Nvidia Intel не переключает
32bit
09 мар 2020, 20:14
Имеется такой ноут
  Host: bit-X550CC Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: ASUSTeK product: X550CC v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X550CC v: 1.0 serial: <filter>
  BIOS: American Megatrends v: X550CC.222 date: 02/24/2014
  ID-1: BAT0 charge: 32.1 Wh condition: 32.1/44.6 Wh (72%)
  model: ASUSTeK X550A30 status: Full
  Topology: Dual Core model: Intel Core i3-3217U bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 14368
  Speed: 798 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 848 2: 912
  3: 854 4: 846
  Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: ASUSTeK driver: nvidia v: 390.116 bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.5 driver: modesetting,nvidia
  unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: GeForce GT 720M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
  Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n vendor: Lite-On
  driver: wl v: kernel port: e000 bus ID: 03:00.0
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.2
  IF: enp4s0f2 state: down mac: <filter>
  Local Storage: total: 465.76 GiB used: 36.27 GiB (7.8%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
  ID-1: / size: 96.75 GiB used: 36.27 GiB (37.5%) fs: ext4 dev: /dev/sda5
  System Temperatures: cpu: 56.0 C mobo: N/A gpu: nvidia temp: 52 C
  Fan Speeds (RPM): cpu: 2900
  Processes: 197 Uptime: 7m Memory: 3.31 GiB used: 1.42 GiB (42.9%)
  inxi: 3.0.32
При переключении в NVIDIA-Prime на Intel Steam нормально работает и игры запускаются(тестирую на WoT Blitz)
В PortSteamX64-22 игры запускается и после заставки просто вылетает.
Вот лог с PortSteam
PortWINE был запущен в режиме создания PortSteamX64.log и он успешно сохранен в корне каталога порта
Для диагностики проблем, скопируйте ВЕСЬ лог в комментарии к игре на сайте portwine-linux.ru
PortWINE version:
22
Date and time of start debug for PortSteamX64
Пн мар  9 20:23:01 +04 2020
The installation path of the PortSteamX64:
/home/bit/PortWINE/PortSteamX64/data/scripts
Operating system
ОС:	Linux Mint 19.3 Tricia
Desktop Environment
mate
Kernel
5.0.0-32-generic
CPU
model name	: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
RAM
              всего        занято        свободно      общая  буф./врем.   доступно
Память:        3388        1355         124         150        1907        1601
Подкачка:        2047         171        1876
Graphic cards
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) Ivybridge Mobile
OpenGL core profile version string: 4.2 (Core Profile) Mesa 19.2.8
OpenGL core profile shading language version string: 4.20
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 19.2.8
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 19.2.8
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
Version WINE in the Port
wine-4.0 (Staging)
log WINE
wine: cannot find L"C:\\windows\\system32\\winemenubuilder.exe"
000b:err:wineboot:ProcessRunKeys Error running cmd L"C:\\windows\\system32\\winemenubuilder.exe -a -r" (2)
001a:err:module:import_dll Library mscoree.dll (which is needed by L"C:\\windows\\Microsoft.NET\\Framework64\\v4.0.30319\\mscorsvw.exe") not found
001a:err:module:LdrInitializeThunk Importing dlls for L"C:\\windows\\Microsoft.NET\\Framework64\\v4.0.30319\\mscorsvw.exe" failed, status c0000135
000f:err:service:process_send_command service protocol error - failed to write pipe!
003c:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
0049:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
004e:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/202346.117:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
ATTENTION: default value of option vblank_mode overridden by environment.
0035:err:clipboard:convert_selection Timed out waiting for SelectionNotify event
ATTENTION: default value of option mesa_glthread overridden by environment.
