Problem: Linux Mint 21 Cinnamon 64 bit - Vulkan doesn't work. AMD APU Radeon RX Vega 6 (Integrated AMD Ryzen™ 5 4600H)
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 08:18
Good morning, gentlemen!
Problem: Vulkan doesn't work. !!!
Tried different versions of drivers. Forced activation. No result.
Graphics acceleration works fine, but there is no Vulkan support according to reports.
PS - I found Vulkan 1.2 support information on the AMD website. On Windows 10, there are no problems with Vulkan.
Operating system: Linux Mint 21 Cinnamon 64 bit
Device: HONOR MagicBook Pro HLYL-WFQ9 Notebook (1920x1080, AMD Ryzen 5 3GHz, RAM 16GB, SSD 512GB)
Video Card: AMD APU Radeon RX Vega 6 (Integrated AMD Ryzen™ 5 4600H)
I would be very grateful if you could help me resolve this issue.
Below is a complete report on the system:
  Kernel: 5.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
    Desktop: Cinnamon 5.4.11 Distro: Linux Mint 21 Vanessa
    base: Ubuntu 22.04 jammy
  Type: Laptop System: HUAWEI product: HLYL-WXX9 v: M1010
    serial: <superuser required>
  Mobo: HUAWEI model: HLYL-WXX9-PCB v: M1010 serial: <superuser required>
    UEFI: HUAWEI v: 1.09 date: 05/18/2022
  ID-1: BAT1 charge: 52.7 Wh (99.6%) condition: 52.9/54.9 Wh (96.3%)
    volts: 8.6 min: 7.6 model: DYNAPACK HB6081V1ECW-22T status: N/A
  Info: 6-core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
  Speed (MHz): avg: 1895 high: 3992 min/max: 1400/3000 boost: enabled
    cores: 1: 3992 2: 3985 3: 1744 4: 1397 5: 1489 6: 1397 7: 1397 8: 1473
    9: 1481 10: 1397 11: 1594 12: 1397 bogomips: 71867
  Device-1: AMD Renoir vendor: QUANTA driver: amdgpu v: kernel
    bus-ID: 03:00.0
  Device-2: Quanta ov9734_techfront_camera type: USB driver: uvcvideo
    bus-ID: 1-4:3
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.0-46-generic)
    v: 4.6 Mesa 22.0.5 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: QUANTA
    driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    vendor: QUANTA driver: N/A bus-ID: 03:00.5
  Device-3: AMD Family 17h HD Audio vendor: QUANTA driver: snd_hda_intel
    v: kernel bus-ID: 03:00.6
  Sound Server-1: ALSA v: k5.15.0-46-generic running: yes
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: & Tele RSH driver: rtw_8822ce v: N/A port: 2000 bus-ID: 01:00.0
  IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-4:3
  Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter>
    bt-v: 3.0 lmp-v: 5.1
  Local Storage: total: 942.7 GiB used: 296.93 GiB (31.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-00000
    size: 476.94 GiB temp: 47.9 C
  ID-2: /dev/sda type: USB vendor: Seagate model: ST500LT012-1DG142
  ID-1: / size: 369.28 GiB used: 58.63 GiB (15.9%) fs: ext4
    dev: /dev/nvme0n1p4
  ID-2: /boot/efi size: 96 MiB used: 30.2 MiB (31.4%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 8.9 MiB (0.4%) file: /swapfile
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 43.0 C
  Processes: 398 Uptime: 9h 31m Memory: 15 GiB used: 7.66 GiB (51.0%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 2929 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
________________________________________________________________________
Доброе утро господа!
Проблема: не работает Vulkan. !!!
Пробовал разные варианты драйверов. Принудительное включение. Нет результата.
Графическое ускорение работает отлично, но нет поддержки Vulkan судя по отчетам.
PS - на сайте AMD нашел информация поддержки Vulkan 1.2. В Windows 10 проблем нет с Vulkan.
Операционная система: Linux Mint 21 Cinnamon 64 bit
Устройство: Ноутбук HONOR MagicBook Pro HLYL-WFQ9 (1920x1080, AMD Ryzen 5 3 ГГц, RAM 16 ГБ, SSD 512 ГБ)
Видеокарта: AMD APU Radeon RX Vega 6 (встроенная AMD Ryzen™ 5 4600H)
Буду очень признателен если поможете разобраться с этим вопросом.
Ниже будет полностью отчет о системе:
    bus-ID: 03:00.0
    bus-ID: 1-4:3
Bluetooth:
    bus-ID: 3-4:3
    dev: /dev/nvme0n1p4
    dev: /dev/nvme0n1p1
Swap:
hardinfo_report.html.zip
(16.11 КБ) 9 скачиваний
Сообщение slant » 30 авг 2022, 15:07
Наткнулся на вашу тему с тем же вопросом на основном форуме, так что отвечаю на кое-что оттуда. К сожалению не могу помочь полностью, т.к. свежих AMD карт у меня под рукой нету.
When you enter the command - lspci | grep 3D && vulkaninfo | grep device_name is null.
Ваша проблема с тестом в том, что имя карты которое выводит lspci не обязано содержать "3D", которое здесь ищет в выводе grep. А если ваша строчка не находит в выводе lspci "3D", то vulkaninfo вообще не запускается - разумеется на выводе ничего нету.
На самый крайний случай, есть еще вот такая ссылка https://www.amd.com/ru/support/kb/relea ... inux-20-20 - это драйверы непосредственно от самих AMD.
