Сломался звук
IL76
Сломался звук
07 мар 2025, 16:10
  Kernel: 6.8.0-52-generic x86_64 bits: 64 compiler: N/A
    base: Ubuntu 22.04 jammy
  Type: Desktop Mobo: Gigabyte model: Z790 UD v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F10
    date: 12/14/2023
  Info: 6-core model: 12th Gen Intel Core i5-12400 bits: 64 type: MT MCP
    arch: Alder Lake rev: 2 cache: L1: 480 KiB L2: 7.5 MiB L3: 18 MiB
  Speed (MHz): avg: 807 high: 885 min/max: 800/4400 cores: 1: 799 2: 800
    3: 800 4: 800 5: 885 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
    bogomips: 59904
  Device-1: Intel vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 730 (ADL-S GT1)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.3 direct render: Yes
  Device-1: Intel vendor: Gigabyte driver: N/A bus-ID: 00:1f.3
  Device-2: JMTek LLC. USB Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-12.2.3:10
  Sound Server-1: ALSA v: k6.8.0-52-generic running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    port: 4000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
    v: kernel port: 3000 bus-ID: 06:00.0
  IF: wlp6s0 state: down mac: <filter>
  IF-ID-1: wgtls state: unknown speed: N/A duplex: N/A mac: N/A
RAID:
  Device-1: md0 type: mdraid level: mirror status: active size: 931.39 GiB
  Info: report: 2/2 UU blocks: 976630464 chunk-size: N/A
  Components: Online: 0: sdb 1: sda
  Device-2: md1 type: mdraid level: mirror status: active size: 931.39 GiB
  Components: Online: 0: sde 1: sdd
  Local Storage: total: raw: 5.46 TiB usable: 3.64 TiB used: 1.43 TiB (39.4%)
  ID-1: /dev/nvme0n1 vendor: Netac model: NVMe SSD 500GB size: 465.76 GiB
    temp: 41.9 C
  ID-2: /dev/nvme1n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
    temp: 49.9 C
  ID-3: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
  ID-4: /dev/sdb vendor: Western Digital model: WD10EZEX-00BN5A0
  ID-5: /dev/sdc vendor: Western Digital model: WD5000AAKX-00ERMA0
  ID-6: /dev/sdd vendor: Hitachi model: HUA722010ALA330 size: 931.51 GiB
  ID-7: /dev/sde vendor: Hitachi model: HUA722010CLA330 size: 931.51 GiB
  ID-1: / size: 575.56 GiB used: 110.78 GiB (19.2%) fs: ext4
    dev: /dev/nvme1n1p3
  ID-2: /boot/efi size: 96 MiB used: 31.3 MiB (32.6%) fs: vfat
    dev: /dev/nvme1n1p1
Swap:
  Alert: No swap data was found.
  System Temperatures: cpu: 55.0 C mobo: 40.0 C
  Processes: 446 Uptime: 1h 11m Memory: 62.56 GiB used: 7.22 GiB (11.5%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3293 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Предыстория. После установки заметил, что после блокировки экрана постоянно сбрасывается звук на HDMI, пытался несколько раз исправить, ни как не удавалось. Сегодня решил еще попробовать для этого привлек chatgpt ;)
он мне много чего предлагал сделать, после всех попыток в итоге после перезагрузки звук пропал вовсе, то есть output остался только dummy output. По всем командам, которые мне предлагались все было вроде бы хорошо, кроме вот этой ournalctl -b | grep -i snd
Mar 07 14:50:07 ilia-work kernel: usbcore: registered new interface driver snd-usb-audio
Mar 07 14:50:07 ilia-work kernel: snd_hda_intel: probe of 0000:00:1f.3 failed with error -2
и вот тут ничего нет
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
Сейчас с ним проделывали одно и тоже и так по кругу, в общем тупиковая ситуация. Подскажите что я сломал и как починить?
Решено: 31
Сломался звук
07 мар 2025, 17:17
IL76 писал(а):
07 мар 2025, 16:10
Вы уже, наверное, и не вспомните что делали.
IL76
Сломался звук
07 мар 2025, 21:37
Сами изменения которые делались были направлены на то чтобы выключить HDMI, на который постоянно сбрасывался звук. А вот после того как после этих изменений звук совсем пропал, чего только не делали, тут действительно уже наверное не восстановить. Непонятно, что делать. Сейчас проапгрейдил систему до 22.1, но звук так и не появился.
Сломался звук
07 мар 2025, 22:30
IL76 писал(а):
07 мар 2025, 16:10
Надеюсь, это послужит хорошим уроком. Реальная нейросеть - это не полноценный AI из фантастики, она не понимает смысла того, что генерит. В результате - генерит "что-то на тему" как студент-двоечник курсовик за ночь пишет. :)
IL76 писал(а):
07 мар 2025, 16:10
Судя по вот этой строчке вы умудрились снести, или заблокировать загрузку модуля ядра который отвечает за вашу звуковую карту. (По сути - драйвер).
Без него, разумеется, звука с материнки вообще не будет. Вспоминайте - было ли у вас там что-то в действиях касающееся ковыряния в конфигах, где описываются загружаемые модули ядра, вызов "update-initramfs" и вписывания чего-то в "/etc/default/grub". Откатывайте если вспомните.
А если нет - возможно, проще будет систему переставить.
IL76
Сломался звук
07 мар 2025, 23:08
посмотрел по логам, что я там делал с ним, вот это
echo "options snd_hda_intel enable=0,1" | sudo tee -a /etc/modprobe.d/disable-hdmi.conf
убрал этот файл и по крайней мере появились девайсы вывода, но звук по-прежнему не работает
говорит ALSA error snd_pcm_hw_params failed input/output error
это плеер так ругается
sveta13
Благодарил (а): 46 раз
Сломался звук
09 мар 2025, 01:49
НЕ РАБОТАЕТ ЗВУК.
sudo apt install alsa-utils alsa-tools
затем в терминале
alsamixer
клавишей "m" включается/выключается, стрелками вверх/вниз уровень звука "esc" выход.
Как так :smile:
Debian 12 xfce:LM-22.1 xfce:
IL76
Сломался звук
09 мар 2025, 18:26
не помогло, сделал так, включил наушники (передняя панель) и все равно эта ошибка. Но включенные динамики, подключенные к карте сзади компа играют , когда я переключаю на Line Out. А headphones (unplugged)
IL76
Сломался звук
12 мар 2025, 10:40
В итоге теперь у меня звук работает так, что если колонки включены, то звук идет на них, а если выключены, то на наушники. В общем непонятно, но меня это устраивает, это даже лучше чем было раньше, нужно было переключать, теперь не нужно. ChatGpt реабилитировался ;)