[0309/202356.524:ERROR:network_change_notifier_win.cc(141)] WSALookupServiceBegin failed with: 0
0032:err:ole:CoGetClassObject class {294935ce-f637-4e7c-a41b-ab255460b862} not registered
0032:err:ole:create_server class {294935ce-f637-4e7c-a41b-ab255460b862} not registered
0032:err:ole:CoGetClassObject no class object {294935ce-f637-4e7c-a41b-ab255460b862} could be created for context 0x17
0094:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
009a:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
0085:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
0098:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/202452.588:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0309/202452.589:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
[0309/202453.461:ERROR:network_change_notifier_win.cc(141)] WSALookupServiceBegin failed with: 0
[0309/202453.732:ERROR:gpu_info_collector_win.cc(211)] Creating device info failed
009a:trace:vulkan:DllMain 0x7b970000, 1, (nil)
[0309/202454.397:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
009a:trace:vulkan:DllMain 0x7b930000, 1, (nil)
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr (nil), "vkEnumerateInstanceVersion"
009a:trace:vulkan:wine_vkGetInstanceProcAddr (nil), "vkCreateInstance"
009a:trace:vulkan:wine_vk_get_global_proc_addr Found name="vkCreateInstance" in global table
009a:trace:vulkan:wine_vkCreateInstance create_info 0x35f650, allocator (nil), instance 0x35f694
009a:trace:vulkan:wine_vk_instance_convert_create_info Enabled 0 instance extensions.
009a:trace:vulkan:X11DRV_vkCreateInstance create_info 0x35f5ac, allocator (nil), instance 0x19390c
Xlib:  extension "NV-GLX" missing on display ":0".
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkCreateDevice"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkCreateWin32SurfaceKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkDestroySurfaceKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkEnumerateDeviceExtensionProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkEnumerateDeviceLayerProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkEnumeratePhysicalDeviceGroups"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkEnumeratePhysicalDeviceGroupsKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkEnumeratePhysicalDevices"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceFeatures"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceFeatures2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceFeatures2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceFormatProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceFormatProperties2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceFormatProperties2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceImageFormatProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceImageFormatProperties2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceImageFormatProperties2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceMemoryProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceMemoryProperties2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceMemoryProperties2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceMultisamplePropertiesEXT"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDevicePresentRectanglesKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceProperties2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceProperties2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceQueueFamilyProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceQueueFamilyProperties2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceQueueFamilyProperties2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSparseImageFormatProperties"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSparseImageFormatProperties2"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSparseImageFormatProperties2KHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSurfaceCapabilitiesKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSurfaceFormatsKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSurfacePresentModesKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceSurfaceSupportKHR"
009a:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c859f80, "vkGetPhysicalDeviceWin32PresentationSupportKHR"
009a:err:vulkan:wine_vk_instance_load_physical_devices Failed to enumerate physical devices, res=-3
009a:err:vulkan:wine_vkCreateInstance Failed to load physical devices, res=-3
009a:trace:vulkan:X11DRV_vkDestroyInstance 0x7c859f80 (nil)
c:\buildslave\steam_rel_client_win32\build\src\webhelper\cef_clienthandler.cpp (3314) : Assertion Failed: killing unresponsive browser for URL
[0309/202541.526:WARNING:cert_verify_proc_win.cc(104)] Unknown error -2146762482 mapped to net::ERR_FAILED
009a:trace:vulkan:DllMain 0x7b970000, 0, (nil)
009a:trace:vulkan:DllMain 0x7b930000, 0, 0x1
[0309/202547.737:WARNING:cert_verify_proc_win.cc(104)] Unknown error -2146762482 mapped to net::ERR_FAILED
00f9:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
00ba:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
00d6:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/202602.823:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
[0309/202602.824:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
[0309/202602.827:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
[0309/202604.000:WARNING:ipc_message_attachment_set.cc(49)] MessageAttachmentSet destroyed with unconsumed attachments: 0/1
[0309/202604.000:ERROR:command_buffer_proxy_impl.cc(124)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.
[0309/202604.044:ERROR:command_buffer_proxy_impl.cc(124)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.
[0309/202604.044:WARNING:ipc_message_attachment_set.cc(49)] MessageAttachmentSet destroyed with unconsumed attachments: 0/1
[0309/202604.724:WARNING:cert_verify_proc_win.cc(104)] Unknown error -2146762482 mapped to net::ERR_FAILED
0032:err:ole:RevokeDragDrop invalid hwnd 0x101d2
0140:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
014d:err:ntdll:RtlpWaitForCriticalSection section 0x7bd2e260 "../../../wine/dlls/ntdll/loader.c: loader_section" wait timed out in thread 014d, blocked by 0140, retrying (60 sec)
0156:err:ole:CoGetContextToken apartment not initialised
0157:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Foundation.Diagnostics.AsyncCausalityTracer"
015b:err:d3d:wined3d_swapchain_set_swap_interval wglSwapIntervalEXT failed to set swap interval 1 for context 0x1486c8c0, last error 0x591.
