FBReader
Автор темы - Сообщения: 312
FBReader
di_mok, уже было
[sudo] пароль для bums:
E: Не удалось найти пакет fbreader
FBReader
darkfenix, воть
System: Host: bums-Aspire-E1-571G Kernel: 4.15.0-32-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara Machine: Device: laptop System: Acer product: Aspire E1-571G v: V2.21 serial: N/A Mobo: Acer model: EA50_HC_HR v: Type2 - Board Version serial: N/A UEFI [Legacy]: Insyde v: V2.21 date: 12/16/2013 Battery BAT1: charge: 32.4 Wh 100.0% condition: 32.4/47.5 Wh (68%) model: SANYO Li_Ion_4000mA status: Full CPU: Dual core Intel Core i3-2348M (-MT-MCP-) arch: Sandy Bridge rev.7 cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9179 clock speeds: max: 2300 MHz 1: 1082 MHz 2: 940 MHz 3: 931 MHz 4: 944 MHz Graphics: Card-1: Intel 2nd Generation Core Integrated Graphics Controller bus-ID: 00:02.0 Card-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] bus-ID: 01:00.0 Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting,nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1366x768@60.00hz OpenGL: renderer: GeForce 710M/PCIe/SSE2 version: 4.4.0 NVIDIA 340.106 Direct Render: Yes Audio: Card Intel 7 Series/C216 Family High Def. Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic Network: Card-1: Broadcom Limited NetLink BCM57785 Gigabit Ethernet PCIe driver: tg3 v: 3.137 bus-ID: 02:00.0 IF: enp2s0f0 state: down mac: <filter> Card-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k bus-ID: 03:00.0 IF: wlp3s0 state: up mac: <filter> Drives: HDD Total Size: 750.2GB (15.7% used) ID-1: /dev/sda model: WDC_WD7500BPVT size: 750.2GB Partition: ID-1: / size: 47G used: 5.9G (14%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 493G used: 96G (21%) fs: ext4 dev: /dev/sda3 ID-3: swap-1 size: 8.84GB used: 0.00GB (0%) fs: swap dev: /dev/sda4 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 63.0C mobo: N/A gpu: 0.0:53C Fan Speeds (in rpm): cpu: N/A Info: Processes: 185 Uptime: 39 min Memory: 1260.4/3834.6MB Init: systemd runlevel: 5 Gcc sys: 7.3.0 Client: Shell (bash 4.4.191) inxi: 2.3.56
FBReader
➜ apt policy fbreader
fbreader:
Установлен: (отсутствует)
Кандидат: 0.12.10dfsg2-2
Таблица версий:
0.12.10dfsg2-2 500
500 http://mirror.yandex.ru/ubuntu bionic/universe amd64 Packages
➜ inxi -S
System: Host: darkfenix Kernel: 4.17.11-041711-generic x86_64 bits: 64 Desktop: Cinnamon 3.8.8
inxi -r
FBReader
darkfenix, да я как установил ваще их не трогал
Repos: Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list deb http://packages.linuxmint.com tara main upstream import backport #id:linuxmint_main deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse deb http://archive.canonical.com/ubuntu/ bionic partner Active apt sources in file: /etc/apt/sources.list.d/steam.list deb [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam deb-src [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
FBReader
darkfenix, вот
надо было libqt4-network установить и всё получилось
bums@bums-Aspire-E1-571G:~$ apt policy fbreader
fbreader:
Таблица версий:
0.12.10dfsg2-2 500
500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
bums@bums-Aspire-E1-571G:~$ apt policy libqt4-network
libqt4-network:
Кандидат: 4:4.8.7+dfsg-7ubuntu1
Таблица версий:
4:4.8.7+dfsg-7ubuntu1 500
fbreader:
Таблица версий:
0.12.10dfsg2-2 500
libqt4-network:
Таблица версий:
