Мало свободного места на диске "кореньфайловой системы"
El2a42
Благодарил (а): 9 раз
#21
13 фев 2020, 20:02
12 фев 2020, 23:27
El2a42, добавь сюда вывод lspci , и совет , выставляй лучше сюда не скрины а текст под спойлер.
Вот я сделал через команду lspci
zog@zog-Default-string:~$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #3 (rev f1)
00:1c.3 PCI bridge: Intel Corporation Device 9d13 (rev f1)
00:1e.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO UART Controller #0 (rev 21)
00:1e.4 SD Host controller: Intel Corporation Device 9d2b (rev 21)
00:1e.6 SD Host controller: Intel Corporation Sunrise Point-LP Secure Digital IO Controller (rev 21)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4322 802.11a/b/g/n Wireless LAN Controller (rev 01)
El2a42
#22
13 фев 2020, 20:13
Сотрудник писал(а):
13 фев 2020, 04:31
El2a42, Очистить систему поможет программа bleachbit (есть в менеджере программ). Я смонтировал папку "/tmp" на отдельный раздел 8GB при установке системы и для временных файлов всегда есть свободное место. Очистить эту папку можно в терминале sudo rm -r /tmp/*
Спасибо за совет. Я уже установил эту программу. Пытался ей чистить. С моими знаниями сложно там разобраться, что можно удалять, а чего нет. Поставишь галку не туда и все... Пока просто механически удаляю два этих файла.
На отдельный раздел , с моими знаниями, я смог установить только хоум. Остальное боюсь проблемотично. Да и что это даст? Размер файлов увеличивается как снежный ком, сейчас без удаления этих файлов система умирает за 10 часов, а будет за 20. Хочется докапаться до причины.
#23
13 фев 2020, 20:24
El2a42, очевидно сбойнул сервер форума , исчезли твои вложения со скринами. Повтори inxi -Fxz и куски логов в виде текста.
El2a42
#24
13 фев 2020, 20:39
colonel писал(а):
13 фев 2020, 07:33
2El2a42,
Установил Минт 19.3, обновил все, через часа два работы прилетело сообщение " мало места на диске корень файловой системы" Проверил. Нашел в корне, в папке var, папка log занимает 19,1 Гв из отведенных под файловую систему 30 Гб. В ней два файла kern.log и syslog занимают по 9 гигов. В файлах все исписано ошибкой типа PCIe Bus Error, и Default - string kernel .
Помогите,..
..... Раньше на нем стоял Минт 18, но решили переустановить потому, что тоже начали выскакивать предупреждения про мало места... Вобщем ХЕЛП!!!!
саймон в #2 и #6 дал ссылки на форумы с вероятновозможным решением проблемы внесением соответствующих записей в /etc/default/grub
так же им было подсказано что "лог можно удалить с флешки" ( т.е. загрузившись с флешки удалить те разросшиеся логи) . Это для того что бы освободить место на корне и загрузиться в систему . А потом уже в системе править /etc/default/grub
так понятно?
вероятно у вас забит дебпакетами ещё и /var/cache/apt/ . И возможно таймшифтовые снимки ...
Освободить место для запуска системы можно ещё и почистив этот кеш и пр. командами
sudo apt clean
sudo apt autoclean
sudo apt autoremove
в принципе можно и без лайффлешки удалить и логи и почистить кеш и всё что угодно поудалять ... зайдя не под графикой а в консоли (зайти по Ctrl+Alt+F1 и залогиниться )
Сотрудник, каким боком к проблеме ТС с отказом загрузки ОС ввибу ортсутствия свободного места из-за разросшихся логов в /var/log ваша ремарка про /tmp ?
ну или ещё вариант - переустановите систему(поставьте снова минт18) и как только "пепельница" заполнится , снова переустановите и поставьте минт19 и так по очереди .и регулярно
"А потом уже в системе править /etc/default/grub
так понятно? "
Этого как раз и непонятно. Я прочитал ссылку на форумы, в общих чертах понял возможную причину, но чисто механически даже не представляю как можно исправить этот файл. Знал бы, задавал в разделе не для чайников.