0157:err:wincodecs:PngDecoder_CreateInstance Failed reading PNG because unable to find libpng12.so.0
0157:err:eventlog:ReportEventW L"Application: wotblitz.exe\nFramework Version: v4.0.30319\nDescription: The process was terminated due to an unhandled exception.\nException Info: System.Runtime.InteropServices.COMException\n\nException Info: System.NotSupportedException\n   at System.Windows.Media.Imaging.BitmapDecoder.SetupDecoderF"...
Unhandled Exception: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Windows.Markup.XamlParseException: Provide value on 'System.Windows.Baml2006.TypeConverterMarkupExtension' threw an exception. ---> System.NotSupportedException: No imaging component suitable to complete this operation was found. ---> System.Runtime.InteropServices.COMException: Exception from HRESULT: 0x88982F50
   --- End of inner exception stack trace ---
   at System.Windows.Media.Imaging.BitmapDecoder.SetupDecoderFromUriOrStream(Uri uri, Stream stream, BitmapCacheOption cacheOption, Guid& clsId, Boolean& isOriginalWritable, Stream& uriStream, UnmanagedMemoryStream& unmanagedMemoryStream, SafeFileHandle& safeFilehandle)
   at System.Windows.Media.Imaging.BitmapDecoder.CreateFromUriOrStream(Uri baseUri, Uri uri, Stream stream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy, Boolean insertInDecoderCache)
   at System.Windows.Media.Imaging.BitmapFrame.CreateFromUriOrStream(Uri baseUri, Uri uri, Stream stream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy)
   at System.Windows.Media.ImageSourceConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
   at System.Windows.Baml2006.TypeConverterMarkupExtension.ProvideValue(IServiceProvider serviceProvider)
   at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
   at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
   at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
   at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
   at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
   at FacebookService.FacebookDialog.InitializeComponent()
   at FacebookService.Session..ctor(String appId, String cacheDirectory)
   at DotNetFacebookBridge.CreateSession.<lambda_8ad2907542e6677344e21db823161a19>.()(<lambda_8ad2907542e6677344e21db823161a19>* )
   at detail.lambda_wrapper<<lambda_8ad2907542e6677344e21db823161a19> >.invoke<bool>()
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at System.Windows.Application.Run(Window window)
   at FacebookService.AppContext.Main()
   at FacebookService.AppContext.<StartApp>b__0_0()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ThreadHelper.ThreadStart()
0157:err:seh:raise_exception Unhandled exception code c0000005 flags 0 addr (nil)
0032:err:ole:RevokeDragDrop invalid hwnd 0x50212
При переключении на Nvidia в Steam игры зависает при запуске, в PortSteam вылетает ошибка
render error 01(после 50-ой перезагрузке компа игра стала вылетать после заставки)
вот лог
PortWINE version:
22
Пн мар  9 20:56:03 +04 2020
Operating system
Desktop Environment
mate
Kernel
5.0.0-32-generic
CPU
RAM
Память:        3388        1395         894          47        1097        1723
Подкачка:        2047           0        2047
Graphic cards
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GT 720M/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 390.116
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL version string: 4.6.0 NVIDIA 390.116
OpenGL shading language version string: 4.60 NVIDIA
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 390.116
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
wine-4.0 (Staging)
log WINE
0037:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
0046:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
0040:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/205626.647:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0309/205627.115:ERROR:network_change_notifier_win.cc(141)] WSALookupServiceBegin failed with: 0
0070:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/205628.580:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0309/205628.621:ERROR:gpu_info_collector_win.cc(211)] Creating device info failed
0095:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/205633.277:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
[0309/205633.346:ERROR:network_change_notifier_win.cc(141)] WSALookupServiceBegin failed with: 0
00ad:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/205641.273:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
00be:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/205644.008:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
00be:trace:vulkan:DllMain 0x7b970000, 1, (nil)
00be:trace:vulkan:DllMain 0x7b930000, 1, (nil)
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr (nil), "vkEnumerateInstanceVersion"
00be:trace:vulkan:wine_vkGetInstanceProcAddr (nil), "vkCreateInstance"
00be:trace:vulkan:wine_vk_get_global_proc_addr Found name="vkCreateInstance" in global table
00be:trace:vulkan:wine_vkCreateInstance create_info 0x35f650, allocator (nil), instance 0x35f694
00be:trace:vulkan:wine_vk_instance_convert_create_info Enabled 0 instance extensions.
