Аккумуляторная батарея
1o4ka
Благодарил (а): 23 раза
21 фев 2023, 16:27
Быть может, мой вопрос задан не по адресу. Но, вначале, попытаюсь изложить проблему.
NAME="Linux Mint"
VERSION="21.1 (Vera)"
железо:
$ inxi -Fxz
Kernel: 5.15.0-60-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: KDE Plasma 5.24.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.53 date: 10/15/2021
ID-1: BAT0 charge: 35.6 Wh (86.0%) condition: 41.4/41.4 Wh (100.0%)
volts: 12.2 min: 11.3 model: Hewlett-Packard Primary status: Discharging
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1701 high: 2113 min/max: 1400/2600 boost: enabled
cores: 1: 1524 2: 1671 3: 1497 4: 2113 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:4
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.6 DRM 3.42
5.15.0-60-generic)
v: 4.6 Mesa 22.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-60-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:2
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 117.74 GiB (49.4%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 25.9 C
ID-1: / size: 29.36 GiB used: 20.51 GiB (69.9%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.8 MiB used: 6.1 MiB (2.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 195.98 GiB used: 97.22 GiB (49.6%) fs: ext4
dev: /dev/nvme0n1p4
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 50.0 C
Processes: 238 Uptime: 13m Memory: 5.71 GiB used: 2.42 GiB (42.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 3173 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Ноутбук HP Laptop 15s-eq1426 ur приобретён 07.07.22. По идее - нестарый. Но вот какую вещь я заметил: при полностью выключенном ноутбуке, отсоединённом от внешнего блока питания, очень быстро садится внутренняя аккумуляторная батарея. (за сутки - более чем на 10%).
Специалист по винде заметил, что аккумулятор может здесь быть совершенно ни при чём. Потому как ноутбук, даже в выключенном состоянии, может подавать питание либо на USB, либо - на сетевую карту, либо ещё на что-нибудь. То есть, проблема может быть с драйвером управления питанием. Как это проверить в LM, специалист - не в курсе. Его рекомендации: снести LM, установить Винду и тогда спец сможет произвести диагностику, меня как-то не устраивают.
Подскажите, пожалуйста, что можно сделать в создавшейся ситуации?
Быть может, мне досталась изначально бракованная аккумуляторная батарея, или всё-таки, проблема в чём-то другом?
...bis dat qui cito dat
21 фев 2023, 16:53
Похоже это "специалист". :)
Т.к. если батарея садится при выключенной машине - тут система уже не при чем. И проверять такую гипотезу надо на уровне железа - тестером, и просмотром опций UEFI.
1o4ka писал(а):
21 фев 2023, 16:27
Обратится к нормальному специалисту, или в сервис-центр.
Но вообще-то, такое поведение некоторых ноутбуков, увы бывает врожденной особенностью. Напрмер, были такие нетбуки Asus EEE Pc - так этим страдали поголовно почти все их модели, за неделю-полторы в шкафу батарея будет съедена в ноль с гарантией. А что касается HP - примерно с 2016-го года я вообще не считаю фирмой, заслуживающей внимания линуксоводов. Ни под каким соусом. Двумя словами "виндохрень делают".
Так же проверьте разряжается ли аккумулятор быстро более чем до планки в 70%, т.к. там может быть в прошивке настройка на сохранение батареи. (Скажем, Dell это любит, но у него оно обычно отключаемо). Смысл в том, что в случае длительного хранения сам ноутбук разряжает батарею до неполного заряда принудительно. Т.к. считается, что будучи заряженной на 100% со временем она начинает терять максимальную емкость быстрее, чем если хранить ее с не полным зарядом.
1o4ka
21 фев 2023, 17:06
21 фев 2023, 16:53
Как это сделать? Не могли бы вы более подробно рассказать.
21 фев 2023, 17:14
1o4ka писал(а):
21 фев 2023, 17:06
Зайти в UEFI, и проверить наличие и состояние соответствующих опций.
Подробно как это сделать - в инструкции к ноутбуку должно быть написано.
1o4ka
21 фев 2023, 17:39
21 фев 2023, 17:14
Зайти в UEFI
Как-то всё запутанно. Раньше было просто: зайдите в BIOS. Теперь - UEFI.
Относительно батареи, в UEFI, одна запись:
battery remaining time
(оставшееся время работы батареи)
и два варианта:
Disabled
Enabled
то есть, отображать и не отображать.
Поставил - Enabled.
Damian
Благодарил (а): 24 раза
21 фев 2023, 18:14
Disabled - Запрещено
Enabled - Разрешено.
1o4ka
21 фев 2023, 18:52
Damian писал(а):
21 фев 2023, 18:14
Ну, это сути не меняет. Технические термины, в английском языке, имеют, как правило, несколько значений.
Суть в том, что ноутбук не обесточивается, даже выключенный, поскольку плате нужно среагировать на кнопку включения, а значит - следить за ее состоянием.