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 17:13
Release Date: June 12, 2020 релиз старый - болше вопросов возникает а так добавлю посты еще с офф форума :blush:
Последний раз редактировалось пользователем 1 liudvig_larson; всего редактировалось раз: 30
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 17:17
да я писал еще и в основнйо ветке https://forums.linuxmint.com/viewtopic. ... 2#p2225272 а насчет дров офф амд - спорное решение - они 2020 года - очень спорно. думал тоже про них. бекап системв есть. если альтернатив не найду попробую. спасибо за ответ :hi3:
MrTowelie
Решено: 8
Благодарил (а): 18 раз
Сообщение MrTowelie » 30 авг 2022, 19:46
Здравствуйте, вот такой вопрос пальцем в небо.
Я вот играю на Linux с видеокарты amd, но не встроенной, и у меня помимо vulkan-tools установлены пакеты libvulkan1, libvulkan1:i386, mesa-vulkan-drivers, mesa-vulkan-drivers:i386. Если они не установлены, то, может быть, их доустановка как-то изменит ситуацию?
Обновление: А вообще, вам бы проверить работу vulkan в приложениях/играх, которые его требуют.
Последний раз редактировалось пользователем 1 MrTowelie; всего редактировалось раз: 30
Сообщение rogoznik » 30 авг 2022, 19:55
liudvig_larson, мой вывод lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
01:00.0 Non-Volatile memory controller: Realtek Semiconductor Co., Ltd. Device 5763 (rev 01)
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
04:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
05:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
07:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
08:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch (rev c1)
09:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch
0a:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 23 [Radeon RX 6600/6600 XT/6600M] (rev c1)
0a:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21/23 HDMI/DP Audio Controller
0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
0c:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
0c:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
0c:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Тут моя видеокарта это
Я тут чего-то не понял.
А что должна вывести команда
В выводе vulkaninfo нет строк, содержащих подстроку device_name
Там в выводе vulkaninfo я вообще не нашел ничего что хоть как-то бы указывало на видеокарту
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 20:33
MrTowelie писал(а):
30 авг 2022, 19:46
ставил разные дрова - прикол как я понял именно с встроенной графикой - на работу ни как не влияет просто нет вулкана - хотя чип поддерживает - вот и решил докопатсья. настроить и забекапить от греха подальше линуху - чтоб потом не парится и не возвращатсья к этому вопросу. у меня есть догадки что на арч подобных линух систем этой проблемы модет и не быть так как там уже 6 ядро во всю теституют и более новые драйвера
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 20:52
30 авг 2022, 19:55
vulkaninfo
andrey@MagicBookPro16:~$ lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c7)
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
03:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
03:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
03:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
03:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
03:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
andrey@MagicBookPro16:~$ vulkaninfo
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
VULKANINFO
Vulkan Instance Version: 1.3.204
Instance Extensions: count = 19
	VK_EXT_acquire_drm_display             : extension revision 1
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 10
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 2
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.3.211, layer version 1:
	Layer Extensions: count = 0
	Devices: count = 2
		GPU id = 0 (AMD RADV RENOIR)
		Layer-Device Extensions: count = 0
		GPU id = 1 (llvmpipe (LLVM 13.0.1, 256 bits))
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.3.211, layer version 1:
	Devices: count = 2
Presentable Surfaces:
GPU id : 0 (AMD RADV RENOIR):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_SRGB
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_UNORM
	Present Modes: count = 4
		PRESENT_MODE_IMMEDIATE_KHR
		PRESENT_MODE_MAILBOX_KHR
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount = 3
		maxImageCount = 0
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 2
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
			COMPOSITE_ALPHA_INHERIT_BIT_KHR
		supportedUsageFlags: count = 6
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
			IMAGE_USAGE_INPUT_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters:
			None
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
GPU id : 1 (llvmpipe (LLVM 13.0.1, 256 bits)):
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
		SurfaceFormat[1]:
		minImageCount = 3
		maxImageCount = 0
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
			None
Device Groups:
Group 0:
	Properties:
		physicalDevices: count = 1
			llvmpipe (LLVM 13.0.1, 256 bits) (ID: 0)
		subsetAllocation = 0
	Present Capabilities:
		llvmpipe (LLVM 13.0.1, 256 bits) (ID: 0):
			Can present images from the following devices: count = 1
		Present modes: count = 1
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Group 1:
	Properties:
			AMD RADV RENOIR (ID: 0)
		AMD RADV RENOIR (ID: 0):
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion        = 4206796 (1.3.204)
	driverVersion     = 92274693 (0x5800005)
	vendorID          = 0x1002
	deviceID          = 0x1636
	deviceType        = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
	deviceName        = AMD RADV RENOIR
	pipelineCacheUUID = e6cba45b-7c24-632d-e36c-97229d6e7dc8
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 16384
	maxImageDimension2D                             = 16384
	maxImageDimension3D                             = 2048
	maxImageDimensionCube                           = 16384
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 4294967295
	maxUniformBufferRange                           = 4294967295
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 256
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 65536
	bufferImageGranularity                          = 0x00000001
	sparseAddressSpaceSize                          = 0xfffffffc
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 8388606
	maxPerStageDescriptorUniformBuffers             = 8388606
	maxPerStageDescriptorStorageBuffers             = 8388606
	maxPerStageDescriptorSampledImages              = 8388606
	maxPerStageDescriptorStorageImages              = 8388606
	maxPerStageDescriptorInputAttachments           = 8388606
	maxPerStageResources                            = 8388606
	maxDescriptorSetSamplers                        = 8388606
	maxDescriptorSetUniformBuffers                  = 8388606
	maxDescriptorSetUniformBuffersDynamic           = 16
	maxDescriptorSetStorageBuffers                  = 8388606
	maxDescriptorSetStorageBuffersDynamic           = 8
	maxDescriptorSetSampledImages                   = 8388606
	maxDescriptorSetStorageImages                   = 8388606
