при загрузке mint и запуске gparted не видит ssd.
linuxmint-19.1-xfce-64bit
Записывал флешку, через Ultra iso, и Rufus. Записывал и mbr и gpt. Безрезультатно.
в этом тонком клиенте, ssd установлен через переходил m2.
ниже скрин
Topology: Dual Core model: Pentium T4500 bits: 64 type: MCP arch: Penryn
rev: A L2 cache: 1024 KiB bogomips: 9176
Speed: 1197 MHz min/max: 1200/2300 MHz Core speeds (MHz): 1: 1197 2: 1197
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca
mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
pti rep_good sep ss sse sse2 ssse3 syscall tm tm2 tsc vme xsave xtpr
Host: h-Lenovo-G550 Kernel: 4.15.0-47-generic x86_64 bits: 64
compiler: gcc v: 7.3.0 Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 20023 v: Lenovo G550 serial: <filter>
Mobo: LENOVO model: NITU1 v: REFERENCE serial: <filter> BIOS: LENOVO
v: 18CN46WW(V2.55) date: 05/21/2010
ID-1: BAT1 charge: 52.7 Wh condition: 52.7/52.7 Wh (100%)
model: LG PABAS024 status: Unknown
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 9176
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express v: 2.1 Mesa 18.2.8
Device-1: Intel 82801I HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k4.15.0-47-generic
Device-1: Broadcom and subsidiaries BCM4312 802.11b/g LP-PHY driver: wl
v: kernel port: 1c00 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: 2.3LK-NAPI port: 3000 bus ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-3: Ralink RT2870/RT3070 Wireless Adapter type: USB
driver: rt2800usb bus ID: 2-1:2
IF: wlxa0f3c11c37d7 state: down mac: <filter>
Local Storage: total: 119.24 GiB used: 18.20 GiB (15.3%)
ID-1: /dev/sda vendor: OCZ model: VERTEX4 size: 119.24 GiB
ID-1: / size: 29.67 GiB used: 18.20 GiB (61.3%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 159 Uptime: 10m Memory: 5.76 GiB used: 1.12 GiB (19.4%)
inxi: 3.0.27
Error 22: Unsupported option: -XZ
Check -h for correct parameters.
System: Host: h-Lenovo-G550 Kernel: 4.15.0-47-generic x86_64 bits: 64 compiler: gcc v: 7.3.0 Desktop: MATE 1.20.1
Machine: Type: Laptop System: LENOVO product: 20023 v: Lenovo G550 serial: <root required>
Mobo: LENOVO model: NITU1 v: REFERENCE serial: <root required> BIOS: LENOVO v: 18CN46WW(V2.55) date: 05/21/2010
Battery: ID-1: BAT1 charge: 52.7 Wh condition: 52.7/52.7 Wh (100%) model: LG PABAS024 status: Unknown
CPU: Topology: Dual Core model: Pentium T4500 bits: 64 type: MCP arch: Penryn rev: A L2 cache: 1024 KiB
Graphics: Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express v: 2.1 Mesa 18.2.8 direct render: Yes
Audio: Device-1: Intel 82801I HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Network: Device-1: Broadcom and subsidiaries BCM4312 802.11b/g LP-PHY driver: wl v: kernel port: 1c00 bus ID: 04:00.0
IF: wlp4s0 state: up mac: 00:26:82:da:26:56
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: 2.3LK-NAPI port: 3000
bus ID: 07:00.0
IF: enp7s0 state: down mac: 88:ae:1d:dd:54:cc
Device-3: Ralink RT2870/RT3070 Wireless Adapter type: USB driver: rt2800usb bus ID: 2-1:2
IF: wlxa0f3c11c37d7 state: down mac: a0:f3:c1:1c:37:d7
Drives: Local Storage: total: 119.24 GiB used: 18.22 GiB (15.3%)
Partition: ID-1: / size: 29.67 GiB used: 18.22 GiB (61.4%) fs: ext4 dev: /dev/sda5
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A
Info: Processes: 163 Uptime: 14m Memory: 5.76 GiB used: 1.14 GiB (19.7%) Init: systemd runlevel: 5 Compilers: gcc: 7.3.0
Shell: bash v: 4.4.19 inxi: 3.0.27
если F большая, уходит в перезагрузку. без сообщений и т.п.
В смысле??? Набираешь в терминале
, жмакаешь enter и комп уходит в ребут?абсолютно точно.darkfenix писал(а): ↑17 июн 2019, 12:22hellonet, ох как я золБегом изучать Панель форматирования текста в темах/ответах
В смысле??? Набираешь в терминалеinxi -Fxz
У меня это было не для применения кода, а лишь для иллюстрации того, что я понял разницу между строчными и заглавными буквами в Linux. Там вообще можно было скриншот упрятать за спойлер - чисто иллюстрация. Как то так, но всё равно спасибо за напоминание
AHCI, там только.
