Установка lmde на raid 0
djsantehnik
Благодарил (а): 24 раза
Сообщение djsantehnik » 26 мар 2020, 08:58
Всем не хворать, случилось непонятное. имею два винта (разных) на 80 Гб и решил себя развлечь установкой лмде
простыня
  Host: mint Kernel: 4.19.0-8-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
  Desktop: Cinnamon 4.4.8 Distro: LMDE 4 Debbie base: Debian 10.2 buster
  Type: Desktop Mobo: Gigabyte model: GA-MA74GM-S2H v: x.x serial: <filter>
  BIOS: Award v: F4b date: 11/19/2009
  Topology: Dual Core model: AMD Athlon 64 X2 4800+ bits: 64 type: MCP
  arch: K8 rev.F+ rev: 2 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 svm bogomips: 4028
  Speed: 1000 MHz min/max: 1000/2500 MHz Core speeds (MHz): 1: 1000 2: 1000
  Device-1: AMD RS740 [Radeon 2100] vendor: Gigabyte driver: radeon
  v: kernel bus ID: 01:05.0
  Display: x11 server: X.Org 1.20.4 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1680x1050~60Hz
  OpenGL: renderer: ATI RS740 v: 2.1 Mesa 18.3.6 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus ID: 00:14.2
  Device-2: AMD RS690 HDMI Audio [Radeon Xpress 1200 Series]
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:05.2
  Sound Server: ALSA v: k4.19.0-8-amd64
  vendor: Gigabyte driver: r8169 v: kernel port: de00 bus ID: 02:00.0
  Local Storage: total: 156.55 GiB used: 12.4 MiB (0.0%)
  ID-1: /dev/sda vendor: Samsung model: HD080HJ size: 74.53 GiB temp: 46 C
  ID-2: /dev/sdb vendor: Western Digital model: WD800AAJS-60PSA0
  size: 74.53 GiB temp: 41 C
  ID-3: /dev/sdc type: USB model: USB 2.0 USB Flash Driver size: 7.49 GiB
RAID:
  Hardware-1: Advanced Micro Devices [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA
  Controller [Non-RAID5 mode]
  driver: ahci v: 3.0 bus ID: 00:11.0
  ID-1: / size: 1.40 GiB used: 12.4 MiB (0.9%) fs: overlay source: ERR-102
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 160 Uptime: 5m Memory: 2.80 GiB used: 659.9 MiB (23.0%)
  Init: systemd runlevel: 5 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3
  inxi: 3.0.32
райд сделал с контроллером на матери определяется при загрузке в биосе так
и даже виден в хардвеа детекшен с образа лмде так (другой диск это флешка)
Но вот при установке полезло странное -
Я думал что я увижу один раздел но никак не два - нахожусь взамешательстве
Сообщение symon2014 » 26 мар 2020, 09:16
djsantehnik, ты уверен , что это настоящий аппаратный рейд?
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 09:18
symon2014, да я вообще впервые рейд в жизни мучаю - могу зафотать нутряху биоса
Сообщение symon2014 » 26 мар 2020, 09:20
djsantehnik, не обязательно , я сам рейдами не занимался
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 09:23
symon2014, забыл вот посмотреть что мне гпартед в лмде покажет, надо бы глянуть сколько там разделов ну и фдиск приложить для инфы
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 10:00
дополнительная инфа
mint@mint:~$ sudo fdisk -l
Disk /dev/sda: 74.5 GiB, 80025280000 bytes, 156299375 sectors
Disk model: SAMSUNG HD080HJ
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Disk /dev/sdb: 74.5 GiB, 80026361856 bytes, 156301488 sectors
Disk model: WDC WD800AAJS-60
Disklabel type: dos
Disk identifier: 0x26da043d
Device     Boot Start       End   Sectors  Size Id Type
/dev/sdb1        2048 154296319 154294272 73.6G 83 Linux
Disk /dev/mapper/pdc_cacjgfhji: 149 GiB, 159916228608 bytes, 312336384 sectors
I/O size (minimum/optimal): 65536 bytes / 131072 bytes
19.3 - нормально при установке видит - один большой раздел
(а диски она видит немного иначе - оба отдельных полностью монотонно закрешены - надо зафотаю)
Сообщение symon2014 » 26 мар 2020, 10:02
На 3 скрине похоже он.
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 10:12
symon2014, ну да, в 19,3 так же все (по фактуре) в дисках, но мне бы его в установщике узреть, в 19,3 он в установщике виден один, никаких винчестеров
Сообщение symon2014 » 26 мар 2020, 10:14
В качестве бреда , при загрузке с флешки выбери 2 пункт.
Сообщение rogoznik » 26 мар 2020, 10:15
djsantehnik, а если выбрать "ручная разметка"?
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 10:18
rogoznik, последняя картинка первого поста - как раз она( на следующем этапе там виден один винт и флеха (не в месседже боксе)- тоже никакаких рэйдов) Я предусмотритетельный
забыл - диски полностью пустые, после полного мапа
Решено: 37
Сообщение WWolf » 26 мар 2020, 10:27
а если рэйд1 сделать, что lmde скажет?
Решено: 37
Сообщение WWolf » 26 мар 2020, 10:38
djsantehnik, dmraid=true похоже надо дописать в параметры ядра дебиана что б отдуплился... проверь
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 11:01
symon2014, После этого
в первом варианте имеем рабочий стол - во втором варианте (что предложен) имеем окно из биоса монитора что частоту кажет, ждал минуты три, два раза, на контрл-алт-дел нет реакции, на ребут в системнике тоже нет. быстрое выключение вызывало сбой в рэйде при загрузке, с долгим все ок
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 11:08
rogoznik, второй экран после выбора нет в ручной разметке (да не выбирал - понапишет всякого непонятного мне в рэйд а потом пересобирать его)
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 12:10
WWolf, чет не помогло - ни опции ни рэйд 1. В рэйд 1 есть изменения только при ручной разметке - подряд два окна из первого поста идут (где я нет жму), и в дисках оба винчестера полностью закрашены и рейд 1 там тоже виден на 80 Гб
Чет приуныл :sad:
В 19,3 все как по маслу сходу видно в установщике (рэйд 1 не смотрел)
ни какого уважения у разработчиков к незалежной мове однако
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 13:33
Может кто-нить того тож попробует накатить у себя - будем унывать вместе
Сообщение symon2014 » 26 мар 2020, 14:03
djsantehnik, как только посылка с компом от тебя дойдёт , сразу начну унывать. :-D
djsantehnik
Сообщение djsantehnik » 26 мар 2020, 14:08
symon2014, Могу ещё снега положить
Тут снег, тут столько снега
Что если б я тут не был сам
Я б не поверил, что бывает столько снега
Что земля не видит неба
И звездам не видать с вершин
Как посреди огней вечерних и гудков машин
Мчится тихий огонек моей души
Сообщение slant » 26 мар 2020, 15:42
djsantehnik, так, слушай сюда. Если только материнка не серверная, и не стоит кучи вечнозеленых денег - на ней может быть исключительно софт-рейд. Под линуксом - это лишь источник проблем, т.к. единственное что он делает - вносит дополнительное усложнение в конфигурацию дисков. Потому программный RAID под линуксом надо делать так:
1. Отключаем в биосе использование RAID, переводим диски в обычный режим ACHI.
2. Ставим линукс и делаем рейд средствами установщика системы, либо вручную через mdadm - руководств в сети куча.
Использование функций soft-raid через биос материнки - это раскладывание себе граблей собственными руками. НЕ ИСПОЛЬЗОВАТЬ. Если не хотите потом собственноручно разложенные грабли лбом собирать.
