Нет звука в VM
1o4ka
Благодарил (а): 23 раза
Нет звука в VM
24 мар 2023, 18:44
LM 21.1 Vera
cinnamon
железо:
Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 3193 min/max: 800/3200 cores: 1: 3193 2: 3193
bogomips: 12771
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 22.2.5 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlxc46e1f210c3f state: up mac: <filter>
Local Storage: total: 1.35 TiB used: 282.46 GiB (20.5%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc type: USB vendor: Patriot model: Burst Elite 480GB
ID-1: / size: 91.11 GiB used: 16.15 GiB (17.7%) fs: ext4 dev: /dev/sdc2
ID-2: /home size: 287.8 GiB used: 77.4 GiB (26.9%) fs: ext4
dev: /dev/sdc4
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sda5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 38.0 C
Processes: 245 Uptime: 11h 30m Memory: 15.52 GiB used: 6.01 GiB (38.7%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2896 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Установил win 10 Pro на VВ. Никак не могу наладить звук. При наведении курсора на иконку звука:
выскакивает сообщение:
Выходное аудиоустройство не установлено
Поиски решения по сети не дали никаких результатов. Не смог я подключить звук в виртуальной винде.
Подскажите, это можно сделать?
...bis dat qui cito dat
Нет звука в VM
24 мар 2023, 18:58
1o4ka, так в настройках виртуальной машины что там?
Нет звука в VM
24 мар 2023, 19:08
В конфигурации VM звуковая карта есть в списке виртуального железа?
extension pack для VirtualBox установлен?
Драйверы для винды для виртуального железа на систему в виртуалке установлены?
1o4ka
Нет звука в VM
24 мар 2023, 19:17
24 мар 2023, 18:58
Нет звука в VM
24 мар 2023, 19:20
Мне кажется или все параметры сгребли в кучу (дополнительные нафига )
1o4ka
Нет звука в VM
24 мар 2023, 19:24
24 мар 2023, 19:08
1o4ka
Нет звука в VM
24 мар 2023, 19:26
24 мар 2023, 19:08
А как узнать, установлен он или нет?
24 мар 2023, 19:08
Да. Потому как проблема - только со звуком.
1o4ka
Нет звука в VM
24 мар 2023, 19:27
24 мар 2023, 19:20
Откуда же я знаю. Может, дополнительные отменить?
Нет звука в VM
24 мар 2023, 19:29
1o4ka писал(а):
24 мар 2023, 19:26
Где то в настройках виртуалки есть пункт плагины . Должен быть где то там.
Нет звука в VM
24 мар 2023, 19:30
1o4ka писал(а):
24 мар 2023, 19:27
Если по умолчанию в чекбоксах ничего не стояло , то и трогать не стоило. Попробуй.
1o4ka
Нет звука в VM
24 мар 2023, 19:40
24 мар 2023, 19:08
Получается установлен:
Нет звука в VM
24 мар 2023, 19:46
1o4ka писал(а):
24 мар 2023, 19:40
У тебя привычка отмечать все чекбоксы подряд ? И наконец , для вставки скринов внизу есть кнопка для вложений. Эти хостинги работают через задницу.
1o4ka
Нет звука в VM
24 мар 2023, 19:53
24 мар 2023, 19:46
Ничего я не отмечал. Открыл, сделал скрин того, что там было.
Дополнительные возможности "Включить аудио выход", "Включить аудио вход" отключил. Но, всё равно.
Я тут вычитал где-то в сети, что, мол в VM звуковых карт нет. Но. Я отлично помню, как когда-то устанавливал VM на ноуте. Звук был. Хотя, ничего особенного я не делал. Устанавливал как обычно.
Нет звука в VM
24 мар 2023, 20:13
1o4ka писал(а):
24 мар 2023, 19:26
Да
А ты точно в этом уверен?
Посмотри на свой скрин из сообщения Нет звука в VM (Пост 1o4ka #131468). Там есть "Мультимедиа аудиоконтроллер" без драйвера
1o4ka
Нет звука в VM
24 мар 2023, 20:21
rogoznik, погоди. Я ещё писал, что проблемы только со звуком. А за звук отвечает Мультимедиа аудиоконтроллер. Вот его одного и нет. И как я не пытался его установить, никак. Из виртуальной винды, из LM. Не могу найти.
Нет звука в VM
24 мар 2023, 20:28
1o4ka, так а мы то чем тебе поможем? Драйвер за тебя установим или что? Поставь драйвер
Нет звука в VM
24 мар 2023, 20:29
1o4ka писал(а):
24 мар 2023, 19:53
Плохо читал , речь видимо шла о пробросе аудиокарты в виртуалку.
Скрин в 13 посте в какой системе сделан ?
Нет звука в VM
24 мар 2023, 20:35
Кстати , для виртуалки нужен не только экстрапак но и кажется гостевые дополнения.
1o4ka
Нет звука в VM
24 мар 2023, 20:41
24 мар 2023, 20:28
Поставь драйвер
Какой? Я найти не могу.
24 мар 2023, 20:29
Через форум.
Нет звука в VM
24 мар 2023, 20:43
1o4ka писал(а):
24 мар 2023, 20:41
Через форум.
Уточню , в винде или в минте ?
Сейчас этот форум просматривают: PetalBot[Bot] и 2 гостя
