23 23:17:22 root thermald[763]: Terminating ...
мар 23 23:17:22 root systemd[1]: Stopping Cgroup management daemon...
мар 23 23:17:22 root systemd[1]: Stopping Thermal Daemon Service...
мар 23 23:17:22 root systemd[1]: Stopped target Login Prompts.
мар 23 23:17:22 root systemd[1]: Stopping Getty on tty1...
мар 23 23:17:22 root systemd[1]: Stopped Initialize hardware monitoring sensors.
мар 23 23:17:22 root systemd[1]: Stopping LSB: disk temperature monitoring daemon...
мар 23 23:17:22 root systemd[1]: Stopping LSB: Speech Dispatcher...
мар 23 23:17:22 root systemd[1]: Stopping LSB: automatic crash report generation...
мар 23 23:17:22 root systemd[1]: Stopping LSB: daemon to balance interrupts for SMP systems...
мар 23 23:17:22 root systemd[1]: Stopping LSB: Set the CPU Frequency Scaling governor to "ondemand"...
мар 23 23:17:22 root systemd[1]: Stopping LSB: Start NTP daemon...
мар 23 23:17:22 root systemd[1]: Stopped target Timers.
мар 23 23:17:22 root systemd[1]: Stopped Daily apt upgrade and clean activities.
мар 23 23:17:22 root systemd[1357]: Reached target Shutdown.
мар 23 23:17:22 root systemd[1357]: Stopped target Default.
мар 23 23:17:22 root systemd[1357]: Starting Exit the Session...
мар 23 23:17:22 root systemd[1357]: Stopped target Basic System.
мар 23 23:17:22 root systemd[1357]: Stopped target Paths.
мар 23 23:17:22 root systemd[1357]: Stopped target Timers.
мар 23 23:17:22 root dbus[789]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkitd.service'
мар 23 23:17:22 root systemd[1357]: Stopped target Sockets.
мар 23 23:17:23 root systemd[1]: Stopping User Manager for UID 1000...
мар 23 23:17:23 root ModemManager[816]: <info> Caught signal, shutting down...
мар 23 23:17:23 root systemd[1]: Stopped Daily Cleanup of Temporary Directories.
мар 23 23:17:23 root systemd[1]: Stopping Daemon for power management...
мар 23 23:17:23 root systemd[1]: Stopping Disk Manager...
мар 23 23:17:23 root systemd[1]: Stopping Modem Manager...
мар 23 23:17:23 root systemd[1]: Stopping Make remote CUPS printers available locally...
мар 23 23:17:23 root systemd[1]: Stopped Daily apt download activities.
мар 23 23:17:23 root systemd[1]: Stopped target System Time Synchronized.
мар 23 23:17:23 root systemd[1]: Stopping System Logging Service...
мар 23 23:17:23 root systemd[1]: Stopping Save/Restore Sound Card State...
мар 23 23:17:23 root systemd[1]: Stopped OpenVPN service.
мар 23 23:17:23 root systemd[1]: Stopping LSB: set CPUFreq kernel parameters...
мар 23 23:17:23 root systemd[1357]: Received SIGRTMIN+24 from PID 6094 (kill).
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.0246] ModemManager disappeared from bus
мар 23 23:17:23 root systemd[1]: Unmounted /run/user/1000/gvfs.
мар 23 23:17:23 root ModemManager[816]: <info> ModemManager is shut down
мар 23 23:17:23 root systemd[1359]: pam_unix(systemd-user:session): session closed for user spchw
мар 23 23:17:23 root systemd[1]: Stopped Cgroup management daemon.
мар 23 23:17:23 root systemd[1]: Stopped Regular background program processing daemon.
мар 23 23:17:23 root systemd[1]: Stopped Accounts Service.
мар 23 23:17:23 root systemd[1]: Stopped System Logging Service.
мар 23 23:17:23 root systemd[1]: Stopped Authenticate and Authorize Users to Run Privileged Tasks.
мар 23 23:17:23 root systemd[1]: Stopped Getty on tty1.
мар 23 23:17:23 root systemd[1]: Stopped Make remote CUPS printers available locally.
