System: Kernel: 5.15.0-79-generic x86_64 bits: 64 compiler: gcc v: 11.3.0 Desktop: Xfce 4.18.1 Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy Machine: Type: Laptop System: HP product: HP Laptop 15-gw0xxx v: Type1ProductConfigId serial: <superuser required> Mobo: HP model: 87D3 v: 38.21 serial: <superuser required> UEFI: Insyde v: F.14 date: 12/24/2020 Battery: ID-1: BAT1 charge: 41.0 Wh (100.0%) condition: 41.0/40.9 Wh (100.2%) volts: 12.9 min: 11.3 model: Hewlett-Packard PABAS0241231 status: Full CPU: Info: dual core model: AMD Athlon Gold 3150U with Radeon Graphics bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB L2: 1024 KiB L3: 4 MiB Speed (MHz): avg: 1345 high: 1395 min/max: 1400/2400 boost: enabled cores: 1: 1366 2: 1230 3: 1389 4: 1395 bogomips: 19163 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Graphics: Device-1: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 01:00.0 Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0 Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-6.1:4 Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.7 DRM 3.42 5.15.0-79-generic) v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 05:00.1 Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 05:00.5 Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 05:00.6 Sound Server-1: ALSA v: k5.15.0-79-generic running: yes Sound Server-2: PulseAudio v: 15.99.1 running: yes Sound Server-3: PipeWire v: 0.3.48 running: yes Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter> Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8821ce v: v5.5.2.1_35598.20191029 port: 2000 bus-ID: 03:00.0 IF: wlo1 state: down mac: <filter> Bluetooth: Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-6.3:5 Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1 lmp-v: 4.2 Drives: Local Storage: total: 238.47 GiB used: 26.77 GiB (11.2%) ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ256HAJD-000H1 size: 238.47 GiB temp: 35.9 CSystem: Kernel: 5.15.0-79-generic x86_64 bits: 64 compiler: gcc v: 11.3.0 Desktop: Xfce 4.18.1 Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy Machine: Type: Laptop System: HP product: HP Laptop 15-gw0xxx v: Type1ProductConfigId serial: <superuser required> Mobo: HP model: 87D3 v: 38.21 serial: <superuser required> UEFI: Insyde v: F.14 date: 12/24/2020 Battery: ID-1: BAT1 charge: 41.0 Wh (100.0%) condition: 41.0/40.9 Wh (100.2%) volts: 12.9 min: 11.3 model: Hewlett-Packard PABAS0241231 status: Full CPU: Info: dual core model: AMD Athlon Gold 3150U with Radeon Graphics bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB L2: 1024 KiB L3: 4 MiB Speed (MHz): avg: 1345 high: 1395 min/max: 1400/2400 boost: enabled cores: 1: 1366 2: 1230 3: 1389 4: 1395 bogomips: 19163 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Graphics: Device-1: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 01:00.0 Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0 Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-6.1:4 Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.7 DRM 3.42 5.15.0-79-generic) v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 05:00.1 Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 05:00.5 Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 05:00.6 Sound Server-1: ALSA v: k5.15.0-79-generic running: yes Sound Server-2: PulseAudio v: 15.99.1 running: yes Sound Server-3: PipeWire v: 0.3.48 running: yes Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter> Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8821ce v: v5.5.2.1_35598.20191029 port: 2000 bus-ID: 03:00.0 IF: wlo1 state: down mac: <filter> Bluetooth: Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-6.3:5 Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1 lmp-v: 4.2 Drives: Local Storage: total: 238.47 GiB used: 26.77 GiB (11.2%) ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ256HAJD-000H1 size: 238.47 GiB temp: 35.9 C Partition: ID-1: / size: 233.18 GiB used: 26.76 GiB (11.5%) fs: ext4 dev: /dev/nvme0n1p2 ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/nvme0n1p1 Swap: ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile Sensors: System Temperatures: cpu: 20.0 C mobo: 10.0 C Fan Speeds (RPM): N/A GPU: device: amdgpu temp: 53.0 C device: amdgpu temp: 52.0 C Info: Processes: 252 Uptime: 54m Memory: 3.27 GiB used: 1.84 GiB (56.4%) Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2163 Shell: Bash v: 5.1.16 inxi: 3.3.13
