Не работает перезагрузка...
Александр Х
Сообщение Александр Х » 05 янв 2025, 15:34
Приветствую всех!
Поднял из "небытия" старенький нетбук
Acer Aspire One HAPPY2,
system:
Kernel: 6.8.0-51-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Laptop System: Acer product: AOHAPPY2 v: V1.04 serial: <filter>
Mobo: Acer model: JE06_PT serial: <filter> BIOS: INSYDE v: 1.04
date: 04/26/2011
ID-1: BAT1 charge: 46.0 Wh (100.0%) condition: 46.0/48.8 Wh (94.2%)
volts: 12.1 min: 11.1 model: SANYO AL10B31 status: full
Info: dual core model: Intel Atom N570 bits: 64 type: MT MCP
arch: Bonnell rev: A cache: L1: 112 KiB L2: 1024 KiB
Speed (MHz): avg: 1083 high: 1333 min/max: 1000/1666 cores: 1: 1000
2: 1333 3: 1000 4: 1000 bogomips: 13301
Flags: ht lm nx pae sse sse2 sse3 ssse3
Device-1: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: PowerVR SGX535
bus-ID: 00:02.0
Device-2: Suyin WebCam driver: uvcvideo type: USB bus-ID: 2-3:5
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: intel unloaded: fbdev,modesetting,vesa dri: i915 gpu: i915
resolution: 1024x600~60Hz
API: EGL v: 1.4,1.5 drivers: i915,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 2.1 vendor: mesa v: 24.0.9-0ubuntu0.3
glx-v: 1.4 direct-render: yes renderer: i915 (: Pineview M)
bus-ID: 00:1b.0
API: ALSA v: k6.8.0-51-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: n/a (root, process)
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Foxconn driver: ath9k v: kernel bus-ID: 02:00.0
Local Storage: total: 298.09 GiB used: 14.95 GiB (5.0%)
ID-1: /dev/sda vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB
ID-1: / size: 291.85 GiB used: 14.94 GiB (5.1%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda2
Swap:
ID-1: swap-1 type: file size: 5.92 GiB used: 376.9 MiB (6.2%)
file: /swapfile
System Temperatures: cpu: 61.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 2 GiB available: 1.91 GiB used: 726.6 MiB (37.2%)
igpu: 8 MiB
Processes: 215 Uptime: 1h 21m Init: systemd target: graphical (5)
Packages: 1991 Compilers: gcc: 13.3.0 Shell: Sudo v: 1.9.15p5
inxi: 3.3.34
ну и решил с Линукс познакомиться: установил Linux Mint 22 Cinnamon. Столкнулся с проблемой - не работает штатная перезагрузка системы, т.е. при нажатии кнопки "Перезагрузить" (в окне либо после установки пакета\приложения) - гаснет экран, отключаются сетевые адаптеры (гаснет индикатор) и все...черный экран и такое впечатление, что машина ушла в ждущий режим. На нажатия кнопок не реагирует, только выключается длительным нажатием кнопки питания. При использовании функции "Выключение" - все Ок. Поиск в сети дал результат - оказывается я не одинок в этом, попробовал указанные там способы, но безрезультатно...
На устройстве изначально (когда-то давно) были установлены Вин7 стартер и Андроид. Пробовал ставить 2-е ОС (Вин и Линукс) - тоже самое.
Возможно кто-то из гуру поможет советом как поправить ситуацию. Заранее спасибо
Благодарил (а): 1219 раз
Сообщение hellonet » 05 янв 2025, 16:00
Александр Х, А из терминала через reboot работает? А вообще жди релиза 22.1 с исправлениями
Александр Х
Сообщение Александр Х » 05 янв 2025, 16:05
Из терминала - результат тот же... :blush:
Решено: 31
Сообщение madesta » 05 янв 2025, 23:35
У меня на LM22.1 Cinnamon терминал настоятельно рекомендует вместо reboot использовать systemctl reboot
На подобные случаи в grub всегда отключаю заставку GRUB_CMDLINE_LINUX_DEFAULT="" По крайней мере, при загрузке или выключении на бегущих строках (выполняемые команды), возможно, есть вероятность увидеть где система спотыкаться будет.