/var/cache/apt/ не забит. Папка apt/ весит около 700мб. Я не знаю на сколько это много.
Кеш и пр. я почистил программой bleachbit. Насколько качественно, не могу судить из отсутствия знаний. И механически удаляю два этих логфайла. Система работает.
После удаления файла сислог и перезагрузки в этой папке почему то появилось два файла. сислог, 120 Мб который не увеличивается, и сислог 1, который уже весит почти 1гиг и увеличивается. Это нормально, что их теперь 2?
Вариант установки старого минт18 не подходит, потому что глюки начались еще на нем. Правда до умирания системы проходило гораздо больше времени, а я не догадывался в чем дело, просто переустанавливал Минт, пару раз всего было, а постоянно менять 18 и 19 местами и регулярно, это видимо шутка такая любителей линукса. Смешно.
Прочитав форумы по ссылке, понял, что можно заставить ядро перестать обращаться к шине, переписав /grub, тогда эти файлы не будут рости как раковая опухоль.
Если уважаемые спецы помогут переписать этот самый груб, будет отлично, если нет, придется возвращаться к Билу. Потому что времени на доскональное изучение Линукса просто нет, хотя это и интересно...
El2a42
#25
13 фев 2020, 20:44
13 фев 2020, 20:24
ОК. Сейчас попробую, только у меня теперь почему то два сислога, какой из них выкладывать то?
Вот терминал по inxi-Fxz
zog@zog-Default-string:~$ inxi -Fxz
Host: zog-Default-string Kernel: 5.3.0-28-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8
Type: Laptop Mobo: INTEL model: SKYBAY serial: <filter>
UEFI: American Megatrends v: 5.12 date: 11/13/2016
Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Kaby Lake rev: 9 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23199
Speed: 800 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 1640 2: 1339
3: 1755 4: 1735
Device-1: Intel HD Graphics 620 driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1280x1024~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2)
v: 4.5 Mesa 19.2.8 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Device-2: N/A type: USB
driver: hid-generic,snd-usb-audio,usb-storage,usbhid bus ID: 1-4:5
Sound Server: ALSA v: k5.3.0-28-generic
driver: r8169 v: kernel port: e000 bus ID: 01:00.0
Device-2: Broadcom and subsidiaries BCM4322 802.11a/b/g/n Wireless LAN
vendor: Dell driver: wl v: kernel port: e000 bus ID: 02:00.0
Local Storage: total: 119.24 GiB used: 23.32 GiB (19.6%)
ID-1: /dev/sda vendor: Kingston model: RBU-SMS151DS3128GG size: 119.24 GiB
ID-1: / size: 27.38 GiB used: 15.29 GiB (55.9%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 89.09 GiB used: 8.02 GiB (9.0%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 203 Uptime: 58m Memory: 7.69 GiB used: 1.27 GiB (16.5%)
inxi: 3.0.32
El2a42
#26
13 фев 2020, 20:50
Вот сислог который ростет. пока писал сообщение он уже 1.5 гб был 950мб, а кернлог я удалил, делитом. так что его сейчас вообще нет.
