Проблема при установке и настройке ftp сервера
scorpionhitech
Благодарил (а): 2 раза
08 янв 2019, 20:59
Всем доброго времени суток Есть комп с такой конфигурацией
Железо
Host: uliy-Mint-Mate Kernel: 4.15.0-43-generic x86_64 bits: 64
compiler: gcc v: 7.3.0 Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Desktop Mobo: ASUSTeK model: P8H77-M LE v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1501 date: 06/20/2014
Topology: Dual Core model: Intel Pentium G620 bits: 64 type: MCP
arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 10376
Speed: 1596 MHz min/max: 1600/2600 MHz Core speeds (MHz): 1: 1596 2: 1596
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Desktop v: 3.3 Mesa 18.0.5
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK ASUS P8Z77-V LX driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-2: Logitech type: USB driver: snd-usb-audio,uvcvideo bus ID: 3-2:2
Sound Server: ALSA v: k4.15.0-43-generic
vendor: ASUSTeK P8 series driver: r8169 v: 2.3LK-NAPI port: e000
bus ID: 03:00.0
Device-2: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: d000 bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Local Storage: total: 1.80 TiB used: 855.34 GiB (46.4%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
ID-2: /dev/sdb vendor: Western Digital model: WD1600AAJS-00PSA0
ID-3: /dev/sdc vendor: Hitachi model: HDT725032VLA360 size: 298.09 GiB
ID-4: /dev/sdd vendor: Western Digital model: WD5000AZRX-00A8LB0
ID-1: / size: 91.17 GiB used: 9.47 GiB (10.4%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 100.23 GiB used: 13.03 GiB (13.0%) fs: ext4
dev: /dev/sda4
ID-3: swap-1 size: 4.66 GiB used: 1002.7 MiB (21.0%) fs: swap
dev: /dev/sda2
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 207 Uptime: 4h 17m Memory: 3.73 GiB used: 1.52 GiB (40.7%)
inxi: 3.0.27
Ранее на нём была установлена Win 10 x64. После последнего сбоярешил переустановить систему и столкнулся с тем, что винду поставить не смог (выдает ошибку при установке 0x8007025d ), а LM 19.1 х64 поставил без проблем. Вот только уже целый день не могу поставить фтп сервер. Всё что нахожу, все установки и настройки через консоль. На винде использовал Filezilla server. Но к сожалению для минт его не существует, а через wine - извращение. Цель - доступ к папкам для двух пользователей, одному доступ только к корневой папке, а другому - доступ к нескольким на разных дисках. Существует ли фтп сервер для линукс с графической оболочкой и нужным функционалом? Спасибо за ответ.
08 янв 2019, 21:07
Есть GAdmin например. Но зачем? Использование ФТП в наши времена приравнивается к половым извращениям
08 янв 2019, 21:15
Крайне рекомендую отправить FTP в архивы истории, где ему давно место. Сейчас есть множество более простых, надежных, и безопасных решений. В частности, лучше сразу перейти на ssh (sftp для обмена файлами).
scorpionhitech
08 янв 2019, 21:49
di_mok писал(а):
08 янв 2019, 21:07
Подскажите пожалуйста как реализовать без фтп?
08 янв 2019, 22:13
scorpionhitech, тут задачу бы поточнее сформулировать. Способов тыща: облака (как свои, так и дядины), синхронизация (как централизованная, так и децентрализованная), банальная Samba через VPN, выше slant SFTP предлагал...
О! Вот еще SSHFS как вариант
Whowka
Благодарил (а): 777 раз
08 янв 2019, 22:46
Эвона, на что наткнулся в статье про FTPhttps://www.syl.ru/article/353787/chto- ... ispolzovat
"...Больше всего существует FTP-серверов для Windows, т. к. это самая инновационная и прогрессивная операционная система, а также ею пользоваться легче и проще,..."
08 янв 2019, 23:23
Whowka, да там вся статья - перл на перле, хохмой погоняет. Спасибо - поржал. :cray2: :crazy: :dash2:
08 янв 2019, 23:38
di_mok писал(а):
08 янв 2019, 22:13
SSHFS - это просто такой своеобразный клиент на основе FUSE. Штука удобная, но в качестве сервера у него все тот же самый ssh/sftp.
Еще один вариант на той же базе - scp (если нужен клиент под винду WinSCP очень похож на ту же Filezilla для FTP).
09 янв 2019, 01:36
Прислушайтесь к тому, что говорит slant по поводу ftp.
На Linux Mint установить сервер openssh, при установке которого установится и sftp.
Одна команда в терминале sudo apt install openssh-server и после установки можно уже подключаться через filezilla.
Пакеты, которые будут установлены: openssh-server openssh-sftp-server
Запустить Filezilla (если привыкли к ней) и, например:
При первой попытке подключения будет выдан запрос:
Причём этот запрос будет выдан для каждого пользователя удалённого узла. Т.е. если на удалённом компьютере, к которому производится подключение, имеется 2 пользователя системы и настраивается 2 подключения по SFTP (для каждого отдельно), то указанный выше запрос будет выдан 2 раза.
Если это узел домашней ЛВС, то смело ставить галочку в поле "Всегда доверять этому хосту, добавить ключ в кэш". И ...
Кроме того, файловые менеджеры nemo, caja, thunar позволяют создавать подключение через ssh. Кстати, даже удобнее, чем через filezilla.
scorpionhitech
18 янв 2019, 01:01
Не подружился я как-то с терминалом. Не могу решить выше поставленную задачу. Всё только через терминал. Всё как-то sudo up zamudreno. Или руки-крюки? Нееее. Не знаю как, но своего добъюсь.и будет sudo up upgrade. Остаётся как всегда читать, читать и ещё раз читать.
18 янв 2019, 15:02
По sftp любой гуйный файловый менеджер умеет. Необязательно файлзиллу
scorpionhitech
18 янв 2019, 15:34
Dja писал(а):
18 янв 2019, 15:02
Подключиться любой сможет. Я же не могу создать sftp сервер с нужными параметрами. Первый пост.
18 янв 2019, 15:45
scorpionhitech, для работы sftp не нужно ставить ftp
Нужно ставить ssh
sudo apt install ssh
i   ssh                                  - оболочка и сервер SSH (метапакет)
Затем прописываем в
nano /etc/ssh/sshd_config
Нужный порт
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
Он может быть и 2231 к примеру...
После этого
systemctl restart sshd.service
Готово!
scorpionhitech
18 янв 2019, 22:56
Спасибо огромное за помощь. А вот как теперь это всё настроить для двух пользователей - для меня доступ к нескольким папкам на разных дисках с возможностью закидывать. И ещё один пользователь с доступом к домашней папке и подпапкам с возможностью скидывать файлы на сервер. Буду очень признателен.
21 янв 2019, 16:01
scorpionhitech,
На целевом linux (192.168.1.5) создаем 2 пользователей
sudo adduser user1
sudo passwd user1
sudo adduser user2
sudo passwd user2
Затем создаем/определяем каталоги
su user1
cd
mkdir user1
chmod 600 ~/user1
exit
su user2
cd
mkdir user2
chmod 600 ~/user2
exit
Соответственно если заходим sftp://user1@192.168.1.5 то попадаем в хомяк пользователя user1, где доступная только для него папка. Аналогично для пользователя user2. К другим папкам применить несложно.
Вернуться в «Работа с сетью»
