System: Host: Monoblok Kernel: 5.0.0-29-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.4 Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic Machine: Type: Desktop System: Acer product: Aspire Z5763 v: N/A serial: <filter> Mobo: Acer model: Aspire Z5763 serial: <filter> BIOS: American Megatrends v: P01-B3 date: 07/22/2011 Battery: Device-1: hidpp_battery_0 model: Logitech K800 charge: 70% status: Discharging CPU: Topology: Quad Core model: Intel Core i7-2600S bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L2 cache: 8192 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44698 Speed: 1645 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 2329 2: 2312 3: 3251 4: 2683 5: 3095 6: 2281 7: 3182 8: 2038 Graphics: Device-1: NVIDIA GF108 [GeForce GT 530] vendor: PC Partner Limited / Sapphire driver: nvidia v: 390.116 bus ID: 01:00.0 Display: x11 server: X.Org 1.19.6 driver: nvidia unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz OpenGL: renderer: GeForce GT 530/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116 direct render: Yes Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Device-2: NVIDIA GF108 High Definition Audio vendor: PC Partner Limited / Sapphire driver: snd_hda_intel v: kernel bus ID: 01:00.1 Device-3: Philips s SAA7231 vendor: Avermedia driver: N/A bus ID: 03:00.0 Device-4: Chicony type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-1.5:6 Sound Server: ALSA v: k5.0.0-29-generic Network: Device-1: Intel 82579V Gigabit Network vendor: Acer Incorporated ALI driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0 IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter> Device-2: Realtek RTL8191SU 802.11n WLAN Adapter type: USB driver: r8712u bus ID: 2-1.8:7 IF: wlx68a3c4e668a7 state: down mac: <filter> Drives: Local Storage: total: 1.03 TiB used: 630.19 GiB (60.0%) ID-1: /dev/sda vendor: Hitachi model: HDS721010CLA332 size: 931.51 GiB ID-2: /dev/sdb vendor: Plextor model: PX-128M5Pro size: 119.24 GiB Partition: ID-1: / size: 36.76 GiB used: 11.57 GiB (31.5%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 60.95 GiB used: 32.40 GiB (53.2%) fs: ext4 dev: /dev/sda7 ID-3: swap-1 size: 7.63 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6 Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 69 C Fan Speeds (RPM): N/A gpu: nvidia fan: 46% Info: Processes: 268 Uptime: 2h 38m Memory: 7.77 GiB used: 3.45 GiB (44.4%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Переназначение клавиши
LM 19.2 x64 Cinnamon. Необходимо переназначить клавишу Tab (не работает) на клавишу F1. ОГРОМНАЯ просьба не предлагать купить новую клавиатуру, погуглить в инете, ссылки где можно посмотреть (почитать, узнать поподробнее, есть что-то похожее и пр. и др., попробовать сделать то-то и так-то). Нужно именно решение, которое предварительно было опробовано на вашем компьютере и 101% работает, причем по пунктам, что и как писать в терминале
Васи Лиса, сложно удержаться - купи новую клавиатуру
А гуглить надо учиться.
По теме - читай, изучай, делай. 100% рабочий способ - только что проверил у себя
System: Host: darkfenix-Aspire-V3-372 Kernel: 5.3.0-19-generic x86_64 bits: 64 Desktop: KDE Plasma 5.17.1
Distro: Ubuntu 19.10 (Eoan Ermine)
darkfenix, гуглить умеем, эта статья давным давно прочитана, как и масса других и статей и псевдоспособов помочь. Клавиатура дорогая, от слова ОЧЕНЬ. Решения вы не привели и у себя его не пробовали. Не давайте ссылки на другие якобы решения. Переназначьте сначала у себя Tab на F1, а потом напишите, что и как вводили в терминале
Васи Лиса, ты читать для начала научись
По ссылке все написано что нужно сделать. Думать за тебя никто не будет.
Васи Лиса, Девочка, здесь не платная техподдержка, и даже не официальный форум дистрибутива. Тебе никто ничего здесь не должен, кашку разжевывать - тоже. Такие требования (в подобной форме) с твоей стороны неуместны. Нет желания решать проблему самостоятельно, или хотя бы помогать другим найти решение для тебя - вызови специалиста и заплати ему за работу.
А здесь, на этом ресурсе - предполагается взаимный обмен знаниями и помощью, а не "кормежка" лентяев (или троллей).
Васи Лиса, ты прикалываешься что ли. Я для кого написал то
Я переназначил клавишу. Проверил что работает и только после этого написал пост. Если тебе мозгов не хватает чтоб воспользоваться указанными там утилитами - я тут не при чем. Иди маме поплачь в передник что тут все плохие.
Васи Лиса, для особо одаренных
Если посмотришь на виртуальную клавиатуру то видно какие клавиши наживаются. И даже видно что "F1" переназначена на TAB.
darkfenix, вижу. Что вводить в терминале? Ссылку на другие ресурсы не предлагайте
Требующим готовое решение, и только его - не помогаю принципиально. Мне такие не интересны. Вот с тем кто хочет учиться и узнавать новое, чтобы потом применять самостоятельно - тем готов помогать.
slant , хочу узнать новое, как переназначить Tab на F1, чтобы потом применять самостоятельно. Зачем пишите, если не можете помочь. Если можете, то напишите решение. Просьба была именно о РЕШЕНИИ, а не о ваших предпочтениях
Васи Лиса, Так как я все-же стараюсь верить в людей: http://maddog.sitengine.ru/smart-question-ru.html
Прочтите, подумайте, примерьте на свое поведение. Надеюсь станет понятно, почему вас так воспринимают.
slant, это не помогло переназначить Tab на F1. Если не можете помочь, не засоряйте эфир
Кстати, так как ваша "дорогая клавиатура" - это Logitech K800, даю подсказку, почему предложенный вам метод не сработал. У данной модели функциональные клавиши Fx совмещены с расширенными Fn. Потому не выдают стандартных сканкодов. Что именно выдают вместо них - logitech его знает, у меня этой модели под рукой нету чтоб посмотреть.
Bums, я сначала очистил содержимое
slant, хм, но я то это проделала на ноутбуке, F1 конечно не совмещена с Fn, но
.Xmodmap
, затем прочитал его - эффекта не принесло. Завершил сеанс, снова залогинился - кнопка стала работать как было.slant, хм, но я то это проделала на ноутбуке, F1 конечно не совмещена с Fn, но
xev
нормально определяет и остальные функциональные клавиши, совмещенные с FnКто сейчас на конференции