	maxDescriptorSetInputAttachments                = 8388606
	maxVertexInputAttributes                        = 32
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 4294967295
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4096
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 127
	maxGeometryInputComponents                      = 64
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 256
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 8388606
	maxComputeSharedMemorySize                      = 65536
	maxComputeWorkGroupCount: count = 3
		65535
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		1024
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 16
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		16384
		16384
	viewportBoundsRange: count = 2
		-32768
		32767
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 4096
	minTexelBufferOffsetAlignment                   = 0x00000004
	minUniformBufferOffsetAlignment                 = 0x00000004
	minStorageBufferOffsetAlignment                 = 0x00000004
	minTexelOffset                                  = -32
	maxTexelOffset                                  = 31
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -2
	maxInterpolationOffset                          = 2
	subPixelInterpolationOffsetBits                 = 8
	maxFramebufferWidth                             = 16384
	maxFramebufferHeight                            = 16384
	maxFramebufferLayers                            = 1024
	framebufferColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferNoAttachmentsSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	storageImageSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 10
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		0
		8191.88
	lineWidthRange: count = 2
		0
		8191.88
	pointSizeGranularity                            = 0.125
	lineWidthGranularity                            = 0.125
	strictLines                                     = false
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000001
	optimalBufferCopyRowPitchAlignment              = 0x00000001
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = true
	residencyStandard2DMultisampleBlockShape = false
	residencyStandard3DBlockShape            = false
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
	primitiveOverestimationSize                 = 0
	maxExtraPrimitiveOverestimationSize         = 0
	extraPrimitiveOverestimationSizeGranularity = 0
	primitiveUnderestimation                    = false
	conservativePointAndLineRasterization       = false
	degenerateTrianglesRasterized               = true
	degenerateLinesRasterized                   = false
	fullyCoveredFragmentShaderInputVariable     = false
	conservativeRasterizationPostDepthCoverage  = false
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
	maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes: count = 4
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 3
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 67108863
	shaderUniformBufferArrayNonUniformIndexingNative     = false
	shaderSampledImageArrayNonUniformIndexingNative      = false
	shaderStorageBufferArrayNonUniformIndexingNative     = false
	shaderStorageImageArrayNonUniformIndexingNative      = false
	shaderInputAttachmentArrayNonUniformIndexingNative   = false
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = false
	maxPerStageDescriptorUpdateAfterBindSamplers         = 8388606
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 8388606
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 8388606
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 8388606
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 8388606
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 8388606
	maxPerStageUpdateAfterBindResources                  = 8388606
	maxDescriptorSetUpdateAfterBindSamplers              = 8388606
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 8388606
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 8388606
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindSampledImages         = 8388606
	maxDescriptorSetUpdateAfterBindStorageImages         = 8388606
	maxDescriptorSetUpdateAfterBindInputAttachments      = 8388606
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
	maxDiscardRectangles = 4
VkPhysicalDeviceDriverProperties:
	driverID           = DRIVER_ID_MESA_RADV
	driverName         = radv
	driverInfo         = Mesa 22.0.5
	conformanceVersion = 1.2.7.1
VkPhysicalDeviceDrmPropertiesEXT:
	hasPrimary   = true
	hasRender    = true
	primaryMajor = 226
	primaryMinor = 0
	renderMajor  = 226
	renderMinor  = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = true
	shaderDenormPreserveFloat32           = true
	shaderDenormPreserveFloat64           = true
	shaderDenormFlushToZeroFloat16        = true
	shaderDenormFlushToZeroFloat32        = true
	shaderDenormFlushToZeroFloat64        = true
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = true
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = 00000000-0300-0000-0000-000000000000
	driverUUID      = 414d442d-4d45-5341-2d44-525600000000
	deviceNodeMask  = 0
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockProperties:
	maxInlineUniformBlockSize                               = 4194304
	maxPerStageDescriptorInlineUniformBlocks                = 134217728
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 134217728
	maxDescriptorSetInlineUniformBlocks                     = 64
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 64
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 22369621
	maxMemoryAllocationSize = 0xfffffffc
VkPhysicalDeviceMaintenance4Properties:
	maxBufferSize = 0xfffffffc
VkPhysicalDeviceMultiDrawPropertiesEXT:
	maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 8
	maxMultiviewInstanceIndex = 2147483647
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 3
	pciDevice   = 0
	pciFunction = 0
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
	provokingVertexModePerPipeline                       = true
	transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000004
	robustUniformBufferAccessSizeAlignment = 0x00000004
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts: count = 3
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleLocationGridSize:
		width  = 2
		height = 2
	sampleLocationCoordinateRange: count = 2
		0
		0.9375
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = false
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = true
VkPhysicalDeviceShaderIntegerDotProductProperties:
	integerDotProduct8BitUnsignedAccelerated                                      = false
	integerDotProduct8BitSignedAccelerated                                        = false
	integerDotProduct8BitMixedSignednessAccelerated                               = false
	integerDotProduct4x8BitPackedUnsignedAccelerated                              = false
	integerDotProduct4x8BitPackedSignedAccelerated                                = false
	integerDotProduct4x8BitPackedMixedSignednessAccelerated                       = false
	integerDotProduct16BitUnsignedAccelerated                                     = false
	integerDotProduct16BitSignedAccelerated                                       = false
