Создание сетевой папки в Nemo
Автор темы - Сообщения: 5469
Переформатировать в ext4
darkfenix, никто не мешает сбиндить.
cat /etc/fstab # /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> # / was on /dev/sda2 during installation UUID=f7bad9ae-8f69-48b4-a204-b1ed702cfb4e / ext4 errors=remount-ro 0 1 # /boot/efi was on /dev/sda1 during installation UUID=E01D-4FB6 /boot/efi vfat umask=0077 0 1 # /home was on /dev/sda4 during installation UUID=98751bbe-9cf8-4315-9f08-95531ce4f7ad /home ext4 defaults 0 2 #Entry for /dev/sda5 : UUID=71FC84E61F0AF303 /media/hardD ntfs-3g uid=1000,gid=1000,dmask-022,fmask=133,locale=ru_RU.UTF-8 0 0 #Binds /media/hardD/dja/Documents/Work/Instructions /home/dja/samba/pub/Инструкции none bind 0 0 /media/hardD/dja/Documents /home/dja/Документы none bind 0 0 /media/hardD/dja/Downloads /home/dja/Загрузки none bind 0 0 /media/hardD/dja/Music /home/dja/Музыка none bind 0 0 /media/hardD/dja/Pictures /home/dja/Изображения none bind 0 0 /media/hardD/dja/Video /home/dja/Видео none bind 0 0 /media/hardD/dja/local /home/dja/local none bind 0 0 /media/hardD/dja/Clouds/YaDisk /home/dja/Clouds/YaDisk none bind 0 0 /media/hardD/dja/Clouds/MailRu /home/dja/Clouds/MailRu none bind 0 0 /media/hardD/dja/Distrib /home/dja/samba/pub/Distr none bind 0 0 /media/hardD/dja/Documents /media/hardD/dja/VirtualShare/mc.admin/Documents none bind 0 0 /media/hardD/dja/Downloads /media/hardD/dja/VirtualShare/mc.admin/Downloads none bind 0 0 /media/hardD/dja/Pictures /media/hardD/dja/VirtualShare/mc.admin/Pictures none bind 0 0 /media/hardD/dja/Video /media/hardD/dja/VirtualShare/mc.admin/Video none bind 0 0 /media/hardD/dja/Desktop /media/hardD/dja/VirtualShare/mc.admin/Desktop none bind 0 0 /media/dja /media/hardD/dja/VirtualShare/mnt none bind 0 0
ls -la ~/samba/pub/ итого 2636 drwxrwxr-x 11 dja dja 4096 май 21 09:17 . drwxr-xr-x 4 dja dja 4096 май 2 2017 .. drwxrwxrwx 1 dja dja 4096 апр 18 13:58 Distr drwxrwxr-x 4 dja dja 4096 фев 16 11:08 DZ drwxrwxrwx 2 dja dja 4096 ноя 27 15:04 i -rwxrwxr-x 1 dja dja 2444288 июн 30 2016 mkb0715.xls -rwxrwxr-x 1 dja dja 127 янв 27 2016 ping_on_off.txt -rwxrwxr-x 1 dja dja 532 янв 29 2016 private_network.reg drwxr-xr-x 2 dja dja 4096 апр 5 08:28 SP -rwxrwxr-x 1 dja dja 59904 фев 2 2017 Thumbs.db drwxrwxr-x 2 dja dja 4096 апр 25 2017 Type_files -rwxrwxr-x 1 dja dja 129085 апр 10 2017 Type.html -rwxrwxr-x 1 dja dja 4278 дек 13 2016 Untitled.FR11.xlsx drwxr-xr-x 2 dja dja 4096 июл 27 2017 ВК drwxr-xr-x 3 dja dja 4096 апр 20 16:51 Здравпункты1 drwxrwxrwx 1 dja dja 4096 апр 19 11:57 Инструкции drwxrwxr-x 2 dja dja 4096 апр 3 16:44 Приколы
ls -la ~/samba/pub/Distr/ итого 24 drwxrwxrwx 1 dja dja 4096 май 21 09:20 . drwxrwxr-x 11 dja dja 4096 май 21 09:17 .. drwxrwxrwx 1 dja dja 4096 мар 2 14:52 ISO drwxrwxrwx 1 dja dja 4096 апр 9 08:59 Linux drwxrwxrwx 1 dja dja 8192 апр 18 13:58 MustDie
При всём при этом
$ df -h Файл.система Размер Использовано Дост Использовано% Cмонтировано в udev 5,8G 0 5,8G 0% /dev tmpfs 1,2G 9,8M 1,2G 1% /run /dev/sda2 20G 14G 4,7G 75% / tmpfs 5,9G 137M 5,7G 3% /dev/shm tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs 5,9G 0 5,9G 0% /sys/fs/cgroup /dev/sda1 435M 3,5M 432M 1% /boot/efi /dev/sda5 436G 307G 129G 71% /media/hardD /dev/sda4 9,8G 4,7G 4,6G 51% /home cgmfs 100K 0 100K 0% /run/cgmanager/fs tmpfs 1,2G 32K 1,2G 1% /run/user/1000
- Решено: 24
Если на машине нет Винды и не предвидится, то и NTFS делать нечего. Используй линуксовые ФС. Это надежнее, быстрее, проще и спокойнее тебе будет.
даже не знаю пробовать или нет, после 3-х дней в линуксе ))
в общем, всем спасибо! главное понял в чем проблема.
а какие будут ждать сюрпризы если я изменю систему на ext4, а будущем решу установить винду? погуглю ))
