Не работает WiFi: как поставить драйвера?
Leo3912
Благодарил (а): 4 раза
#61
12 янв 2020, 13:18
Белый Кролик писал(а):
12 янв 2020, 12:59
Попробуй установить ядро 4.13.0-36-generic и загрузиться с ним.
На этом ядре остальное оборудование хорошо работает?
leo@Notebook ~ $ inxi -Fxz
System:    Host: Notebook Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18 Sarah
Machine:   System: Hewlett-Packard (portable) product: HP 655 Notebook PC v: 0884120000005B10002600010
           Mobo: Hewlett-Packard model: 1885 v: 66.33
           Bios: Insyde v: F.23 date: 11/17/2012
CPU:       Dual core AMD E1-1200 APU with Radeon HD Graphics (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4a ssse3 svm) bmips: 5589
           clock speeds: max: 1400 MHz 1: 1400 MHz 2: 1166 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 7310]
           bus-ID: 00:01.0
           Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@59.64hz
           GLX Renderer: Gallium 0.4 on AMD PALM (DRM 2.43.0, LLVM 3.8.0)
           GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Wrestler HDMI Audio
           driver: snd_hda_intel bus-ID: 00:01.1
           Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
           Card-2: Ralink RT3290 Wireless 802.11n 1T/1R PCIe
           driver: rt2860 bus-ID: 04:00.0
           IF: rename3 state: down mac: <filter>
Drives:    HDD Total Size: 120.0GB (23.1% used)
           ID-1: /dev/sda model: WDC_WDS120G2G0A size: 120.0GB
Partition: ID-1: / size: 99G used: 15G (16%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 12.45GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 68.6C mobo: N/A gpu: 68.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 231 Uptime: 25 min Memory: 736.2/11608.4MB
           Client: Shell (bash 4.3.421) inxi: 2.2.35
leo@Notebook ~ $
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
#62
12 янв 2020, 13:21
Leo3912, вряд ли хуже. Но уже поздно, лучше это было делать на чистой системе.
Белый Кролик
Решено: 10
#63
12 янв 2020, 13:30
Leo3912 писал(а):
12 янв 2020, 13:05
Что мне надо ввести вместо WIRELESSCARD?
rt3290 или RT3290
#64
12 янв 2020, 13:33
12 янв 2020, 13:30
rt3290 или RT3290
Кролики это не только ценный мех. :acute:
wlo1
Leo3912
#65
12 янв 2020, 13:34
12 янв 2020, 13:30
Leo3912 писал(а):
12 янв 2020, 13:05
rt3290 или RT3290
В обоих случаях пишет нет такого устройства:
leo@Notebook ~ $ sudo ifconfig rt3290 up
[sudo] пароль для leo:
rt3290: ОШИБКА при получении флагов интерфейса: Нет такого устройства
leo@Notebook ~ $ sudo ifconfig RT3290 up
RT3290: ОШИБКА при получении флагов интерфейса: Нет такого устройства
leo@Notebook ~ $
Leo3912
#66
12 янв 2020, 13:36
12 янв 2020, 13:33
12 янв 2020, 13:30
rt3290 или RT3290
wlo1
Не выходит:
leo@Notebook ~ $ sudo ifconfig wlo1 up
wlo1: ОШИБКА при получении флагов интерфейса: Нет такого устройства
leo@Notebook ~ $
Последний раз редактировалось пользователем 1 Leo3912; всего редактировалось раз: 12
#67
12 янв 2020, 13:37
и снова lshw -c net
Leo3912
#68
12 янв 2020, 13:40
12 янв 2020, 13:37
и снова lshw -c net
leo@Notebook ~ $ sudo lshw -c net
  *-network
       описание: Ethernet interface
       продукт: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       производитель: Realtek Semiconductor Co., Ltd.
       физический ID: 0
       сведения о шине: pci@0000:03:00.0
       логическое имя: eno1
       версия: 07
       серийный №: 38:ea:a7:fa:ce:c9
       capacity: 1Gbit/s
       разрядность: 64 bits
       частота: 33MHz
       возможности: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       конфигурация: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.88.152 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       ресурсы: IRQ:25 ioport:2000(размер=256) память:f0004000-f0004fff память:f0000000-f0003fff
  *-network ВЫКЛЮЧЕНО
       описание: Беспроводной интерфейс
       продукт: RT3290 Wireless 802.11n 1T/1R PCIe
       производитель: Ralink corp.
       физический ID: 0
       сведения о шине: pci@0000:04:00.0
       логическое имя: rename3
       версия: 00
       разрядность: 32 bits
       частота: 33MHz
       возможности: pm msi pciexpress bus_master cap_list ethernet physical wireless
       конфигурация: broadcast=yes driver=RALINK WLAN latency=0 multicast=yes wireless=Ralink STA
       ресурсы: IRQ:23 память:f0110000-f011ffff
leo@Notebook ~ $
#69
12 янв 2020, 13:41
Leo3912 писал(а):
12 янв 2020, 13:40
Leo3912
#70
12 янв 2020, 13:46
12 янв 2020, 13:41
Leo3912 писал(а):
12 янв 2020, 13:40
leo@Notebook ~ $ sudo ifconfig rename3 up
leo@Notebook ~ $ sudo service network-manager restart
leo@Notebook ~ $
После этого WiFi появился на полной мощности (хотя так еще не было). УРА!!! :yahoo: :tux:
Теперь надо проверить будет ли обрываться и глючить (но скорее всего нет). Если будет, я скажу.
Спасибо!
#71
12 янв 2020, 13:48
Leo3912 писал(а):
12 янв 2020, 13:46
Сетевик я не очень , не знаю будет ли это работать после ребута или обновления ядра.
Leo3912
#72
12 янв 2020, 14:05
12 янв 2020, 13:48
Leo3912 писал(а):
12 янв 2020, 13:46
Еще рекомендуется сделать следующее:
поместить эти 2 строки внутри строки /etc/rc.local«exit 0», чтобы интерфейс автоматически включался.
открыл этот файл и вот его содержимое:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
Куда конкретно вбить эти две строчки?
(источник: https://askubuntu.com/questions/253632/ ... rd-working)
#73
12 янв 2020, 14:11
Leo3912, если ты заметил , ссылка со статьёй более чем шестилетней давности. И это может оказаться костыльным и не рабочим решением. Сделай бэкап системы и продолжай эксперименты. :hoho:
Leo3912
#74
12 янв 2020, 14:30
12 янв 2020, 14:11
Изменил содержимое файла до такого состояния:
#!/bin/sh -e
# rc.local
# value on error.
# bits.
exit 0
Теперь при включении wifi появляется автоматически.
