How-to: Установка драйвера amdgpu-pro Linux Mint 18.2 Cinamon
#61
27 окт 2017, 08:13
gand писал(а):
27 окт 2017, 07:58
Смотрю
А нам показать вывод inxi -Fxz не желаешь?
gand
#62
27 окт 2017, 10:21
27 окт 2017, 08:13
Еще как желаю, вот забежал с работы домой на обед и сразу показываю:
System:    Host: gand Kernel: 4.10.0-37-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.4.6 (Gtk 3.18.9-1ubuntu3.3)
           Distro: Linux Mint 18.2 Sonya
Machine:   Mobo: ASUSTeK model: A78M-A v: Rev X.0x
           Bios: American Megatrends v: 1101 date: 07/15/2014
CPU:       Quad core AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G (-MCP-) cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 24925
           clock speeds: max: 3100 MHz 1: 1900 MHz 2: 2400 MHz 3: 1900 MHz
           4: 1400 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Kaveri [Radeon R7 Graphics]
           bus-ID: 00:01.0
           Display Server: X.Org 1.18.4 driver: amdgpu
           Resolution: 1280x1080@60.00hz, 1280x1080@60.00hz
           GLX Renderer: AMD Radeon Graphics
           GLX Version: 4.5.13491 - CPC Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Kaveri HDMI/DP Audio Controller
           driver: snd_hda_intel bus-ID: 00:01.1
           Card-3 KYE Systems (Mouse Systems) Genius iSlim 2000AF V2
           driver: USB Audio usb-ID: 005-003
           Sound: Advanced Linux Sound Architecture v: k4.10.0-37-generic
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 03:00.0
Drives:    HDD Total Size: 772.2GB (4.8% used)
           ID-1: USB /dev/sda model: Transcend_16GB size: 16.1GB
           ID-2: /dev/sdb model: Crucial_CT256MX1 size: 256.1GB
           ID-3: /dev/sdc model: ST500DM002 size: 500.1GB
Partition: ID-1: / size: 28G used: 13G (48%) fs: ext4 dev: /dev/sdb1
           ID-2: /home size: 165G used: 16G (10%) fs: ext4 dev: /dev/sdb5
           ID-3: swap-1 size: 4.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdb6
Sensors:   System Temperatures: cpu: 19.0C mobo: N/A gpu: 14.0
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 307 Uptime: 11:13 Memory: 4300.2/10942.5MB
gand
#63
31 окт 2017, 21:12
Так что, совсем никто не знает, куда копать по моему вопросу?
вот так, кстати, игрушка ругается:
ZloyRus
#64
06 янв 2018, 10:32
Попробовал впихнуть невпихуемоее, точнее трудно впихуемое, вроде получилось:
zloyrus-pc / # inxi -SG
System:    Host: zloyrus-pc Kernel: 4.10.0-42-generic x86_64 (64 bit) Desktop: Cinnamon 3.6.7
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Pitcairn XT [Radeon HD 7870 GHz Edition]
           Display Server: X.org 1.19.3 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
           tty size: 164x64 Advanced Data: N/A for root
zloyrus-pc / # xrandr
Screen 0: minimum 320 x 200, current 3840 x 1200, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 1920x1080+1920+120 (normal left inverted right x axis y axis) 531mm x 298mm
   1920x1080     60.00*+
   1680x1050     59.88
   1600x900      60.00
   1280x1024     75.02    60.02
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00
   1024x768      75.03    60.00
   832x624       74.55
   800x600       75.00    60.32
   640x480       75.00    59.94
   720x400       70.08
DVI-I-0 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 582mm x 375mm
   1920x1200     59.95*+
   1600x1200     60.00
   1680x1050     59.95
   1440x900      59.89
   1280x800      59.81
   1152x864      75.00
   1024x768      75.03    72.00    70.07    60.00
   832x624       74.55
   800x600       72.19    75.00    60.32    56.25
   640x480       75.00    72.81    66.67    59.94
   720x400       70.08
lcpci -k
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Pitcairn XT [Radeon HD 7870 GHz Edition]
	Subsystem: PC Partner Limited / Sapphire Technology Pitcairn XT [Radeon HD 7870 GHz Edition]
	Kernel driver in use: amdgpu
	Kernel modules: radeon, amdgpu
Немного смущает вот это:
drivers: ati,amdgpu
ati надо выпиливать или нет?
