https://www.xfce-look.org/browse/cat/136/ord/latest/
все в том же
bar
bar {
font pango:Ubuntu Mono Bold 14
status_command i3status
все в том же
bar
bar {
Я там был, но подходящую тему не нашел.Chocobo писал(а): https://www.xfce-look.org/browse/cat/136/ord/latest/
Спасибо.
[kbd]
interval=1
command=xset -q|grep LED| awk '{ if (substr ($10,5,1) == 1) print "RU"; else print "EN"; }'
set $Locker i3lock && sleep 1
set $mode_system System (l) lock, (e) logout, (s) suspend, (h) hibernate, (r) reboot, (Shift+s) shutdown
mode "$mode_system" {
bindsym l exec --no-startup-id $Locker, mode "default"
bindsym e exec --no-startup-id i3-msg exit, mode "default"
bindsym s exec --no-startup-id $Locker && systemctl suspend, mode "default"
bindsym h exec --no-startup-id $Locker && systemctl hibernate, mode "default"
bindsym r exec --no-startup-id systemctl reboot, mode "default"
bindsym Shift+s exec --no-startup-id systemctl poweroff -i, mode "default"
# back to normal: Enter or Escape
bindsym Return mode "default"
bindsym Escape mode "default"
bindsym $mod+Pause mode "$mode_system"
Меняем параметр:
command=xset -q|grep LED| awk '{ if (substr ($10,5,1) == 1) print "RU\nRU\n#0000FF"; else print "EN\nEN\n#FF0000"; }'
[kbd]
interval=1
Созрел))
### settings for i3-gaps: ###
# Disable window titlebars entirely
for_window [class="^.*"] border pixel 2
# Set inner/outer gaps
gaps inner 10
gaps outer 0
# Additionally, you can issue commands with the following syntax. This is useful to bind keys to changing the gap size.
# gaps inner|outer current|all set|plus|minus <px>
# gaps inner all set 10
# gaps outer all plus 5
# Smart gaps (gaps used if only more than one container on the workspace)
smart_gaps on
# Smart borders (draw borders around container only if it is not the only container on this workspace)
# on|no_gaps (on=always activate and no_gaps=only activate if the gap size to the edge of the screen is 0)
smart_borders on
# Press $mod+Shift+g to enter the gap mode. Choose o or i for modifying outer/inner gaps. Press one of + / - (in-/decrement for current workspace) or 0 (remove gaps for current workspace). If you also press Shift with these keys, the change will be global for all workspaces.
set $mode_gaps Gaps: (o) outer, (i) inner
set $mode_gaps_outer Outer Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_inner Inner Gaps: +|-|0 (local), Shift + +|-|0 (global)
bindsym $mod+Shift+g mode "$mode_gaps"
mode "$mode_gaps" {
bindsym o mode "$mode_gaps_outer"
bindsym i mode "$mode_gaps_inner"
mode "$mode_gaps_inner" {
bindsym plus gaps inner current plus 5
bindsym minus gaps inner current minus 5
bindsym 0 gaps inner current set 0
bindsym Shift+plus gaps inner all plus 5
bindsym Shift+minus gaps inner all minus 5
bindsym Shift+0 gaps inner all set 0
mode "$mode_gaps_outer" {
bindsym plus gaps outer current plus 5
bindsym minus gaps outer current minus 5
bindsym 0 gaps outer current set 0
bindsym Shift+plus gaps outer all plus 5
bindsym Shift+minus gaps outer all minus 5
bindsym Shift+0 gaps outer all set 0
blurlock+i3lock
, а для управления сессие, перезагрузкой выключением - стоял oblogout
Думаю что да, но надо самому глянуть как смотрится, но думаю будет оригинально )))
Это я вряд ли смогу сделать, так как не знаю английского языка, да и редко когда нормально справляюсь с компиляцией, но буду пробовать.Chocobo писал(а): Надо собирать i3-gaps отсюда - https://github.com/Airblader/i3 , как установить там тоже есть инфа.
Надо попробовать эти варианты.
При выполнении команды: шифт + вин + пробел = приобретает нормальный вид...