	integerDotProduct16BitMixedSignednessAccelerated                              = false
	integerDotProduct32BitUnsignedAccelerated                                     = false
	integerDotProduct32BitSignedAccelerated                                       = false
	integerDotProduct32BitMixedSignednessAccelerated                              = false
	integerDotProduct64BitUnsignedAccelerated                                     = false
	integerDotProduct64BitSignedAccelerated                                       = false
	integerDotProduct64BitMixedSignednessAccelerated                              = false
	integerDotProductAccumulatingSaturating8BitUnsignedAccelerated                = false
	integerDotProductAccumulatingSaturating8BitSignedAccelerated                  = false
	integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated         = false
	integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated        = false
	integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated          = false
	integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
	integerDotProductAccumulatingSaturating16BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating16BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated        = false
	integerDotProductAccumulatingSaturating32BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating32BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated        = false
	integerDotProductAccumulatingSaturating64BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating64BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated        = false
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 64
	supportedStages: count = 8
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
		SHADER_STAGE_ALL_GRAPHICS
		SHADER_STAGE_ALL
	supportedOperations: count = 8
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_ARITHMETIC_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_CLUSTERED_BIT
		SUBGROUP_FEATURE_QUAD_BIT
	quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlProperties:
	minSubgroupSize              = 64
	maxSubgroupSize              = 64
	maxComputeWorkgroupSubgroups = 4294967295
	requiredSubgroupSizeStages:
		None
VkPhysicalDeviceTexelBufferAlignmentProperties:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000004
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000004
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffff
	maxTransformFeedbackStreamDataSize         = 512
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 512
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = true
	transformFeedbackRasterizationStreamSelect = false
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 0
	subgroupSize                      = 64
	subgroupSupportedStages: count = 8
		SHADER_STAGE_ALL
	subgroupSupportedOperations: count = 8
	subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
	driverName                                           = radv
	framebufferIntegerColorSampleCounts: count = 1
		SAMPLE_COUNT_1_BIT
VkPhysicalDeviceVulkan13Properties:
		None
	maxInlineUniformTotalSize                                                     = 65535
Device Extensions: count = 133
	VK_AMD_buffer_marker                        : extension revision 1
	VK_AMD_device_coherent_memory               : extension revision 1
	VK_AMD_draw_indirect_count                  : extension revision 2
	VK_AMD_gcn_shader                           : extension revision 1
	VK_AMD_gpu_shader_half_float                : extension revision 2
	VK_AMD_gpu_shader_int16                     : extension revision 2
	VK_AMD_memory_overallocation_behavior       : extension revision 1
	VK_AMD_mixed_attachment_samples             : extension revision 1
	VK_AMD_shader_ballot                        : extension revision 1
	VK_AMD_shader_core_properties               : extension revision 2
	VK_AMD_shader_core_properties2              : extension revision 1
	VK_AMD_shader_explicit_vertex_parameter     : extension revision 1
	VK_AMD_shader_fragment_mask                 : extension revision 1
	VK_AMD_shader_image_load_store_lod          : extension revision 1
	VK_AMD_shader_info                          : extension revision 1
	VK_AMD_shader_trinary_minmax                : extension revision 1
	VK_AMD_texture_gather_bias_lod              : extension revision 1
	VK_EXT_4444_formats                         : extension revision 1
	VK_EXT_buffer_device_address                : extension revision 2
	VK_EXT_calibrated_timestamps                : extension revision 2
	VK_EXT_color_write_enable                   : extension revision 1
	VK_EXT_conditional_rendering                : extension revision 2
	VK_EXT_conservative_rasterization           : extension revision 1
	VK_EXT_custom_border_color                  : extension revision 12
	VK_EXT_depth_clip_enable                    : extension revision 1
	VK_EXT_depth_range_unrestricted             : extension revision 1
	VK_EXT_descriptor_indexing                  : extension revision 2
	VK_EXT_discard_rectangles                   : extension revision 1
	VK_EXT_display_control                      : extension revision 1
	VK_EXT_extended_dynamic_state               : extension revision 1
	VK_EXT_extended_dynamic_state2              : extension revision 1
	VK_EXT_external_memory_dma_buf              : extension revision 1
	VK_EXT_external_memory_host                 : extension revision 1
	VK_EXT_global_priority                      : extension revision 2
	VK_EXT_global_priority_query                : extension revision 1
	VK_EXT_host_query_reset                     : extension revision 1
	VK_EXT_image_drm_format_modifier            : extension revision 2
	VK_EXT_image_robustness                     : extension revision 1
	VK_EXT_image_view_min_lod                   : extension revision 1
	VK_EXT_index_type_uint8                     : extension revision 1
	VK_EXT_inline_uniform_block                 : extension revision 1
	VK_EXT_line_rasterization                   : extension revision 1
	VK_EXT_memory_budget                        : extension revision 1
	VK_EXT_memory_priority                      : extension revision 1
	VK_EXT_multi_draw                           : extension revision 1
	VK_EXT_pci_bus_info                         : extension revision 2
	VK_EXT_physical_device_drm                  : extension revision 1
	VK_EXT_pipeline_creation_cache_control      : extension revision 3
	VK_EXT_pipeline_creation_feedback           : extension revision 1
	VK_EXT_primitive_topology_list_restart      : extension revision 1
	VK_EXT_private_data                         : extension revision 1
	VK_EXT_provoking_vertex                     : extension revision 1
	VK_EXT_queue_family_foreign                 : extension revision 1
	VK_EXT_robustness2                          : extension revision 1
	VK_EXT_sample_locations                     : extension revision 1
	VK_EXT_sampler_filter_minmax                : extension revision 2
	VK_EXT_scalar_block_layout                  : extension revision 1
	VK_EXT_shader_atomic_float                  : extension revision 1
