Нет работает аудио устройство
Radeonx64
26 сен 2023, 17:35
Здраствуйте! Прошу помочь. У меня Linux Mint 21.2 x64 XFCE.
  Kernel: 5.15.0-84-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: Xfce 4.18.1 Distro: Linux Mint 21.2 Victoria
    base: Ubuntu 22.04 jammy
  Type: Laptop System: HP product: HP Laptop 15-gw0xxx
    v: Type1ProductConfigId serial: <superuser required>
  Mobo: HP model: 87D3 v: 38.21 serial: <superuser required> UEFI: Insyde
    v: F.14 date: 12/24/2020
  ID-1: BAT1 charge: 41.1 Wh (100.0%) condition: 41.1/40.9 Wh (100.4%)
    volts: 12.7 min: 11.3 model: Hewlett-Packard PABAS0241231 status: Full
  Info: dual core model: AMD Athlon Gold 3150U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
    L2: 1024 KiB L3: 4 MiB
  Speed (MHz): avg: 1377 high: 1392 min/max: 1400/2400 boost: enabled
    cores: 1: 1366 2: 1359 3: 1391 4: 1392 bogomips: 19162
  Device-1: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
    620/625 Mobile]
    vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 01:00.0
  Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0
  Device-3: Quanta HP TrueVision HD Camera type: USB driver: N/A
    bus-ID: 1-6.1:4
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080
  OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.7 DRM 3.42
  5.15.0-84-generic)
    v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 05:00.1
    vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 05:00.5
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 05:00.6
  Sound Server-1: ALSA v: k5.15.0-84-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: no
    vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtl8821ce v: v5.5.2.1_35598.20191029
    port: 2000 bus-ID: 03:00.0
  IF: wlo1 state: down mac: <filter>
Bluetooth:
  Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
    bus-ID: 1-6.3:5
  Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
    bt-v: 2.1 lmp-v: 4.2
  Local Storage: total: 238.47 GiB used: 35.53 GiB (14.9%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ256HAJD-000H1
    size: 238.47 GiB temp: 26.9 C
  ID-1: / size: 233.18 GiB used: 35.52 GiB (15.2%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 2.5 MiB (0.1%) file: /swapfile
  System Temperatures: cpu: 20.0 C mobo: 10.0 C
  GPU: device: amdgpu temp: 40.0 C device: amdgpu temp: 39.0 C
  Processes: 246 Uptime: 35m Memory: 3.27 GiB used: 1.8 GiB (55.2%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2221 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Проблема в том что я установил программу lyrebird из гитхаба. Я после этого выключил и через день включил ноутбук снова. И после включения у меня не нет вообще никакого звука не из встроенных динамиков, не из наушников (тоже самое с микрофонами). Подскажите как удалить lyrebird и как "починить" звук.
Благодарил (а): 1218 раз
26 сен 2023, 19:03
sudo apt-get remove Название программы
26 сен 2023, 19:20
Radeonx64 писал(а):
26 сен 2023, 17:35
Внимательно прочитать инструкции в том репозитории из которого устанавливал.
Точнее тебе никто не скажет, т.к. ты даже ссылку на репозиторий не указал
volp
Благодарил (а): 30 раз
26 сен 2023, 21:59
тут написано. что при проблемах с приложениями надо запустить pavucontrol
Вернуться в «Звуковые карты»