Говоря проще, напряжение по плате гуляет всегда. (Кроме случая с извлечением аккумуляторной батареи, либо батарея полностью "села").
Выключенный ноутбук, если он подключен к розетке, потребляет электроэнергию. Это около 5 ватт.
В данной связи было решено отсоединить SSD, дабы в ходе проверки выяснить, как быстро разряжается аккумуляторная батарея, без наличия ОСи. Если срок разрядки увеличится, значит надо смотреть установленную операционную систему. Если нет, то - одно из двух.
Отпишусь после завершения проверки.
1o4ka
26 фев 2023, 11:27
Вот что удалось почерпнуть из сети:
Батарея ноутбука разряжается до 0% при выключенном питании.
Это довольно распространенная проблема, обычно возникающая из-за подключенного режима ожидания. Чтобы полностью отключить эту функцию, вам нужно внести несколько изменений в реестр.
В статье написано, как это сделать для Windows.
Не подскажете, как это можно сделать для LM?
yarichin
26 фев 2023, 12:03
1o4ka писал(а):
26 фев 2023, 11:27
А винда у тебя на компе есть ? Если нет , то на эту статью можно смело наплевать.
1o4ka писал(а):
21 фев 2023, 18:52
Где результаты ?
И поищи в своём уефи что нибудь похожее на - wake on lan
26 фев 2023, 12:55
1o4ka писал(а):
26 фев 2023, 11:27
Никак. В линксе нету ни реестра, ни такого режима "выключения" которым страдает винда, и который лечат подобным образом.
(10-ка по умолчанию не выключает комп полноценно, а перегружает и вводит его в гибернацию).
Вообще, искать информацию в статьях посвященных windows - в вашем случае все равно, что пытаться учить математику читая учебник химии.
P.S. Если хотите провести тест и убедится что выключается ноутбук полноценно - это сделать очень просто. После выключения, снимите с ноутбука батарею на ~5 минут, и затем верните обратно. Не включая (не загружая) оставьте на тестовый период времени. И когда запустите следующий раз, смотрите уровень разряда. Если просядет как и раньше - точно не оно. А если заряд сохранится - возможны варианты...
1o4ka
26 фев 2023, 17:49
yarichin писал(а):
26 фев 2023, 12:03
Где результаты ?
Пока результат один: аккумуляторная батарея разряжается более чем на 10% за сутки. После выходных понесу ноут к товарищу. Будем вместе думать.
yarichin писал(а):
26 фев 2023, 12:03
И что с этим "wake on lan" делать?
yarichin
26 фев 2023, 17:50
1o4ka писал(а):
26 фев 2023, 17:49
Можешь сьесть , можешь отключить. Только не бросай его в терновый куст.
1o4ka
26 фев 2023, 17:57
yarichin писал(а):
26 фев 2023, 17:50
Можешь сьест
Ничего похожего на "wake on lan", в UEFI, нет.
1o4ka
26 фев 2023, 18:16
26 фев 2023, 12:55
Какие варианты?
yarichin
26 фев 2023, 18:17
1o4ka писал(а):
26 фев 2023, 17:57
Не верю. ( Станиславский )
Когда уже будешь отвечать по делу ?
1o4ka
26 фев 2023, 18:35
yarichin, что ж ты такой...неверующий. Смотри
1o4ka
26 фев 2023, 18:45
yarichin писал(а):
26 фев 2023, 12:03
На ноуте SSD -- только c LM. Но есть SSD с Виндой (на стационаре). Можно поставить на ноут. Я уже запускал ОСи, установленные на выносные диски.
Вопрос: будет ли толк?
26 фев 2023, 12:55
Вообще-то, есть приложения, из которых можно править реестр Винды. Но, так как у меня на ноуте только LM, подобные приложения, в моём случае, не нужны.
yarichin
26 фев 2023, 18:49
1o4ka писал(а):
26 фев 2023, 18:35
Ну хоть один ответ с фактажом выцепил )) А по картинкам у меня сложилось впечатление что это бизнес недобук с чем то ранее предустановленным. И возможно с урезанным биос.
1o4ka
26 фев 2023, 18:56
yarichin, не надо гадать. Ничего там не было. Никакой операционки. Во всяком случае, при покупке, достали из запечатанного ящика ноут. Посмотрели на BIOS, и собственно, всё. Далее, устанавливал ОСи самостоятельно. В смысле, вначале стояла одна. Полетела. Потом - другая. LM, вроде держится.
Если, как ты говоришь, "урезанный" BIOS, обоснуй. Готов выслушать рекомендации.
yarichin
26 фев 2023, 19:01
1o4ka писал(а):
26 фев 2023, 18:56
Первый скрин с описанием. Ни даты изготовления , ни даты обновления биос , да и в модели ххх. Как будто какой то безродный ноунейм. (ИМХО)
Вернуться в «KDE»