	VK_EXT_shader_atomic_float2                 : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation   : extension revision 1
	VK_EXT_shader_image_atomic_int64            : extension revision 1
	VK_EXT_shader_stencil_export                : extension revision 1
	VK_EXT_shader_subgroup_ballot               : extension revision 1
	VK_EXT_shader_subgroup_vote                 : extension revision 1
	VK_EXT_shader_viewport_index_layer          : extension revision 1
	VK_EXT_subgroup_size_control                : extension revision 2
	VK_EXT_texel_buffer_alignment               : extension revision 1
	VK_EXT_transform_feedback                   : extension revision 1
	VK_EXT_vertex_attribute_divisor             : extension revision 3
	VK_EXT_vertex_input_dynamic_state           : extension revision 2
	VK_EXT_ycbcr_image_arrays                   : extension revision 1
	VK_GOOGLE_decorate_string                   : extension revision 1
	VK_GOOGLE_hlsl_functionality1               : extension revision 1
	VK_GOOGLE_user_type                         : extension revision 1
	VK_KHR_16bit_storage                        : extension revision 1
	VK_KHR_8bit_storage                         : extension revision 1
	VK_KHR_bind_memory2                         : extension revision 1
	VK_KHR_buffer_device_address                : extension revision 1
	VK_KHR_copy_commands2                       : extension revision 1
	VK_KHR_create_renderpass2                   : extension revision 1
	VK_KHR_dedicated_allocation                 : extension revision 3
	VK_KHR_deferred_host_operations             : extension revision 4
	VK_KHR_depth_stencil_resolve                : extension revision 1
	VK_KHR_descriptor_update_template           : extension revision 1
	VK_KHR_device_group                         : extension revision 4
	VK_KHR_draw_indirect_count                  : extension revision 1
	VK_KHR_driver_properties                    : extension revision 1
	VK_KHR_dynamic_rendering                    : extension revision 1
	VK_KHR_external_fence                       : extension revision 1
	VK_KHR_external_fence_fd                    : extension revision 1
	VK_KHR_external_memory                      : extension revision 1
	VK_KHR_external_memory_fd                   : extension revision 1
	VK_KHR_external_semaphore                   : extension revision 1
	VK_KHR_external_semaphore_fd                : extension revision 1
	VK_KHR_format_feature_flags2                : extension revision 1
	VK_KHR_get_memory_requirements2             : extension revision 1
	VK_KHR_image_format_list                    : extension revision 1
	VK_KHR_imageless_framebuffer                : extension revision 1
	VK_KHR_incremental_present                  : extension revision 2
	VK_KHR_maintenance1                         : extension revision 2
	VK_KHR_maintenance2                         : extension revision 1
	VK_KHR_maintenance3                         : extension revision 1
	VK_KHR_maintenance4                         : extension revision 2
	VK_KHR_multiview                            : extension revision 1
	VK_KHR_pipeline_executable_properties       : extension revision 1
	VK_KHR_push_descriptor                      : extension revision 2
	VK_KHR_relaxed_block_layout                 : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge         : extension revision 3
	VK_KHR_sampler_ycbcr_conversion             : extension revision 14
	VK_KHR_separate_depth_stencil_layouts       : extension revision 1
	VK_KHR_shader_atomic_int64                  : extension revision 1
	VK_KHR_shader_clock                         : extension revision 1
	VK_KHR_shader_draw_parameters               : extension revision 1
	VK_KHR_shader_float16_int8                  : extension revision 1
	VK_KHR_shader_float_controls                : extension revision 4
	VK_KHR_shader_integer_dot_product           : extension revision 1
	VK_KHR_shader_non_semantic_info             : extension revision 1
	VK_KHR_shader_subgroup_extended_types       : extension revision 1
	VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
	VK_KHR_shader_terminate_invocation          : extension revision 1
	VK_KHR_spirv_1_4                            : extension revision 1
	VK_KHR_storage_buffer_storage_class         : extension revision 1
	VK_KHR_swapchain                            : extension revision 70
	VK_KHR_swapchain_mutable_format             : extension revision 1
	VK_KHR_synchronization2                     : extension revision 1
	VK_KHR_timeline_semaphore                   : extension revision 2
	VK_KHR_uniform_buffer_standard_layout       : extension revision 1
	VK_KHR_variable_pointers                    : extension revision 1
	VK_KHR_vulkan_memory_model                  : extension revision 3
	VK_KHR_workgroup_memory_explicit_layout     : extension revision 1
	VK_KHR_zero_initialize_workgroup_memory     : extension revision 1
	VK_NV_compute_shader_derivatives            : extension revision 1
	VK_VALVE_mutable_descriptor_type            : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 1
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		timestampValidBits          = 64
		present support             = true
		VkQueueFamilyGlobalPriorityPropertiesKHR:
			priorityCount  = 4
			priorities: count = 16
				128
				256
				512
				1024
				0
				0
				0
				0
				0
				0
				0
				0
				0
				0
				0
				0
	queueProperties[1]:
		queueCount                  = 4
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
			priorityCount  = 4
				128
				256
				512
				1024
				0
				0
				0
				0
				0
				0
				0
				0
				0
				0
				0
				0
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 2
	memoryHeaps[0]:
		size   = 1252696064 (0x4aaaa000) (1.17 GiB)
		budget = 1015214080 (0x3c82f000) (968.18 MiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags:
			None
	memoryHeaps[1]:
		size   = 2505400320 (0x95556000) (2.33 GiB)
		budget = 2030428160 (0x7905e000) (1.89 GiB)
		flags: count = 1
			MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 8
	memoryTypes[0]:
		heapIndex     = 1
		propertyFlags = 0x0001: count = 1
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
			IMAGE_TILING_OPTIMAL:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D16_UNORM_S8_UINT
				FORMAT_D32_SFLOAT_S8_UINT
			IMAGE_TILING_LINEAR:
				color images
	memoryTypes[1]:
		heapIndex     = 0
		propertyFlags = 0x0006: count = 2
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[2]:
		heapIndex     = 1
		propertyFlags = 0x0007: count = 3
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[3]:
		heapIndex     = 0
		propertyFlags = 0x000e: count = 3
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[4]:
		heapIndex     = 1
		propertyFlags = 0x00c1: count = 3
			MEMORY_PROPERTY_DEVICE_COHERENT_BIT_AMD
			MEMORY_PROPERTY_DEVICE_UNCACHED_BIT_AMD
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[5]:
		heapIndex     = 0
		propertyFlags = 0x00c6: count = 4
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[6]:
		heapIndex     = 1
		propertyFlags = 0x00c7: count = 5
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[7]:
		heapIndex     = 0
		propertyFlags = 0x00ce: count = 5
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = false