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544301] pcieport 0000:00:1c.3: AER: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544303] pcieport 0000:00:1c.3: AER: device [8086:9d13] error status/mask=00000001/00002000
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544304] pcieport 0000:00:1c.3: AER: [ 0] RxErr
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544398] pcieport 0000:00:1c.3: AER: Corrected error received: 0000:00:1c.3
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544402] pcieport 0000:00:1c.3: AER: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544403] pcieport 0000:00:1c.3: AER: device [8086:9d13] error status/mask=00000001/00002000
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544405] pcieport 0000:00:1c.3: AER: [ 0] RxErr
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544466] pcieport 0000:00:1c.3: AER: Corrected error received: 0000:00:1c.3
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544470] pcieport 0000:00:1c.3: AER: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544471] pcieport 0000:00:1c.3: AER: device [8086:9d13] error status/mask=00000001/00002000
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544473] pcieport 0000:00:1c.3: AER: [ 0] RxErr
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544601] pcieport 0000:00:1c.3: AER: Corrected error received: 0000:00:1c.3
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544605] pcieport 0000:00:1c.3: AER: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544607] pcieport 0000:00:1c.3: AER: device [8086:9d13] error status/mask=00000001/00002000
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544608] pcieport 0000:00:1c.3: AER: [ 0] RxErr
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544635] pcieport 0000:00:1c.3: AER: Corrected error received: 0000:00:1c.3
Feb 13 19:48:04 zog-Default-string kernel: [ 315.544639] pcie
#27
13 фев 2020, 21:10
El2a42, 100% ответа я не нашёл. Делать будем следующее , для начала покажи здесь cat /etc/default/grub
El2a42
#28
13 фев 2020, 21:41
13 фев 2020, 21:10
Вот сделал. Ты только имей в виду у меня знаний 0. Хоть напоминай что это в терминале, я то весь корень перерыл в поиске папки cat))))
zog@zog-Default-string:~$ cat /etc/default/grub
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_CMDLINE_LINUX=""
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
#29
13 фев 2020, 21:51
El2a42 писал(а):
13 фев 2020, 21:41
Вариант 1 , эту строку приводим к виду ---- GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pcie_aspm=off"
это делается редактором , в терминале вводим -- sudo xed /etc/default/grub и редактируем. После редактирования выполняем sudo update-grub , перезагружаемся и смотрим , что получилось.
El2a42
#30
13 фев 2020, 21:58
13 фев 2020, 21:51
El2a42 писал(а):
13 фев 2020, 21:41
А в самом редакторе сохранять изменения тоже надо?
#31
13 фев 2020, 22:00
El2a42 писал(а):
13 фев 2020, 21:58
тоже надо?
Ты в танке?
El2a42
#32
13 фев 2020, 22:02
Я изменил строчку. добавил туда все что ты выделил красным. сохранил в этом редакторе, нажал на дискетку. после сохранения в редакторе терминал выдал следубщее
zog@zog-Default-string:~$ sudo xed /etc/default/grub
[sudo] пароль для zog:
** (xed:2412): WARNING **: 21:57:59.108: Set document metadata failed: Установка атрибута metadata::xed-spell-language не поддерживается
** (xed:2412): WARNING **: 21:57:59.108: Set document metadata failed: Установка атрибута metadata::xed-encoding не поддерживается
sudo update-grub
И команда sudo update-grub в нем уже не проходит
El2a42
#33
13 фев 2020, 22:03
13 фев 2020, 22:00
El2a42 писал(а):
13 фев 2020, 21:58
тоже надо?
Ты в танке?
Да, я же этого и не скрываю)))
#34
13 фев 2020, 22:05
El2a42, покажи cat /etc/default/grub
El2a42
#35
13 фев 2020, 22:07
13 фев 2020, 22:05
Вот
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
#36
13 фев 2020, 22:08
El2a42, выполни в терминале sudo update-grub
El2a42
#37
13 фев 2020, 22:12
13 фев 2020, 22:08
Все.Выполнил. Вот что он выдал.
zog@zog-Default-string:~$ sudo update-grub
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/50_linuxmint.cfg'
Sourcing file `/etc/default/grub.d/60_mint-theme.cfg'
Генерируется файл настройки grub …
Найдена тема: /boot/grub/themes/linuxmint/theme.txt
Найден образ linux: /boot/vmlinuz-5.3.0-28-generic
Найден образ initrd: /boot/initrd.img-5.3.0-28-generic
Найден образ linux: /boot/vmlinuz-5.0.0-32-generic
Найден образ initrd: /boot/initrd.img-5.0.0-32-generic
Добавление записи в загрузочное меню для конфигурации с микропрограммой EFI
завершено
#38
13 фев 2020, 22:13
Перезагрузись. Будут ли изменения?
El2a42
#39
13 фев 2020, 22:20
13 фев 2020, 22:13
Перегрузился. В папке var появился файл кернлог 1.5 гига и эти два файла сислог и сислог1, 3 и 1 гига соответственно.
Где еще надо смотреть изменения?
Да и может мне все таки удалить один из файлов сислог? Который побольше, пока система опять не рухнула.
#40
13 фев 2020, 22:22
El2a42, ошибки продолжает сыпать?
