хотя flash player установлен, в чём проблема ?
celtic
Благодарил (а): 50 раз
05 янв 2018, 22:30
Доброго дня всем.
в браузере Chromium Версия 63.0.3239.84 (Официальная сборка), Built on Ubuntu, на странице http://www.speedtest.net сообщение:
This version of Speedtest requires Adobe Flash. Fortunately, we're ready to share our new Flash-free beta site. Thanks in advance for your patience and feedback.
(Для этой версии Speedtest требуется Adobe Flash. К счастью, мы готовы поделиться нашим новым бета-сайтом без Flash. Заранее благодарю за ваше терпение и обратную связь.)
О платформе Flash
Chromium 63.0.3239.84 (Built on Ubuntu , running on LinuxMint 18.3)
ОС Linux
Flash plugin 28.0.0.126 /usr/lib/adobe-flashplugin/libpepflashplayer.so
--- Crash data ---
Crash Reporting Enable crash reporting to see crash IDs
For more details https://support.google.com/chrome/?p=ui_usagestat
--- GPU information ---
--- GPU driver, more information ---
Vendor Id 0x10de
Device Id 0x1051
Driver vendor Mesa
Driver version 11.2.0
Driver date
Pixel shader version 1.30
Vertex shader version 1.30
GL_VENDOR Intel Open Source Technology Center
GL_RENDERER Mesa DRI Intel(R) Sandybridge Mobile
GL_VERSION 3.0 Mesa 11.2.0
GL_EXTENSIONS GL_3DFX_texture_compression_FXT1 GL_AMD_draw_buffers_blend GL_AMD_performance_monitor GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_trinary_minmax GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sync GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_INTEL_performance_query GL_KHR_context_flush_control GL_KHR_debug GL_MESA_pack_invert GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
sudo update-pepperflashplugin-nonfree --status
Flash Player version installed on this system : 28.0.0.126
Flash Player version available on upstream site: 28.0.0.126
System: Host: samsung Kernel: 4.13.0-21-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.6.6 (Gtk 3.18.9-1ubuntu3.3)
Machine: System: SAMSUNG product: 300E4Z/300E5Z/300E7Z v: 0.1
Mobo: SAMSUNG model: 300E4Z/300E5Z/300E7Z v: FAB1
Bios: Phoenix v: 02QB date: 11/12/2011
CPU: Dual core Intel Core i3-2350M (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9179
clock speeds: max: 2300 MHz 1: 2294 MHz 2: 2294 MHz 3: 2294 MHz
4: 2294 MHz
Graphics: Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
bus-ID: 00:02.0
Card-2: NVIDIA GF119M [GeForce GT 520MX] bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
Resolution: 1366x768@60.07hz
GLX Renderer: Mesa DRI Intel Sandybridge Mobile
GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio: Card Intel 6 Series/C200 Series Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.13.0-21-generic
Network: Card-1: Intel Centrino Wireless-N 130
driver: iwlwifi bus-ID: 02:00.0
IF: wlp2s0 state: down mac: <filter>
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 750.2GB (17.6% used)
ID-1: /dev/sda model: TOSHIBA_MK7559GS size: 750.2GB temp: 48C
Partition: ID-1: / size: 37G used: 24G (67%) fs: ext4 dev: /dev/sda6
ID-2: swap-1 size: 8.50GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 59.0C mobo: 29.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 212 Uptime: 3:08 Memory: 1178.9/7893.1MB
06 янв 2018, 11:01
celtic, у меня в openSUSE в Chromiume с флешом рабочим показывает ошибку и сразу автоматом перекидывает на beta-версию сайта с html5. А что тебя не устраивает? Он же измеряет скорость. Просто они решили отказаться от флеша в пользу html5. И просят протестировать как работает их новый сервис и оставить им отзыв. Вот и вся беда
celtic
06 янв 2018, 12:22
06 янв 2018, 11:01
я просто подумал где-то ещё проблема проявится, так-то работает.
06 янв 2018, 11:01
про это я не подумал
08 янв 2018, 08:58
celtic писал(а):
05 янв 2018, 22:30
Доброго дня всем.
У меня к примеру без проблем открывается. Сперва пишет тоже самое, а затем перекидвает на тест. Может у тебя чего-то не доустановленно? И вообще... для меня этот сайт уже умер. Ведь есть замечательная утилитка:
sudo apt install speedtest-cli
vir0id@15-bw0xx ~ $ speedtest-cli
Retrieving speedtest.net configuration...
Retrieving speedtest.net server list...
Testing from Sia Mint Net (8x.xx.2x4.x38)...
Selecting best server based on latency...
Hosted by DEAC (Riga) [0.25 km]: 18.328 ms
Testing download speed........................................
Download: 23.91 Mbit/s
Testing upload speed..................................................
Upload: 12.36 Mbit/s
vir0id@15-bw0xx ~ $
Kurum
Благодарил (а): 193 раза
03 янв 2019, 11:27
Странно, у меня в мозилле и вивальди флеш плеер работает, а вот в опере (в.57) отказывается. Пишет "нажмите, чтобы включить adobe flash", нажимаю, но результата никакого.
Linux - это свобода... :tux:
Текущая:
KDE Neon 5.2x
Предыдущая:
Linux Mint 19.1 Cinnamon
Железо:
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
03 янв 2019, 12:28
vir0id, установил по твоему совету speedtest-cli, но при попытке набора командыы в консоли с Tab оказалось, что у меня есть еще и просто speedtest...
...то ли я сей speedtest раньше ставил, то ли это алиас на предложеный тобой пакет - этого я так и не понял. :dash2:
А работает обнаруженый speedtest точно также как и speedtest-cli
starmaugli@mugalem-P35 ~ $ spee
speech-dispatcher  speedtest          speedtest-cli
starmaugli@mugalem-P35 ~ $ speedtest
Testing from Rostelecom (37.204.60.96)...
Hosted by Megafon (Moscow) [0.15 km]: 9.619 ms
Download: 69.31 Mbit/s
Upload: 91.77 Mbit/s
starmaugli@mugalem-P35 ~ $ speedtest-cli
Hosted by Megafon (Moscow) [0.15 km]: 4.628 ms
Download: 48.78 Mbit/s
Upload: 86.15 Mbit/s
starmaugli@mugalem-P35 ~ $ wh
whatis    whereis   which     while     whiptail  who       whoami
starmaugli@mugalem-P35 ~ $ whatis speedtest
speedtest (1)        - Test your bandwidth througput using speedtest.net
starmaugli@mugalem-P35 ~ $ whatis speedtest-cli
speedtest-cli (1)    - Test your bandwidth througput using speedtest.net
(латенси и скорости загрузки/выгрузки очень похожи (в пределах не малой довольно-таки погрешности)
03 янв 2019, 19:41
StarMAUGLI писал(а):
03 янв 2019, 12:28
Ну не совсем алиас. Там два бирарика комилатся питоновских скрипта с разным вводом.
Вернуться в «Работа с сетью»
