Нагревается оперативная память
Любое устройство не попавшее под категории выше - сюда.
msinitsyn
Сообщение msinitsyn » 05 ноя 2017, 17:54
День добрый.
Имеется ноутбук конфигурация
System: Host: local.loc Kernel: 4.11.0-14-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.4.6 (Gtk 2.24.30) dm: mdm Distro: Linux Mint 18.2 Sonya
Machine: System: Hewlett-Packard product: HP ENVY Sleekbook 4 PC v: 0888110000305A00000310100
Mobo: Hewlett-Packard model: 1894 v: 72.43 Bios: Insyde v: F.13 date: 09/04/2012
Chassis: type: 10
CPU: Dual core Intel Core i5-3317U (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 6784
clock speeds: min/max: 800/2600 MHz 1: 2382 MHz 2: 2427 MHz 3: 2348 MHz 4: 2319 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0 chip-ID: 8086:0166
Resolution: 1366x768@60.00hz
GLX Renderer: Mesa DRI Intel Ivybridge Mobile
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:1e20
Sound: Advanced Linux Sound Architecture v: k4.11.0-14-generic
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 01:00.2 chip-ID: 10ec:8168
IF: eno1 state: down mac: <filter>
Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
driver: ath9k bus-ID: 02:00.0 chip-ID: 168c:002b
Drives: HDD Total Size: 628.1GB (57.6% used)
ID-1: /dev/sda model: Hitachi_HTS54505 size: 500.1GB serial: TE85123RCA9V0W
ID-2: /dev/sdb model: KingFast size: 128.0GB serial: SZHYPO1601041100817
Partition: ID-1: / size: 58G used: 26G (47%) fs: ext4 dev: /dev/sdb2
ID-2: /home size: 53G used: 26G (52%) fs: ext4 dev: /dev/sdb3
ID-3: swap-1 size: 8.04GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 60.0C mobo: 60.0C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 316 Uptime: 5:35 Memory: 6209.2/7883.7MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Unknown python2.7 client inxi: 2.2.35
В системе при стандартной работе (браузер, месенджеры, IDE) греется память. Греется так, что обжигает ноги. То, что память определил на вскрытом ноуте.
В Windows такого эффекта нет при тех же условиях.
Ноут чистый, пыли нет, тем более на памяти.
В чем может быть проблема ? Как решать ? Можно как-то решить?
connor41
Благодарил (а): 71 раз
Сообщение connor41 » 05 ноя 2017, 17:56
msinitsyn, а на какую температуру она нагревается есть информация?
Может она греется от соседних компонентов?
Arch Linux and Linux mint User :smile:
4.14.13-1-zen
i3wm :tux:
Сообщение rogoznik » 05 ноя 2017, 18:00
msinitsyn писал(а):
05 ноя 2017, 17:54
На ноуте :-D
msinitsyn
Сообщение msinitsyn » 05 ноя 2017, 18:10
connor41 писал(а):
05 ноя 2017, 17:56
нет. я ее пальцем пробовал во время работы со снятой крышкой. Греется сильно, обжигает. Датчика температуры на памяти нет.
Сообщение Dja » 05 ноя 2017, 20:27
msinitsyn писал(а):
05 ноя 2017, 17:54
проверяйте систему охлаждения. Термопасту. Хотя может тут IDE виноват... не использовал - сказать не могу.
msinitsyn
Сообщение msinitsyn » 05 ноя 2017, 21:14
В винде у меня нет такой проблемы, а система охлаждения одинаковая.
Сообщение Dja » 05 ноя 2017, 21:17
msinitsyn, и каковая температура при работе в windows? пруф в студию
msinitsyn
Сообщение msinitsyn » 05 ноя 2017, 22:34
Dja, да, это правильное решение - снести линух что бы посмотреть температуру в винде :)
Ноги не обжигало - это факт. Столкнулся с такой бедой только когда переехал на mint.
Сообщение Dja » 05 ноя 2017, 22:39
msinitsyn, зачем сносить? я думал дуалбут, чем многие страдают.