00be:trace:vulkan:X11DRV_vkCreateInstance create_info 0x35f5ac, allocator (nil), instance 0x19390c
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkCreateDevice"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkCreateWin32SurfaceKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkDestroySurfaceKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkEnumerateDeviceExtensionProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkEnumerateDeviceLayerProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkEnumeratePhysicalDeviceGroups"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkEnumeratePhysicalDeviceGroupsKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkEnumeratePhysicalDevices"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceFeatures"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceFeatures2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceFeatures2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceFormatProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceFormatProperties2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceFormatProperties2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceImageFormatProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceImageFormatProperties2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceImageFormatProperties2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceMemoryProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceMemoryProperties2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceMemoryProperties2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceMultisamplePropertiesEXT"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDevicePresentRectanglesKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceProperties2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceProperties2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceQueueFamilyProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceQueueFamilyProperties2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceQueueFamilyProperties2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSparseImageFormatProperties"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSparseImageFormatProperties2"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSparseImageFormatProperties2KHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSurfaceCapabilitiesKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSurfaceFormatsKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSurfacePresentModesKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceSurfaceSupportKHR"
00be:trace:vulkan:X11DRV_vkGetInstanceProcAddr 0x7c862380, "vkGetPhysicalDeviceWin32PresentationSupportKHR"
00be:err:vulkan:wine_vk_instance_load_physical_devices Failed to enumerate physical devices, res=-3
00be:err:vulkan:wine_vkCreateInstance Failed to load physical devices, res=-3
00be:trace:vulkan:X11DRV_vkDestroyInstance 0x7c862380 (nil)
00be:trace:vulkan:DllMain 0x7b970000, 0, (nil)
00be:trace:vulkan:DllMain 0x7b930000, 0, 0x1
00d9:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
00d3:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
00dc:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
[0309/205646.015:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
[0309/205646.019:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
[0309/205646.048:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: renderer
[0309/205648.372:WARNING:cert_verify_proc_win.cc(104)] Unknown error -2146762482 mapped to net::ERR_FAILED
0117:err:winediag:wined3d_dll_init Setting multithreaded command stream to 0x1.
012f:err:ole:CoGetContextToken apartment not initialised
0130:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Foundation.Diagnostics.AsyncCausalityTracer"
0130:err:wincodecs:PngDecoder_CreateInstance Failed reading PNG because unable to find libpng12.so.0
0130:err:eventlog:ReportEventW L"Application: wotblitz.exe\nFramework Version: v4.0.30319\nDescription: The process was terminated due to an unhandled exception.\nException Info: System.Runtime.InteropServices.COMException\n\nException Info: System.NotSupportedException\n   at System.Windows.Media.Imaging.BitmapDecoder.SetupDecoderF"...
0130:err:seh:raise_exception Unhandled exception code c0000005 flags 0 addr (nil)
0032:err:ole:RevokeDragDrop invalid hwnd 0x501fc
Интересно то, что в логе видеокарта выбрана Intel,а драйвера Nvidia.