мар 23 23:17:23 root systemd[1]: Stopped Daemon for power management.
мар 23 23:17:23 root systemd[1]: Stopped User Manager for UID 1000.
мар 23 23:17:23 root systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
мар 23 23:17:23 root systemd[1]: Stopped Disk Manager.
мар 23 23:17:23 root systemd[1]: Stopped Bluetooth service.
мар 23 23:17:23 root systemd[1]: Stopped Manage, Install and Generate Color Profiles.
мар 23 23:17:23 root systemd[1]: Stopped Save/Restore Sound Card State.
мар 23 23:17:23 root systemd[1]: Stopped LSB: disk temperature monitoring daemon.
мар 23 23:17:23 root systemd[1]: Stopped Session c2 of user spchw.
мар 23 23:17:23 root speech-dispatcher[6076]: * speech-dispatcher disabled; edit /etc/default/speech-dispatcher
мар 23 23:17:23 root systemd[1]: Stopped LSB: Speech Dispatcher.
мар 23 23:17:23 root systemd[1]: Stopped LSB: Record successful boot for GRUB.
мар 23 23:17:23 root ntp[6086]: * Stopping NTP server ntpd
мар 23 23:17:23 root ntp[6086]: ...done.
мар 23 23:17:23 root ntpd[948]: ntpd exiting on signal 15 (Terminated)
мар 23 23:17:23 root systemd[1]: Stopped LSB: Start NTP daemon.
мар 23 23:17:23 root ntpd[948]: 147.231.100.5 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 80.79.25.111 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 78.108.145.1 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 37.187.104.44 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 81.2.248.189 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 91.216.168.42 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 5.1.56.123 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 94.124.107.190 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 81.0.208.219 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 195.78.244.50 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 212.96.160.147 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 185.102.185.102 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 91.189.89.198 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 109.224.76.139 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 195.78.244.34 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 78.108.102.237 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root ntpd[948]: 91.189.94.4 local addr 192.168.0.102 -> <null>
мар 23 23:17:23 root irqbalance[6079]: * Stopping SMP IRQ Balancer: irqbalance
мар 23 23:17:23 root systemd[1]: Stopped LSB: Set the CPU Frequency Scaling governor to "ondemand".
мар 23 23:17:23 root irqbalance[6079]: ...done.
мар 23 23:17:23 root apport[6077]: * Stopping automatic crash report generation: apport
мар 23 23:17:23 root systemd[1]: Stopped LSB: daemon to balance interrupts for SMP systems.
мар 23 23:17:23 root systemd[1]: Stopped LSB: set CPUFreq kernel parameters.
мар 23 23:17:23 root apport[6077]: ...done.
мар 23 23:17:23 root systemd[1]: Stopped LSB: automatic crash report generation.
мар 23 23:17:23 root dbus[789]: [system] Activation via systemd failed for unit 'polkitd.service': Refusing activation, D-Bus is shutting down.
мар 23 23:17:23 root systemd[1]: Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
мар 23 23:17:23 root NetworkManager[795]: <warn> [1521836243.2635] error requesting auth for org.freedesktop.NetworkManager.wifi.share.protected: Authorization check f
мар 23 23:17:23 root NetworkManager[795]: <warn> [1521836243.2636] error requesting auth for org.freedesktop.NetworkManager.wifi.share.open: Authorization check failed
мар 23 23:17:23 root avahi-daemon[821]: Got SIGTERM, quitting.
мар 23 23:17:23 root systemd[1]: Removed slice User Slice of spchw.
мар 23 23:17:23 root avahi-daemon[821]: Leaving mDNS multicast group on interface wlp2s0f0.IPv6 with address fe80::9caf:5a70:1876:18e8.
мар 23 23:17:23 root systemd[1]: Stopping Login Service...
мар 23 23:17:23 root avahi-daemon[821]: Leaving mDNS multicast group on interface wlp2s0f0.IPv4 with address 192.168.0.102.
мар 23 23:17:23 root systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
мар 23 23:17:23 root systemd[1]: Stopping CUPS Scheduler...
