Xiaomi Portable WiFi (ID 2717:4106) делаем точку доступа по умолчанию
Решено: 36
#21
28 фев 2023, 11:47
fanny, поковырялся, у меня тоже ругается порой так же :)
так, а ты делал? sudo ip link set ra0 up
fanny
Благодарил (а): 3 раза
#22
28 фев 2023, 12:15
root@debian:/home/foxser# sudo ip link set ra0 up
root@debian:/home/foxser# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s5: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 00:1a:4d:62:26:50 brd ff:ff:ff:ff:ff:ff
inet 192.168.100.1/24 brd 192.168.100.255 scope global enp1s5
3: enp1s2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
link/ether 00:80:48:cb:f4:38 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.200/24 brd 192.168.0.255 scope global enp1s2
inet6 fe80::280:48ff:fecb:f438/64 scope link
5: ra0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
link/ether 1c:bf:ce:05:32:35 brd ff:ff:ff:ff:ff:ff
inet6 fe80::1ebf:ceff:fe05:3235/64 scope link
попробовал свисток в дркомпе где ничего не модифицировал, в логе такое вылезло:
[11443.369099] usb 2-5: new high-speed USB device number 4 using ehci-pci
[11443.536627] usb 2-5: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[11443.536630] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[11443.536631] usb 2-5: Product: 802.11 n WLAN
[11443.536632] usb 2-5: Manufacturer: MediaTek
[11443.536634] usb 2-5: SerialNumber: 1.0
[11443.785147] usb 2-5: reset high-speed USB device number 4 using ehci-pci
[11443.951990] mt7601u 2-5:1.0: ASIC revision: 76010001 MAC revision: 76010500
[11443.953719] mt7601u 2-5:1.0: firmware: failed to load mt7601u.bin (-2)
[11443.953723] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[11443.953725] mt7601u 2-5:1.0: Direct firmware load for mt7601u.bin failed with error -2
[11443.954403] mt7601u: probe of 2-5:1.0 failed with error -2
[11443.954442] usbcore: registered new interface driver mt7601u
Решено: 36
#23
28 фев 2023, 12:35
fanny писал(а):
28 фев 2023, 12:15
передёрни свисток и всё должно пойти
Решено: 36
#24
28 фев 2023, 12:36
fanny писал(а):
28 фев 2023, 12:15
ну а что ты хотел там увидеть? грузиться mt7601u, которому и фирмварю надо дать
fanny
#25
28 фев 2023, 13:12
кроме как по появлению ra0 работоспособность свистка по другому проверить можно?
Решено: 36
#26
28 фев 2023, 13:17
fanny, если интерфейс поднялся, значит всё нормально со свистком и драйвером, надо дальше копать - почему не назначился ip (конкретно пункт 7)
fanny
#27
01 мар 2023, 14:38
WWolf, в rt2870ap.txt что-то еще править кроме SSID и пароля? Точка доступа появилась, но подключится не выходит, телефон пишет ошибка аутентификации.
Хотел статистику посмотреть, но утилита iw свисток не видит, видимо из-за кривых драйверов?
Решено: 36
#28
01 мар 2023, 15:51
fanny писал(а):
01 мар 2023, 14:38
ничего больше не правлю
fanny писал(а):
01 мар 2023, 14:38
передёрнуть свисток и проверить пароль... ещё что-то было по поводу WPA/WPA2 - новые телефоны брезгуют им пользоваться, надо принудительно пинать их в этом направлении....
fanny писал(а):
01 мар 2023, 14:38
iw разве работает с точками доступа?
fanny
#29
02 мар 2023, 10:12
01 мар 2023, 15:51
судя по https://zalinux.ru/?p=411 да
точка заработала, дело было в iptables
Решено: 36
#30
02 мар 2023, 10:25
fanny писал(а):
02 мар 2023, 10:12
ну и отлично :)
yarichin
#31
02 мар 2023, 10:32
Дело было не в бобине. :-D