Вот с gpu-manager
:~$ gpu-manager
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
can't access /opt/amdgpu-pro/bin/amdgpu-pro-px
Looking for nvidia modules in /lib/modules/5.0.0-32-generic/updates/dkms
Error: can't open /lib/modules/5.0.0-32-generic/updates/dkms
Looking for amdgpu modules in /lib/modules/5.0.0-32-generic/updates/dkms
Is nvidia loaded? yes
Was nvidia unloaded? no
Is nvidia blacklisted? no
Is intel loaded? yes
Is radeon loaded? no
Is radeon blacklisted? no
Is amdgpu loaded? no
Is amdgpu blacklisted? no
Is amdgpu versioned? no
Is amdgpu pro stack? no
Is nouveau loaded? no
Is nouveau blacklisted? yes
Is nvidia kernel module available? no
Is amdgpu kernel module available? no
Vendor/Device Id: 8086:166
BusID "PCI:0@0:2:0"
Is boot vga? yes
Vendor/Device Id: 10de:1140
BusID "PCI:1@0:0:0"
Is boot vga? no
Skipping "/dev/dri/card1", driven by "i915"
Skipping "/dev/dri/card0", driven by "nvidia-drm"
Found "/dev/dri/card1", driven by "i915"
output 0:
	card1-LVDS-1
Number of connected outputs for /dev/dri/card1: 1
Does it require offloading? yes
last cards number = 2
I couldn't open /var/lib/ubuntu-drivers-common/last_gfx_boot for writing.
Error: can't write to /var/lib/ubuntu-drivers-common/last_gfx_boot
Ето лог с gpu-manager
log_file: /var/log/gpu-manager.log
BusID "PCI:0@0:2:0"
Is boot vga? yes
BusID "PCI:1@0:0:0"
Is boot vga? no
output 0:
	card1-LVDS-1
Has amd? no
Has intel? yes
Has nvidia? yes
How many cards? 2
Has the system changed? No
Intel IGP detected
Intel hybrid system
Creating /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
Setting power control to "on" in /sys/bus/pci/devices/0000:01:00.0/power/control
Я так понимаю хоть NVIDIA и работает игры запускаются все равно с Intel.
Драйвера Nvidia 390 запустились только из Synaptic и только 390, остальные не работают(пробывал около 50-ти способов и драйверов).
С неофициального PPA не работают.
Nouveau в blacklist добавлен.
32-х битные библиотеки NVIDIA добавлены
Архитектура i386 добавлена
На Mint Sonya 32бит с драйверами Nvidia 384 все нормально работало и переключалось.
Запуск Steam командой "STEAM_RUNTIME=0 steam" не помогает. Ничего не меняется.
Вывода команд:
~$ lspci -knn | grep -EA2 'VGA|3D'
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09)
	Subsystem: ASUSTeK Computer Inc. 3rd Gen Core processor Graphics Controller [1043:124d]
	Kernel driver in use: i915
01:00.0 3D controller [0302]: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] [10de:1140] (rev a1)
	Subsystem: ASUSTeK Computer Inc. GeForce GT 720M [1043:124d]
	Kernel driver in use: nvidia
~$ lsmod | grep nvidia
nvidia_uvm            761856  0
nvidia_drm             45056  3
nvidia_modeset       1048576  3 nvidia_drm
nvidia              14381056  189 nvidia_uvm,nvidia_modeset
drm_kms_helper        180224  2 nvidia_drm,i915
drm                   483328  6 drm_kms_helper,nvidia_drm,i915
ipmi_msghandler       102400  2 ipmi_devintf,nvidia
nvidia-smi
Mon Mar  9 21:11:14 2020
| NVIDIA-SMI 390.116                Driver Version: 390.116                   |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GT 720M     Off  | 00000000:01:00.0 N/A |                  N/A |
| N/A   50C    P0    N/A /  N/A |    142MiB /  1985MiB |     N/A      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0                    Not Supported                                       |
~$ dpkg -l | grep -i nvidia
ii  libnvidia-cfg1-390:amd64                   390.116-0ubuntu0.18.04.3                         amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.116-0ubuntu0.18.04.3                         all          Shared files used by the NVIDIA libraries
ii  libnvidia-common-410                       410.104-0ubuntu0~18.04.1                         all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.116-0ubuntu0.18.04.3                         amd64        NVIDIA libcompute package
ii  libnvidia-compute-390:i386                 390.116-0ubuntu0.18.04.3                         i386         NVIDIA libcompute package
rc  libnvidia-compute-415:amd64                415.27-0ubuntu0~gpu18.04.2                       amd64        NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.116-0ubuntu0.18.04.3                         amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-390:i386                  390.116-0ubuntu0.18.04.3                         i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.116-0ubuntu0.18.04.3                         amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-390:i386                  390.116-0ubuntu0.18.04.3                         i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.116-0ubuntu0.18.04.3                         amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-390:i386                    390.116-0ubuntu0.18.04.3                         i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.116-0ubuntu0.18.04.3                         amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-390:i386                      390.116-0ubuntu0.18.04.3                         i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.116-0ubuntu0.18.04.3                         amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-390:i386                    390.116-0ubuntu0.18.04.3                         i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-390                   390.116-0ubuntu0.18.04.3                         amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.116-0ubuntu0.18.04.3                         amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.116-0ubuntu0.18.04.3                         amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.116-0ubuntu0.18.04.3                         amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.116-0ubuntu0.18.04.3                         amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8.2                                          all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                            390.77-0ubuntu0.18.04.1                          amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-390                           390.116-0ubuntu0.18.04.3                         amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-nvidia-390              390.116-0ubuntu0.18.04.3                         amd64        NVIDIA binary Xorg driver
Как сделать чтобы игры запускались с Nvidia?
