Не запускается Virtualbox
volp
Благодарил (а): 30 раз
14 авг 2022, 20:39
Kernel: 5.13.0-30-generic x86_64 bits: 64 compiler: N/A
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop Mobo: KLLISRE model: X79 v: V1.2 serial: <filter>
UEFI: American Megatrends v: 4.6.5 date: 11/15/2021
Topology: 8-Core model: Intel Xeon E5-2650L 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 20.0 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57599
Speed: 1245 MHz min/max: 1200/2300 MHz Core speeds (MHz): 1: 1237 2: 1429
3: 1219 4: 1288 5: 1241 6: 1283 7: 1250 8: 1223 9: 1302 10: 1234 11: 1200
12: 1295 13: 1251 14: 1243 15: 1266 16: 1231
Device-1: AMD RV730 XT [Radeon HD 4670] vendor: Micro-Star MSI
driver: radeon v: kernel bus ID: 03:00.0
Display: x11 server: X.Org 1.20.13 driver: ati,radeon
unloaded: fbdev,modesetting,vesa tty: N/A
OpenGL: renderer: AMD RV730 (DRM 2.50.0 / 5.13.0-30-generic LLVM 12.0.0)
v: 3.3 Mesa 21.2.6 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio
Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 03:00.1
Sound Server: ALSA v: k5.13.0-30-generic
driver: r8169 v: kernel port: d000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr0-nic state: down mac: <filter>
Local Storage: total: 816.03 GiB used: 403.27 GiB (49.4%)
ID-1: /dev/nvme0n1 model: KLLISRE 256GB size: 238.47 GiB
ID-2: /dev/sda vendor: Western Digital model: WD5000AAKX-001CA0
ID-3: /dev/sdb model: KSQ120 size: 111.79 GiB
ID-1: / size: 51.04 GiB used: 23.54 GiB (46.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 182.34 GiB used: 26.84 GiB (14.7%) fs: ext4
dev: /dev/nvme0n1p3
System Temperatures: cpu: 127.5 C mobo: N/A gpu: radeon temp: 62 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1510 fan-3: 0 fan-4: 0 fan-5: 0
Voltages: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.30
Processes: 379 Uptime: 7h 36m Memory: 15.56 GiB used: 2.75 GiB (17.7%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Не могу запустить виртуальную машину , даже пустую, без образов накопителей и дисков.
Текст ошибки
The virtual machine '1' has terminated unexpectedly during startup with exit code 1 (0x1).
Код ошибки:
NS_ERROR_FAILURE (0x80004005)
Компонент:
MachineWrap
Интерфейс:
IMachine {85632c68-b5bb-4316-a900-5eb28d3413df}
Мои группы
volp adm tty disk uucp dialout cdrom sudo audio dip plugdev lpadmin netdev scanner sambashare vboxusers libvirt
В сети все советы по этой ошибке или касаются Windows или принадлежности к vboxusers . Как бы не мой случай. Через sudo virtualbox та же ошибка. По поводу несовместимого железа - с другого SSD диска на этом компе, на котором установлена LM19.3 Mate 64, Vbox запускается . Прошу общество помощи разобраться в этой проблеме.
Решение Сотрудник » 17 авг 2022, 11:12
Какие права доступа установлены для папки "/usr"? root не может получить доступ к папке.
У меня:
ls -ld /usr
drwxr-xr-x 13 root root 148 мая 22 22:03 /usr
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
14 авг 2022, 23:06
Откуда ставили Virtualbox? Официальные репы, РРА или что-то ещё?
Один из возможных вариантов: отсутствует подходящий модуль ядра, это у меня часто возникало, если ставить виртуалбокс из РРА.
Ещё вот пишут, что можно обновить версии расширений: https://askubuntu.com/questions/1311800 ... u-20-04lts
Сотрудник
15 авг 2022, 08:40
volp, Попробуйте скачать и установить с официального сайта VirtualBox
*.deb файл для версии Ubuntu 20.04, попробовать версии Ubuntu 19.10 / 20.10 / 21.04, какой то из этих файлов должен установить VirtualBox.
15 авг 2022, 11:02
volp, Еще проверьте - включена ли аппаратная виртуализация в bios/uefi.
Damian
Благодарил (а): 24 раза
15 авг 2022, 17:53
Памяти хватает? Виртуальной машине памяти необходимо не менее 4Гб по моему.
