Запуск из терминала выдает следующую надпись.
0009:fixme:exec:SHELL_execute flags ignored: 0x00000100
0009:fixme:exec:SHELL_execute flags ignored: 0x00004100
john@doe ~ $ 002e:err:module:import_dll Loading library mfc140u.dll (which is needed by L"C:\\Program Files (x86)\\GOG Galaxy\\GalaxyClient.exe") failed (error c000007b).
002e:err:module:attach_dlls Importing dlls for L"C:\\Program Files (x86)\\GOG Galaxy\\GalaxyClient.exe" failed, status c0000135
Desktop: Cinnamon 3.4.6 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.2 Sonya
Machine: Mobo: Gigabyte model: Z87M-D3H v: x.x Bios: American Megatrends v: 11b date: 06/12/2014
CPU: Quad core Intel Core i5-4690 (-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 27935
clock speeds: max: 3900 MHz 1: 3821 MHz 2: 3890 MHz 3: 3898 MHz 4: 3896 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Hawaii PRO [Radeon R9 290] bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
Resolution: 1920x1080@60.00hz
GLX Renderer: AMD Radeon R9 200 Series
GLX Version: 4.5.13491 - CPC 17.30.0 Direct Rendering: Yes
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
Card-2 Advanced Micro Devices [AMD/ATI] Hawaii HDMI Audio
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
Drives: HDD Total Size: 1448.3GB (9.2% used) ID-1: /dev/sda model: ST31000524AS size: 1000.2GB
ID-2: /dev/sdb model: Samsung_SSD_850 size: 128.0GB
ID-3: /dev/sdc model: WDC_WD3200BPVT size: 320.1GB
Partition: ID-1: / size: 28G used: 8.7G (34%) fs: ext4 dev: /dev/sdc3
ID-2: /boot size: 461M used: 105M (24%) fs: ext2 dev: /dev/sdc1
ID-3: /home size: 264G used: 114G (46%) fs: ext4 dev: /dev/sdc4
ID-4: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdc2
Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 49.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 230 Uptime: 3:59 Memory: 2355.9/15984.2MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0 Client: Shell (bash 4.3.481) inxi: 2.2.35