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = false
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = true
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = true
	sparseResidencyImage2D                  = true
	sparseResidencyImage3D                  = false
	sparseResidency2Samples                 = false
	sparseResidency4Samples                 = false
	sparseResidency8Samples                 = false
	sparseResidency16Samples                = false
	sparseResidencyAliased                  = true
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = true
	storageInputOutput16               = true
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = true
	bufferDeviceAddressMultiDevice   = false
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
	colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = false
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
	customBorderColors             = true
	customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceDynamicRenderingFeatures:
	dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
	extendedDynamicState2                   = true
	extendedDynamicState2LogicOp            = true
	extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesKHR:
	globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeatures:
	robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
	minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeatures:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = false
	bresenhamLines           = true
	smoothLines              = false
	stippledRectangularLines = false
	stippledBresenhamLines   = false
	stippledSmoothLines      = false
VkPhysicalDeviceMaintenance4Features:
	maintenance4 = true
VkPhysicalDeviceMemoryPriorityFeaturesEXT:
	memoryPriority = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
	multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeatures:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
	primitiveTopologyListRestart      = true
	primitiveTopologyPatchListRestart = false
VkPhysicalDevicePrivateDataFeatures:
	privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
	provokingVertexLast                       = true
	transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloat2FeaturesEXT:
	shaderBufferFloat16Atomics      = false
	shaderBufferFloat16AtomicAdd    = false
	shaderBufferFloat16AtomicMinMax = false
	shaderBufferFloat32AtomicMinMax = false
	shaderBufferFloat64AtomicMinMax = false
	shaderSharedFloat16Atomics      = false
	shaderSharedFloat16AtomicAdd    = false
	shaderSharedFloat16AtomicMinMax = false
	shaderSharedFloat32AtomicMinMax = true
	shaderSharedFloat64AtomicMinMax = true
	shaderImageFloat32AtomicMinMax  = false
	sparseImageFloat32AtomicMinMax  = false
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = false
	shaderBufferFloat64Atomics   = true
	shaderBufferFloat64AtomicAdd = false
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = true
	shaderSharedFloat64Atomics   = true
	shaderSharedFloat64AtomicAdd = false
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = false
	sparseImageFloat32Atomics    = true
	sparseImageFloat32AtomicAdd  = false
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeatures:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = true
	shaderInt8    = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
	shaderImageInt64Atomics = true
	sparseImageInt64Atomics = true
VkPhysicalDeviceShaderIntegerDotProductFeatures:
	shaderIntegerDotProduct = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
	shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeatures:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeatures:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceSynchronization2Features:
	synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTextureCompressionASTCHDRFeatures:
	textureCompressionASTC_HDR = false
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVertexInputDynamicStateFeaturesEXT:
	vertexInputDynamicState = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = true
	descriptorIndexing                                 = true
	samplerFilterMinmax                                = true
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = false
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkan13Features:
	privateData                                        = true
	shaderZeroInitializeWorkgroupMemory                = true
	maintenance4                                       = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
	workgroupMemoryExplicitLayout                  = true
	workgroupMemoryExplicitLayoutScalarBlockLayout = true
	workgroupMemoryExplicitLayout8BitAccess        = true
	workgroupMemoryExplicitLayout16BitAccess       = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeatures:
GPU1:
	apiVersion        = 4202700 (1.2.204)
	driverVersion     = 1 (0x0001)
	vendorID          = 0x10005
	deviceID          = 0x0000
	deviceType        = PHYSICAL_DEVICE_TYPE_CPU
	deviceName        = llvmpipe (LLVM 13.0.1, 256 bits)
	pipelineCacheUUID = 76616c2d-6c6c-206e-6f3d-270000000000
	maxImageDimension3D                             = 4096
	maxImageDimensionCube                           = 32768
	maxTexelBufferElements                          = 134217728
	maxUniformBufferRange                           = 65536
	maxStorageBufferRange                           = 134217728
	maxPushConstantsSize                            = 128
	maxSamplerAllocationCount                       = 32768
	bufferImageGranularity                          = 0x00000040
	sparseAddressSpaceSize                          = 0x00000000
	maxBoundDescriptorSets                          = 8
	maxPerStageDescriptorSamplers                   = 32
	maxPerStageDescriptorUniformBuffers             = 15
	maxPerStageDescriptorStorageBuffers             = 16
	maxPerStageDescriptorSampledImages              = 128
	maxPerStageDescriptorStorageImages              = 16
	maxPerStageResources                            = 128
	maxDescriptorSetSamplers                        = 32768
	maxDescriptorSetUniformBuffers                  = 256
	maxDescriptorSetUniformBuffersDynamic           = 256
	maxDescriptorSetStorageBuffers                  = 256
	maxDescriptorSetStorageBuffersDynamic           = 256
	maxDescriptorSetSampledImages                   = 256
	maxDescriptorSetStorageImages                   = 256
	maxDescriptorSetInputAttachments                = 256
	maxVertexInputAttributeOffset                   = 2047
	maxTessellationControlPerPatchOutputComponents  = 128
	maxGeometryShaderInvocations                    = 32
	maxGeometryOutputVertices                       = 1024
	maxFragmentDualSrcAttachments                   = 2
	maxFragmentCombinedOutputResources              = 40
	maxComputeSharedMemorySize                      = 32768
		65535
		65535
		65535
		1024
		1024
		1024
	mipmapPrecisionBits                             = 4
	maxViewports                                    = 16
		16384
		16384
		-32768
		32768
	viewportSubPixelBits                            = 0
	minMemoryMapAlignment                           = 64
	minTexelBufferOffsetAlignment                   = 0x00000010