Решено: 37
15 авг 2022, 17:57
volp писал(а):
14 авг 2022, 20:39
ну так проверь пути к виртуальной машине, может какой диск отвалился..
15 авг 2022, 19:00
Damian писал(а):
15 авг 2022, 17:53
Бред. Виртуальной машине нужно столько памяти, сколько выделено гостю, плюс совсем немного на сам гипервизор. Там не то что 4ГБ, там и одного не нужно. Для vbox точно не скажу, а qemu-kvm в пару-тройку сотен метров укладывается, причем с обвязкой.
Про память была другая история - когда-то для vmware было требование - наличие swap не менее чем размер памяти выделенный гостю. Но сейчас уже не обязательно.
Damian
16 авг 2022, 10:51
15 авг 2022, 19:00
вот это или нет точно не помню,но оф.сайте в качестве требований значилось 4Gb,у меня не получилось виндоуз запустить,грешил на то что всего 3 у меня есть.
16 авг 2022, 13:12
Damian писал(а):
16 авг 2022, 10:51
Как будто не знаете, что официальные требования - это "средняя температура по больнице"? Имея 4Gb у хоста, без дополнительных специальных действий, практически гарантированно, хватит памяти на гостей с 2Gb - а это типичные официальные требования для многих систем. Ну, вот и вписали.
А по факту - все зависит от того, что выделяется гостю.
16 авг 2022, 13:54
Damian, чтоб не гадать
https://www.virtualbox.org/wiki/End-user_documentation
Depending on what guest operating systems you want to run, you will need at least 512 MB of RAM (but probably more, and the more the better). Basically, you will need whatever your host operating system needs to run comfortably, plus the amount that the guest operating system needs. So, if you want to run Windows 8.1 on Windows 7, you probably won't enjoy the experience much with less than 2 GB of RAM. Check the minimum RAM requirements of the guest operating system, they often will refuse to install if it is given less. Sometimes it malfunctions instead. So you'll need that for the guest alone, plus the memory your operating system normally needs.
Damian
16 авг 2022, 16:51
Всё это правильно,надо чтоб и основной хватило системе и гостевую не обделить,но я VirtualBox и не пробовал, на VMware-Player пробовал Win7 запустить там не получилось хотя система установилась а может и не до конца,я так и не понял.
volp
16 авг 2022, 22:44
Ара Магеддон писал(а):
14 авг 2022, 23:06
С оф. сайта , при попытке установить ext pack получаю ошибку
Не удалось установить плагин /home/volp/Загрузки/Oracle_VM_VirtualBox_Extension_Pack-6.1.36a-152435.vbox-extpack.  The installer failed with exit code 1: VBoxExtPackHelperApp: error: The owner is not root: '/usr'.
Естественно запускаю с sudo.
volp
16 авг 2022, 22:45
15 авг 2022, 11:02
Включена . с другого носителя LM19.3 все работает , разница только в том. что LM20 запускается с nvme gpt, а LM19 - ssd mbr
Последний раз редактировалось пользователем 1 volp; всего редактировалось раз: 16
volp
16 авг 2022, 22:46
15 авг 2022, 17:57
Виртуальная машина не запускается в принципе, без подключения всяких носителей.