мар 23 23:17:23 root kernel: wlp2s0f0: deauthenticating from c4:6e:1f:af:b4:a4 by local choice (Reason: 3=DEAUTH_LEAVING)
мар 23 23:17:23 root systemd[1]: Stopped /etc/rc.local Compatibility.
мар 23 23:17:23 root systemd[1]: Stopped target Network.
мар 23 23:17:23 root systemd[1]: Stopping Raise network interfaces...
мар 23 23:17:23 root avahi-daemon[821]: avahi-daemon 0.6.32-rc exiting.
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.2691] caught SIGTERM, shutting down normally.
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.2705] device (wlp2s0f0): state change: activated -> deactivating (reason 'unmanaged') [100 110 3]
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.2708] manager: NetworkManager state is now DISCONNECTING
мар 23 23:17:23 root systemd[1]: Stopping Network Manager...
мар 23 23:17:23 root systemd[1]: Stopping WPA supplicant...
мар 23 23:17:23 root systemd[1]: Removed slice system-getty.slice.
мар 23 23:17:23 root systemd[1]: Stopped Login Service.
мар 23 23:17:23 root systemd[1]: Stopped Modem Manager.
мар 23 23:17:23 root systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
мар 23 23:17:23 root systemd[1]: Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
мар 23 23:17:23 root systemd[1]: Stopped ACPI event daemon.
мар 23 23:17:23 root systemd[1]: Stopped Light Display Manager.
мар 23 23:17:23 root systemd[1]: Stopping Permit User Sessions...
мар 23 23:17:23 root systemd[1]: Stopped Permit User Sessions.
мар 23 23:17:23 root systemd[1]: Stopped target User and Group Name Lookups.
мар 23 23:17:23 root systemd[1]: Stopped target Remote File Systems.
мар 23 23:17:23 root systemd[1]: Stopped target Remote File Systems (Pre).
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.5489] device (wlp2s0f0): state change: deactivating -> unmanaged (reason 'removed') [110 10 36]
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.5514] dhcp4 (wlp2s0f0): canceled DHCP transaction, DHCP client pid 1147
мар 23 23:17:23 root NetworkManager[795]: <info> [1521836243.5516] dhcp4 (wlp2s0f0): state changed bound -> done
мар 23 23:17:23 root systemd[1]: Stopped Raise network interfaces.
мар 23 23:17:23 root kernel: ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
мар 23 23:17:23 root thermald[763]: terminating on user request ..
мар 23 23:17:24 root systemd[1]: Stopped CUPS Scheduler.
мар 23 23:17:24 root kernel: ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
мар 23 23:17:24 root systemd[1]: Stopped Thermal Daemon Service.
мар 23 23:17:25 root wpa_supplicant[1082]: wlp2s0f0: CTRL-EVENT-DISCONNECTED bssid=c4:6e:1f:af:b4:a4 reason=3 locally_generated=1
мар 23 23:17:25 root kernel: ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
мар 23 23:17:25 root NetworkManager[795]: <info> [1521836245.1497] dns-mgr: Writing DNS information to /sbin/resolvconf
мар 23 23:17:25 root dnsmasq[1156]: setting upstream servers from DBus
мар 23 23:17:25 root wpa_supplicant[1082]: nl80211: deinit ifname=wlp2s0f0 disabled_11b_rates=0
мар 23 23:17:25 root NetworkManager[795]: <info> [1521836245.1711] manager: NetworkManager state is now DISCONNECTED
мар 23 23:17:25 root dbus[789]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
мар 23 23:17:25 root NetworkManager[795]: <info> [1521836245.1789] exiting (success)
мар 23 23:17:25 root dbus[789]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting dow
мар 23 23:17:25 root systemd[1]: Stopped WPA supplicant.
мар 23 23:17:25 root wpa_supplicant[1082]: wlp2s0f0: CTRL-EVENT-TERMINATING
мар 23 23:17:25 root systemd[1]: Stopped Network Manager.
мар 23 23:17:25 root systemd[1]: Stopped target Network (Pre).
мар 23 23:17:25 root systemd[1]: Stopping D-Bus System Message Bus...