Решено: 37
Сообщение WWolf » 06 янв 2025, 01:06
hellonet писал(а):
05 янв 2025, 16:00
и что изменится? :-D
Александр Х, попробуй 21.3, там ядро 5.15 если память не изменяет, как на нём себя поведёт твой атом :)
Сообщение hellonet » 06 янв 2025, 02:25
06 янв 2025, 01:06
и что изменится?
А вдруг? новая версия - новые возможности! :joke:
Stawr
Сообщение Stawr » 06 янв 2025, 12:34
У себя всегда ставлю на р/столе кнопки выкл. перезагруз. и форс-стоп(xkill) и все работают .в меню не захожу.
Stawr
Сообщение Stawr » 06 янв 2025, 12:49
если кому-то интересно могу написать команды ВЫКЛ. ПЕРЕЗАГРУЗКА и принудительное закрытие окон (если зависло).я это называю ФОРС-СТОП
Александр Х
Сообщение Александр Х » 06 янв 2025, 13:47
Stawr писал(а):
06 янв 2025, 12:49
Напишите - попробуем. Но дело, по моему, не в железе, стоял же Андроид с Виндой, да и в сети вопросы по этой проблеме встречаются... :dash2:
Stawr
Сообщение Stawr » 06 янв 2025, 15:07
1. ПКМ -Создать кнопку запуска
2.В поле названия--перезапуск или перезагрузка.можно сокр.
3.Комментарии не обязательно.
4.команда shutdown -r now
5/ОК СОХРАНЯТЬ или НЕТ без разницы.я сохранял (вдруг случайно удалится)значок сами выбирайте.
если понравится ,пишите,на 2 другие команды напишу.
Александр Х
Сообщение Александр Х » 06 янв 2025, 15:42
Stawr, спасибо, хорошая фича но... Не помогло, увы.
Stawr
Сообщение Stawr » 06 янв 2025, 16:45
Жаль.Интересно,а другие команды будут работать?
выкл. shutdown -P now
"убийца окон" xkill после ЛКМ по новой кнопке, курсор становится "весёлым Роджером" ,ставится в любое место окна,которое нужно убрать и жмём ЛКМ.
Удачи.
Stawr
Сообщение Stawr » 06 янв 2025, 17:16
Можно ещё попробовать скачать образ с другого зеркала ,а флешку создать через Ventoy или другую программу но не на Balena(один раз пробовал-резко против).у меня такое бывало с разных источников,даже в интерфейсах отличия были,небольшие,но замечал.
Решено: 31
Сообщение madesta » 06 янв 2025, 17:31
А что будет если попробуете команду reboot с указанием параметра (параметров)?
Подробности: https://askubuntu.com/questions/7114/wh ... t-shutdown
BIM
Сообщение BIM » 06 янв 2025, 18:04
Стандартные клавиатурные комбинации и утилиты Минта тоже не работают?
Александр Х
Сообщение Александр Х » 06 янв 2025, 18:29
Stawr, выключение-то работает как раз штатно, к нему вопросов нет..
madesta писал(а):
06 янв 2025, 17:31
уйдет в черный экран.
Александр Х
Сообщение Александр Х » 06 янв 2025, 18:35
И выключение, и ждущий режим работают штатно - проблема в перезагрузке: команды проходят, комп готовится перегружаться, если открыты проги - спрашивает, начинается выключение и все, висит с черным экраном.
Сообщение hellonet » 06 янв 2025, 19:09
Александр Х, забей, всё равно на таком недобуке с 2-мя гигами оперативы и медленным HDD диском невозможно работать комфортно. Чисто поиграться немного и забыть
Александр Х
Сообщение Александр Х » 06 янв 2025, 19:47
hellonet писал(а):
06 янв 2025, 19:09
Александр Х, забей, всё равно на таком недобуке...
Да похоже так и сделаю, вот еще завтра бету попробую...
А машинку есть куда пристроить, буду использовать для прошивки через Fastboot и как хранилище для них, чего пропадать 320Гб.
Всем спасибо, что не бросили в непонятках. удачи в новом году!
Решено: 31
Сообщение madesta » 06 янв 2025, 20:00
Александр Х писал(а):
06 янв 2025, 19:47
Ну можно было бы пристроить на Ubuntu server без графики, dhcp, dns с поднятием ftp или sftp либо samba на хранилище файлов. Управление по ssh или удалённо через веб-сервер. Помню, что на прежнем месте работы такой узел на виртуальной машине летал на выделенных ему 64 Мб оперативной памяти.