32bit
09 мар 2020, 20:24
Нашел где то в описании ноутбука
GF117 не предлагает выделенных графических портов, поэтому может быть использован с технологией Optimus. Как и вся линейка карт 700М, GT 720M поддерживает технологию GPU Boost 2.0, которая может автоматически разогнать видеокарту, если не наблюдается перегрева. Поэтому стоит обратить внимание на размеры ноутбука и качество системы охлаждения.
Теоретически если отключить gpu-manager то можно запустить bumblebee?. Или на Linux Mint 19 он не запустится? А то мануалы по установки все староваты и для Mint 18
Решено: 36
09 мар 2020, 20:35
Не логичнее это спросить у создателя? portwine-linux.ru
как минимум из лога видно что не стоят зависимости...
32bit
09 мар 2020, 20:39
09 мар 2020, 20:35
Что-то мне подсказывает, если я у него спрошу почему игры запускаются в Linux Steam с Intel, то он отправит на этот форум
32bit
09 мар 2020, 20:40
У меня задача запустить в нативном Steam. Просто его лог не пишет ошибок
Решено: 36
09 мар 2020, 20:43
32bit, ну как минимум логично... если они на базе его сборки бутылки пытаются что-то запустить, то вопросы к ним, а не к нему :)
но я б на твоём месте начал бы с какого перепуга у тебя не ставятся другие версии дров...
опять же не стоит nouvea дрова скидывать со счёта, как по мне, так они лучше себя показывают чем nvidia на 750M карте
32bit
09 мар 2020, 20:54
Когда стояла Mint Sonya 32bit все работало и с Nvidia и с nouveau. Но с nouveau производительность было ниже заметно, поэтому со счета я их скидываю. Я 3 недели пытался запустить разные драйвера и только 390 запустились нормально, поэтому не хочется их менять. Да я думаю что и не в версии драйвера дела, а в том что c Intel в реальности не переключатся. В биосе Intel не отключается(нет такой настройки). EFI отключен
32bit
09 мар 2020, 20:56
Лог с PortSteam выложил для общей информации, потому что только в нем видно что игры пытается запустится с Intel и драйверами nvidia
Решено: 36
09 мар 2020, 21:00
32bit, глупый вопрос, но ребут делал после смены intel/nvidia...
32bit писал(а):
09 мар 2020, 20:54
хз как на 32, но на 64 я кроме меньшего нагрева на nouveau не заметил разницы...
32bit
09 мар 2020, 21:03
Делал и завершение сеанса и ребут. С драйверами nouveau тоже не запускается, но логов уже нету, давно было
09 мар 2020, 21:26
32bit писал(а):
09 мар 2020, 20:54
Если лениво следить за прогрессом. То вернуться к Соньке и радоваться жизни
32bit
09 мар 2020, 21:27
Жаль только Steam не работает в 32bit. Я поэтому и ушел с нее
Вернуться в «Видеокарты»
Сейчас этот форум просматривают: doctor2012 и 1 гость