мар 23 23:17:25 root systemd[1]: Stopped D-Bus System Message Bus.
мар 23 23:17:25 root systemd[1]: Stopped target Basic System.
мар 23 23:17:25 root systemd[1]: Stopped target Paths.
мар 23 23:17:25 root systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
мар 23 23:17:25 root systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
мар 23 23:17:25 root systemd[1]: Stopped ACPI Events Check.
мар 23 23:17:25 root systemd[1]: Stopped CUPS Scheduler.
мар 23 23:17:25 root systemd[1]: Stopped target Sockets.
мар 23 23:17:25 root systemd[1]: Closed Syslog Socket.
мар 23 23:17:25 root systemd[1]: Closed ACPID Listen Socket.
мар 23 23:17:25 root systemd[1]: Closed CUPS Scheduler.
мар 23 23:17:25 root systemd[1]: Closed UUID daemon activation socket.
мар 23 23:17:25 root systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
мар 23 23:17:25 root systemd[1]: Stopped target Slices.
мар 23 23:17:25 root systemd[1]: Removed slice User and Session Slice.
мар 23 23:17:25 root systemd[1]: Closed D-Bus System Message Bus Socket.
мар 23 23:17:25 root systemd[1]: Stopped target System Initialization.
мар 23 23:17:25 root systemd[1]: Starting Console System Shutdown Logging...
мар 23 23:17:25 root systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
мар 23 23:17:25 root systemd[1]: Stopped target Encrypted Volumes.
мар 23 23:17:25 root systemd[1]: Stopped target Swap.
мар 23 23:17:25 root systemd[1]: Deactivating swap Swap Partition...
мар 23 23:17:25 root systemd[1]: Deactivating swap /dev/disk/by-partuuid/96229667-08b8-4295-aabf-d48e7168ebfc...
мар 23 23:17:25 root systemd[1]: Stopping Load/Save Random Seed...
мар 23 23:17:25 root systemd[1]: Stopped Create Volatile Files and Directories.
мар 23 23:17:25 root systemd[1]: Stopped target Local File Systems.
мар 23 23:17:25 root systemd[1]: Unmounting /run/cgmanager/fs...
мар 23 23:17:25 root systemd[1]: Unmounting /boot/efi...
мар 23 23:17:25 root systemd[1]: Unmounting /run/user/1000...
мар 23 23:17:25 root systemd[1]: Stopped Apply Kernel Variables.
мар 23 23:17:25 root systemd[1]: Stopped Load Kernel Modules.
мар 23 23:17:25 root systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
мар 23 23:17:25 root systemd[1]: Stopped Load/Save Random Seed.
мар 23 23:17:25 root systemd[1]: Started Console System Shutdown Logging.
мар 23 23:17:25 root systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
мар 23 23:17:25 root swapoff[6215]: swapoff: /dev/disk/by-uuid/7cc8552d-8b3e-439a-97d1-65cddb9d229c: не удалось выполнить swapoff: Недопустимый аргумент
мар 23 23:17:25 root systemd[1]: dev-disk-by\x2duuid-7cc8552d\x2d8b3e\x2d439a\x2d97d1\x2d65cddb9d229c.swap: Swap process exited, code=exited status=255
мар 23 23:17:25 root systemd[1]: Deactivated swap /dev/disk/by-uuid/7cc8552d-8b3e-439a-97d1-65cddb9d229c.
мар 23 23:17:25 root systemd[1]: dev-disk-by\x2duuid-7cc8552d\x2d8b3e\x2d439a\x2d97d1\x2d65cddb9d229c.swap: Unit entered failed state.
мар 23 23:17:25 root systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:00:13.0-ata-1-part3.
мар 23 23:17:25 root systemd[1]: Deactivated swap /dev/disk/by-partuuid/96229667-08b8-4295-aabf-d48e7168ebfc.
мар 23 23:17:25 root systemd[1]: Deactivated swap /dev/disk/by-id/wwn-0x5000cca7aedf763b-part3.
мар 23 23:17:25 root systemd[1]: Deactivated swap /dev/disk/by-id/ata-HGST_HTS545050A7E680_TE85134NJ76KBR-part3.