achilles_85
Благодарил (а): 10 раз
#65
21 мар 2018, 12:34
Дано Mint Mate 18.3, карта R7 250X. Установил иксы 1.19.5 след образом:
apt update
apt install xserver-xorg-hwe-16.04 xserver-xorg-legacy-hwe-16.04 xserver-xorg-video-all-hwe-16.04
apt install -f
Обновил ядро до крайней версии 4.15.11, команда
grep CONFIG_DRM_AMDGPU_SI /boot/config-$(uname -r)
отвечает
CONFIG_DRM_AMDGPU_SI=y
(то что нужно моей карте)
По инструкции установил крайние дрова от амд. Но после ребута система не видит их, kernel driver отсутствует. Только на ядре 4.10.17 и ниже видит драйвер.
Как завести на крайней версии ядра этот драйвер?
Также изображение стало каким то жутким, не четким что ли. Слева появилась полоса небольшая сверху вниз. На дровах радеон норм все было. Как настроить изображение? Нужно создать файл xorg.conf и в нем прописать?
Кто знает помогите плиз, только начинаю разбираться в этих дебрях.
System:    Host: worklap Kernel: 4.10.17-041017-generic x86_64 (64 bit)
           Desktop: MATE 1.18.0  Distro: Linux Mint 18.3 Sylvia
Machine:   Mobo: ASUSTeK model: H61M-K v: Rev X.0x
           Bios: American Megatrends v: 0801 date: 07/21/2014
CPU:       Dual core Intel Core i3-3250 (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 3500 MHz 1: 1603 MHz 2: 1599 MHz 3: 1599 MHz
           4: 1599 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Cape Verde XT [Radeon HD 7770/8760 / R7 250X]
           Display Server: X.Org 1.19.5 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: AMD Radeon HD 7700 Series
           GLX Version: 4.5.13505 - CPC
Audio:     Card-1 Intel 6 Series/C200 Series Family High Definition Audio Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
           Sound: ALSA v: k4.10.17-041017-generic
           driver: r8169
           mac: e0:3f:49:57:cc:03
Drives:    HDD Total Size: 1320.2GB (25.2% used)
           ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
           ID-2: USB /dev/sdb model: ZM size: 320.0GB
Partition: ID-1: / size: 902G used: 51G (6%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 17.12GB used: 0.00GB (0%) fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 41.0
Info:      Processes: 206 Uptime: 1 min Memory: 760.6/15990.4MB
           Client: Shell (bash) inxi: 2.2.35
glxheads: exercise multiple GLX connections (any key = exit)
Usage:
  glxheads xdisplayname ...
Example:
  glxheads :0 mars:0 venus:1
  Display:     0x19bc780
  Window:      0x3c00002
  Context:     0x1a9bf40
  GL_VERSION:  4.5.13505 Compatibility Profile Context
  GL_VENDOR:   ATI Technologies Inc.
  GL_RENDERER: AMD Radeon HD 7700 Series
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
      after 14815 requests (14815 known processed) with 0 events remaining.
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde XT [Radeon HD 7770/8760 / R7 250X]
	Subsystem: Gigabyte Technology Co., Ltd Cape Verde XT [Radeon HD 7770/8760 / R7 250X]
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
HDMI-A-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 298mm
   1920x1080     60.00*+  50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1600x900      60.00
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   832x624       74.55
   800x600       75.00    60.32
   720x576       50.00
   720x576i      50.00
   720x480       60.00    59.94
   720x480i      60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
DVI-I-0 disconnected (normal left inverted right x axis y axis)
Последний раз редактировалось пользователем 1 achilles_85; всего редактировалось раз: 21
achilles_85
#66
21 мар 2018, 12:38
UPD Нашел в соседней теме ответы.
Вернуться в «Видеокарты»
