Гибридное видео на ASUS TUF FX705DD-AU086
tonythecat
Благодарил (а): 3 раза
02 дек 2019, 14:58
Всем привет.
Инфо о моем железе и ОСи: https://termbin.com/554m
System:    Host: tony-TUF-Gaming-FX705DD-FX705DD Kernel: 4.15.0-70-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
           Desktop: Cinnamon 4.2.4 Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine:   Type: Laptop System: ASUSTeK product: TUF Gaming FX705DD_FX705DD v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: FX705DD v: 1.0 serial: <filter> UEFI [Legacy]: American Megatrends v: FX705DD.306
           date: 07/12/2019
Battery:   ID-1: BAT0 charge: 40.9 Wh condition: 62.4/67.0 Wh (93%) model: FX70542 status: Discharging
CPU:       Topology: Quad Core model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
           arch: Zen rev: 1 L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36726
           Speed: 1510 MHz min/max: 1400/2300 MHz Core speeds (MHz): 1: 2116 2: 2319 3: 1231 4: 1341 5: 2036
           6: 2099 7: 1601 8: 1597
Graphics:  Device-1: NVIDIA vendor: ASUSTeK driver: nvidia v: 435.21 bus ID: 01:00.0
           Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: N/A bus ID: 05:00.0
           Display: x11 server: X.Org 1.19.6 driver: ati,fbdev,nouveau,nvidia unloaded: modesetting,radeon,vesa
           resolution: 1920x1080~77Hz
           OpenGL: renderer: llvmpipe (LLVM 8.0 128 bits) v: 3.3 Mesa 19.0.8 direct render: Yes
Audio:     Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 01:00.1
           Device-2: Advanced Micro Devices [AMD] vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 05:00.6
           Sound Server: ALSA v: k4.15.0-70-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
           v: 2.3LK-NAPI port: e000 bus ID: 02:00.0
           Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: N/A
           port: c000 bus ID: 04:00.0
Drives:    Local Storage: total: 238.47 GiB used: 16.73 GiB (7.0%)
           ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ3 size: 238.47 GiB
Partition: ID-1: / size: 233.73 GiB used: 16.73 GiB (7.2%) fs: ext4 dev: /dev/nvme0n1p1
Sensors:   System Temperatures: cpu: 41.2 C mobo: N/A
Info:      Processes: 239 Uptime: 22m Memory: 15.54 GiB used: 2.10 GiB (13.5%) Init: systemd runlevel: 5
           Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Проблема: не работает выход HDMI (не обнаруживается подключенный внешний монитор). Кабель и сам монитор проверены - все ок.
Предполагаю, что дело в гибридной графике - сейчас работает интегрированная карточка, которая не выдает видеосигнал на HDMI выход.
Буду крайне признателен за помощь.
Спасибо.
Решение tonythecat » 04 дек 2019, 15:08
UPDATE: Проблему удалось решить!!!
Решение тут: https://egpu.io/forums/thunderbolt-linu ... your-egpu/
Работает на Ubuntu 19, но должно и на LM. Есть второй такой же ноутбук, буду накатывать на него LM 19 и пробовать данное решение. Отпишусь.
Всем неравнодушным спасибо!
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 2
Причина: bbcode
Real
04 дек 2019, 10:39
"Апну" тему. Странно, что никто не ответил.
Моя версия причины: ядро Kernel: 4.15.0-70-generic ничего не знает об этом железе.
04 дек 2019, 10:51
Ну ядро тучно нужно апнуть до 5 ветки. 5.4 как раз релизнулось.
tonythecat
04 дек 2019, 12:25
Спасибо за ответ.
Ядро, естественно, апнуто до 5.4.
04 дек 2019, 12:31
tonythecat, а какому выводу inxi -Fxz верить.
То что по ссылке отличается от того что ты под спойлер положил
tonythecat
04 дек 2019, 13:12
Сорри за дезинформацию, между этими выхлопами эксперементировал с разными дровами и PRIME.
Железо одно и то же.
Сейчас накатил чистую Ubuntu 19. Привожу текущий выхлоп с Ubuntu 19.
  Host: workstation Kernel: 5.3.0-24-generic x86_64 bits: 64 compiler: gcc
  v: 9.2.1 Desktop: Gnome 3.34.1 Distro: Ubuntu 19.10 (Eoan Ermine)
  serial: <filter>
  UEFI [Legacy]: American Megatrends v: FX705DD.306 date: 07/12/2019
  ID-1: BAT0 charge: 62.5 Wh condition: 62.5/67.0 Wh (93%) model: FX70542
  status: Full
  bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 36732
  Speed: 1350 MHz min/max: 1400/2300 MHz Core speeds (MHz): 1: 1233 2: 1235
  3: 1296 4: 1282 5: 1234 6: 1277 7: 1242 8: 1228
  Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] vendor: ASUSTeK
  Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
  bus ID: 05:00.0
  Display: x11 server: X.Org 1.20.5 driver: amdgpu,ati
  unloaded: fbdev,modesetting,nouveau,nvidia,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD RAVEN (DRM 3.33.0 5.3.0-24-generic LLVM 9.0.0)
  v: 4.5 Mesa 19.2.1 direct render: Yes
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  Sound Server: ALSA v: k5.3.0-24-generic
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
  vendor: AzureWave driver: rtl8821ce v: v5.2.5.2.1_xxxx.20181112_beta
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 238.47 GiB used: 8.70 GiB (3.6%)
  ID-1: / size: 233.73 GiB used: 8.70 GiB (3.7%) fs: ext4
  dev: /dev/nvme0n1p1
  System Temperatures: cpu: 46.8 C mobo: N/A gpu: amdgpu temp: 46 C
  Fan Speeds (RPM): cpu: 0
  Processes: 318 Uptime: 2m Memory: 15.51 GiB used: 1.51 GiB (9.7%)
  Init: systemd runlevel: 5 Compilers: gcc: 9.2.1 Shell: bash v: 5.0.3
  inxi: 3.0.36
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 4
Причина: bbcode
04 дек 2019, 13:20
tonythecat, По идее, в таких конфигурациях выводом на экран занимается интегрированная видяха.
Давай сделаем так - сделай это Утилита-агрегатор логов и сведений о системе - hw-probe с подключенным внешним моником и без него. Обе ссылки сюда. Там будут должны будут собраться нужные логи
tonythecat
04 дек 2019, 14:42
Не вполне понял свою оплошность касательно bbcode, прошу пояснить. Предложенную тему изучу, спасибо.
По сабжу:
С монитором: https://linux-hardware.org/?probe=23a1815d83
Без монитора: https://linux-hardware.org/?probe=fa5bcf6e91
tonythecat
04 дек 2019, 15:08
04 дек 2019, 16:08
tonythecat, на LM 19.x должно работать, т.к. в упомянутом ppa по ссыке есть пакеты для ubuntu 18.04, а LM 19.x на ней основан
Вернуться в «Видеокарты»