мар 23 23:17:25 root systemd[1]: Deactivated swap Swap Partition.
мар 23 23:17:25 root systemd[1]: Unmounted /run/cgmanager/fs.
мар 23 23:17:25 root systemd[1]: Unmounted /run/user/1000.
мар 23 23:17:25 root systemd[1]: Unmounted /boot/efi.
мар 23 23:17:25 root systemd[1]: Reached target Unmount All Filesystems.
мар 23 23:17:25 root systemd[1]: Stopped File System Check on /dev/disk/by-uuid/B984-11A0.
мар 23 23:17:25 root systemd[1]: Stopped target Local File Systems (Pre).
мар 23 23:17:25 root systemd[1]: Stopped Create Static Device Nodes in /dev.
мар 23 23:17:25 root systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
мар 23 23:17:25 root systemd[1]: Stopped Remount Root and Kernel File Systems.
мар 23 23:17:25 root systemd[1]: Removed slice system-systemd\x2dfsck.slice.
мар 23 23:17:25 root systemd[1]: Reached target Shutdown.
мар 23 23:17:25 root systemd[1]: Starting Shuts down the "live" preinstalled system cleanly...
мар 23 23:17:25 root systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
мар 23 23:17:25 root systemd[1]: Stopping LVM2 metadata daemon...
мар 23 23:17:25 root systemd[1]: Stopped LVM2 metadata daemon.
мар 23 23:17:25 root systemd[1]: Started Shuts down the "live" preinstalled system cleanly.
мар 23 23:17:25 root systemd[1]: Reached target Final Step.
мар 23 23:17:25 root systemd[1]: Starting Power-Off...
мар 23 23:17:25 root systemd[1]: Shutting down.
мар 23 23:17:25 root kernel: systemd-shutdow: 33 output lines suppressed due to ratelimiting
мар 23 23:17:26 root systemd-shutdown[1]: Sending SIGTERM to remaining processes...
мар 23 23:17:26 root systemd-journald[340]: Journal stopped
Решено: 215
Благодарил (а): 815 раз
#22
23 мар 2018, 23:54
spchw писал(а):
23 мар 2018, 23:26
печалька, журналирование успело успешно завершиться. здесь тоже ничего не поймали
Решено: 215
#23
24 мар 2018, 00:00
Пока не придумались очередные варианты - попробуй перебрать версии ядра. от 4.4 до 4.13 (можно в обратном порядке), что предлагаются в контестном меню менеджера обновлений
Благодарил (а): 212 раз
#24
24 мар 2018, 20:01
23 мар 2018, 21:46
AlexZ, Пробежался по всем 4-м ссылкам, в поисках объяснения.
Что сказать-то хотел?
Проблема из-за сети. Ссылки скинул для "куда копать".
Ну это по аналогии как мне советовали Bumblebee (Nvidia + Intel) в Linux Mint 18.X
Ссылка та в итоге не помогла, а проблему решило новейшее ядро.
24 мар 2018, 00:00
Может сразу 4.15? :smile: Как "панацею" для драйверов (видео, сети и т.д.). И ноут смотрю ровесник моего..
spchw
#25
25 мар 2018, 15:32
AlexZ писал(а):
24 мар 2018, 20:01
Может сразу 4.15? Как "панацею" для драйверов (видео, сети и т.д.). И ноут смотрю ровесник моего..
Либо я слепой, либо...
Решено: 129
Благодарил (а): 776 раз
#26
25 мар 2018, 15:39
spchw писал(а):
25 мар 2018, 15:32
либо...
Ставить ядро так Ubuntu Kernel Upgrade Utility
spchw
#27
25 мар 2018, 15:42
25 мар 2018, 15:39
Благодарю, просто мне сказали
24 мар 2018, 00:00
вот...
Решено: 129
#28
25 мар 2018, 15:46
spchw писал(а):
25 мар 2018, 15:42
просто мне сказали
вам предлагали ядра 4.4-4.13 из менеджера обновлений. Про ядра версии выше 4.13 там ничего не было сказано.