	minUniformBufferOffsetAlignment                 = 0x00000010
	minStorageBufferOffsetAlignment                 = 0x00000010
	maxTexelOffset                                  = 31
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	framebufferDepthSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	framebufferStencilSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	framebufferNoAttachmentsSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageColorSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageIntegerSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageDepthSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageStencilSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	storageImageSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	timestampPeriod                                 = 1
		0
		255
	lineWidthGranularity                            = 0.0078125
	strictLines                                     = true
	optimalBufferCopyOffsetAlignment                = 0x00000080
	optimalBufferCopyRowPitchAlignment              = 0x00000080
	residencyStandard2DBlockShape            = false
	residencyNonResidentStrict               = false
	maxCustomBorderColorSamplers = 32768
	supportedDepthResolveModes: count = 2
	supportedStencilResolveModes: count = 1
	independentResolveNone = false
	independentResolve     = false
	maxPerStageDescriptorUpdateAfterBindSamplers         = 65536
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 65536
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 65536
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 65536
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 65536
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 65536
	maxPerStageUpdateAfterBindResources                  = 65536
	maxDescriptorSetUpdateAfterBindSamplers              = 65536
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 65536
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 65536
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindSampledImages         = 65536
	maxDescriptorSetUpdateAfterBindStorageImages         = 65536
	maxDescriptorSetUpdateAfterBindInputAttachments      = 65536
	driverID           = DRIVER_ID_MESA_LLVMPIPE
	driverName         = llvmpipe
	driverInfo         = Mesa 22.0.5 (LLVM 13.0.1)
	conformanceVersion = 0.0.0.0
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	shaderDenormPreserveFloat16           = false
	shaderDenormPreserveFloat32           = false
	shaderDenormPreserveFloat64           = false
	shaderDenormFlushToZeroFloat16        = false
	shaderDenormFlushToZeroFloat32        = false
	shaderDenormFlushToZeroFloat64        = false
	shaderRoundingModeRTZFloat16          = false
	shaderRoundingModeRTZFloat32          = false
	shaderRoundingModeRTZFloat64          = false
	deviceUUID      = 00000000-0000-0000-0000-000000000000
	driverUUID      = 00000000-0000-0000-0000-000000000000
	deviceNodeMask  = 0
	lineSubPixelPrecisionBits = 8
	maxPerSetDescriptors    = 1024
	maxMemoryAllocationSize = 0x80000000
	maxMultiviewViewCount     = 6
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 20:54
продолжение
	subgroupSize              = 8
	supportedStages: count = 4
		SHADER_STAGE_ALL
	supportedOperations: count = 4
	quadOperationsInAllStages = false
	transformFeedbackStreamsLinesTriangles     = false
	deviceNodeMask                    = 0
	subgroupSize                      = 8
	subgroupSupportedStages: count = 4
		SHADER_STAGE_ALL
	subgroupSupportedOperations: count = 4
	subgroupQuadOperationsInAllStages = false
		SAMPLE_COUNT_1_BIT
Device Extensions: count = 67
	VK_EXT_post_depth_coverage             : extension revision 1
	VK_EXT_separate_stencil_usage          : extension revision 1
	queueProperties[0]:
		queueCount                  = 1
memoryHeaps: count = 1
	memoryHeaps[0]:
		size   = 2147483648 (0x80000000) (2.00 GiB)
		flags: count = 1
memoryTypes: count = 1
	memoryTypes[0]:
		heapIndex     = 0
		propertyFlags = 0x000f: count = 4
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_X8_D24_UNORM_PACK32
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D24_UNORM_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	dualSrcBlend                            = true
	logicOp                                 = true
	depthClamp                              = true
	depthBounds                             = false
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = true
	shaderStorageImageReadWithoutFormat     = false
	shaderSampledImageArrayDynamicIndexing  = false
	shaderStorageImageArrayDynamicIndexing  = false
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = false
	shaderResourceMinLod                    = false
	sparseBinding                           = false
	sparseResidencyBuffer                   = false
	sparseResidencyImage2D                  = false
	sparseResidencyAliased                  = false
	variableMultisampleRate                 = false
	inheritedQueries                        = false
	storageInputOutput16               = false
	bufferDeviceAddressCaptureReplay = false
	shaderInputAttachmentArrayDynamicIndexing          = false
	shaderUniformTexelBufferArrayDynamicIndexing       = false
	shaderStorageTexelBufferArrayDynamicIndexing       = false
	shaderUniformBufferArrayNonUniformIndexing         = false
	shaderSampledImageArrayNonUniformIndexing          = false
	shaderStorageBufferArrayNonUniformIndexing         = false
	shaderStorageImageArrayNonUniformIndexing          = false
	shaderInputAttachmentArrayNonUniformIndexing       = false
	shaderUniformTexelBufferArrayNonUniformIndexing    = false
	shaderStorageTexelBufferArrayNonUniformIndexing    = false
	descriptorBindingUniformBufferUpdateAfterBind      = false
	descriptorBindingSampledImageUpdateAfterBind       = false
	descriptorBindingStorageImageUpdateAfterBind       = false
	descriptorBindingStorageBufferUpdateAfterBind      = false
	descriptorBindingUniformTexelBufferUpdateAfterBind = false
	descriptorBindingStorageTexelBufferUpdateAfterBind = false
	descriptorBindingUpdateUnusedWhilePending          = false
	descriptorBindingPartiallyBound                    = false
	descriptorBindingVariableDescriptorCount           = false
	runtimeDescriptorArray                             = false
VkPhysicalDeviceDynamicRenderingFeaturesKHR:
	extendedDynamicState2PatchControlPoints = true
	rectangularLines         = true
	smoothLines              = true
	stippledRectangularLines = true
	stippledBresenhamLines   = true
	stippledSmoothLines      = true
	multiDraw = true
	multiview                   = true
	primitiveTopologyPatchListRestart = true
VkPhysicalDevicePrivateDataFeaturesEXT:
	privateData = true
	samplerYcbcrConversion = false
	shaderInt8    = true
	variablePointers              = false
	vertexAttributeInstanceRateZeroDivisor = false
	multiview                          = true
	shaderInt8                                         = true
	descriptorIndexing                                 = false
	vulkanMemoryModel                                  = false
	vulkanMemoryModelDeviceScope                       = false
основное что заметил -
ВНИМАНИЕ: lavapipe не является совместимой реализацией vulkan, используется только для тестирования.
MrTowelie
Решено: 8
Сообщение MrTowelie » 30 авг 2022, 21:05
liudvig_larson писал(а):
30 авг 2022, 20:54
У меня пишет такое же предупреждение при выводе команды в файл.
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
Сообщение Белый Кролик » 30 авг 2022, 21:25
30 авг 2022, 20:33
ставил разные дрова
Вместо установки разных дров надо было обновить ядро и установить Вулкан
sudo apt install libvulkan1 mesa-vulkan-drivers vulkan-utils
. Вертай все взад и давай по новой.
MrTowelie
Решено: 8
Сообщение MrTowelie » 30 авг 2022, 21:27
Запихал в сравнение текстов ваш вывод и свой, из различий (напомню, у меня дискретная карта):
У меня есть раздел "VkPhysicalDeviceFragmentShadingRatePropertiesKHR:", у вас его нет, но есть раздел "VkPhysicalDeviceSampleLocationsPropertiesEXT:".
В разделе "VkPhysicalDeviceShaderIntegerDotProductProperties:" у вас всё false, у меня примерно половина true.
В разделе "VkPhysicalDeviceVulkan13Properties:" у вас так же почти всё false, у меня где-то треть true.
У вас нет раздела "VkPhysicalDeviceFragmentShadingRateFeaturesKHR:".
В разделе "VkPhysicalDeviceShaderAtomicFloat2FeaturesEXT:" у вас так же всё false, у меня треть true.
Больше существенный отличий, явно не связанных с разными моделями видеоускорителей, я не вижу при сравнении текстов. Но и это всё, имхо, не особо что-то даёт, кроме того, что, у вас, скорее всего, что-то не работает, что вам и так очевидно.
liudvig_larson
Problem: Linux Mint 21 Cinnamon 64 bit - Vulkan doesn't work. AMD APU Radeon RX Vega 6 (Integrated AMD Ryzen™ 5 4600H)
Сообщение liudvig_larson » 30 авг 2022, 21:32
MrTowelie писал(а):
30 авг 2022, 21:27
:joke: :blush: вот думаю - прордолжать экзуенции или забить и сидеть без вулкана
Сообщение rogoznik » 30 авг 2022, 21:34
liudvig_larson, так он должен работать. Где-то ты ошибся. Вон у кролика на встройке работает вулкан(единственное отличие от тебя у него десктопный проц (атлон))
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 21:36
Белый Кролик писал(а):
30 авг 2022, 21:25
30 авг 2022, 20:33
ставил разные дрова
:blush: ладно друже - сейчас принципиально установлю по новой и обновлю без установки дров с кодом sudo apt install libvulkan1 mesa-vulkan-drivers vulkan-utils
Белый Кролик
Решено: 10
Сообщение Белый Кролик » 30 авг 2022, 21:37
30 авг 2022, 21:36
Давай, удачи тебе. :thumbs: :vic:
MrTowelie
Решено: 8
Сообщение MrTowelie » 30 авг 2022, 21:37
У вас команда vkcube картинку даёт? Вроде как при ней должен крутиться кубик, который рендерится на vulkan.
MrTowelie
Решено: 8
Сообщение MrTowelie » 30 авг 2022, 21:47
30 авг 2022, 21:25
Кстати, делаю ставку, что vulkan-utils не найдёт в репозитории. У меня вот почему-то стоит vulkan-tools вместо него, но не помню почему (но у меня Kubuntu 22.04). Ещё помню, что для libvulkan1 и mesa-vulkan-drivers нужны ещё 32-ух битные либы, потому что d9vk работает только на них, но не знаю, как оно обстоит после слияния d9vk и DXVK, но это всё для игр.
liudvig_larson
Сообщение liudvig_larson » 30 авг 2022, 21:52
MrTowelie писал(а):
30 авг 2022, 21:37
дает и крутится
MrTowelie
Решено: 8
Сообщение MrTowelie » 30 авг 2022, 21:53
30 авг 2022, 21:52
дает и крутится
Тогда на основе чего вы делаете вывод, что vulkan у вас не работает? Вы как его тестировали? Пробовали скачать приложение или игру в которой есть опция рендера на vulkan и проверить их работу с ней и без неё?
Вернуться в «Видеокарты»