volp
16 авг 2022, 22:53
14 авг 2022, 23:06
lsmod
Module Size Used by
binfmt_misc 24576 1
xt_CHECKSUM 16384 1
xt_MASQUERADE 20480 3
vboxnetadp 28672 0
vboxnetflt 28672 0
ip6table_mangle 16384 1
ip6table_nat 16384 1
iptable_mangle 16384 1
iptable_nat 16384 1
nf_nat 49152 3 ip6table_nat,iptable_nat,xt_MASQUERADE
nf_tables 212992 0
nfnetlink 20480 1 nf_tables
bridge 266240 0
stp 16384 1 bridge
llc 16384 2 bridge,stp
vboxdrv 524288 2 vboxnetadp,vboxnetflt
snd_hda_codec_realtek 143360 1
snd_hda_codec_generic 81920 1 snd_hda_codec_realtek
ledtrig_audio 16384 1 snd_hda_codec_generic
snd_hda_codec_hdmi 61440 1
snd_hda_intel 53248 3
snd_intel_dspcfg 28672 1 snd_hda_intel
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
snd_hda_codec 147456 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core 94208 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
intel_rapl_msr 20480 0
snd_hwdep 16384 1 snd_hda_codec
intel_rapl_common 24576 1 intel_rapl_msr
snd_pcm 114688 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
sb_edac 32768 0
x86_pkg_temp_thermal 20480 0
nls_iso8859_1 16384 1
intel_powerclamp 20480 0
snd_seq_midi 20480 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 36864 1 snd_seq_midi
input_leds 16384 0
joydev 28672 0
kvm_intel 303104 0
snd_seq 73728 2 snd_seq_midi,snd_seq_midi_event
hid_a4tech 16384 0
kvm 864256 1 kvm_intel
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
snd_timer 40960 2 snd_seq,snd_pcm
rapl 20480 0
snd 94208 17 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
efi_pstore 16384 0
intel_cstate 20480 0
soundcore 16384 1 snd
sch_fq_codel 20480 3
nct6775 69632 0
hwmon_vid 16384 1 nct6775
coretemp 20480 0
ipmi_devintf 20480 0
mac_hid 16384 0
ipmi_msghandler 114688 1 ipmi_devintf
msr 16384 0
ip6t_REJECT 16384 1
nf_reject_ipv6 20480 1 ip6t_REJECT
xt_hl 16384 22
ip6t_rt 20480 3
ipt_REJECT 16384 3
nf_reject_ipv4 16384 1 ipt_REJECT
xt_LOG 20480 10
nf_log_syslog 20480 10
xt_multiport 20480 4
xt_limit 16384 13
xt_addrtype 16384 4
xt_tcpudp 20480 35
xt_conntrack 16384 17
nf_conntrack 147456 3 xt_conntrack,nf_nat,xt_MASQUERADE
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
ip6table_filter 16384 1
ip6_tables 32768 55 ip6table_filter,ip6table_nat,ip6table_mangle
parport_pc 45056 1
iptable_filter 16384 1
ppdev 24576 0
bpfilter 16384 0
lp 20480 0
parport 65536 3 parport_pc,lp,ppdev
ip_tables 32768 11 iptable_filter,iptable_nat,iptable_mangle
x_tables 49152 20 ip6table_filter,xt_conntrack,iptable_filter,ip6table_nat,xt_LOG,xt_multiport,xt_tcpudp,xt_addrtype,xt_CHECKSUM,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,iptable_nat,xt_limit,xt_hl,ip6table_mangle,xt_MASQUERADE,ip6t_REJECT,iptable_mangle
autofs4 45056 2
btrfs 1388544 0
blake2b_generic 20480 0
xor 24576 1 btrfs
zstd_compress 176128 1 btrfs
raid6_pq 114688 1 btrfs
libcrc32c 16384 4 nf_conntrack,nf_nat,btrfs,nf_tables
dm_mirror 24576 0
dm_region_hash 24576 1 dm_mirror
dm_log 20480 2 dm_region_hash,dm_mirror
hid_generic 16384 0
usbhid 57344 0
hid 139264 3 hid_a4tech,usbhid,hid_generic
radeon 1486848 22
i2c_algo_bit 16384 1 radeon
drm_ttm_helper 16384 1 radeon
ttm 69632 2 radeon,drm_ttm_helper
drm_kms_helper 253952 1 radeon
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
crct10dif_pclmul 16384 1
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
crc32_pclmul 16384 0
cec 53248 1 drm_kms_helper
ghash_clmulni_intel 16384 0
rc_core 61440 1 cec
aesni_intel 376832 0
nvme 49152 3
r8169 77824 0
ahci 40960 2
i2c_i801 36864 0
xhci_pci 24576 0
crypto_simd 16384 1 aesni_intel
cryptd 24576 2 crypto_simd,ghash_clmulni_intel
drm 557056 16 drm_kms_helper,radeon,drm_ttm_helper,ttm
libahci 36864 1 ahci
lpc_ich 24576 0
i2c_smbus 20480 1 i2c_i801
realtek 32768 1
xhci_pci_renesas 20480 1 xhci_pci
nvme_core 126976 4 nvme
wmi 32768 0
Вроде все есть
Решено: 37
16 авг 2022, 23:03
volp писал(а):
16 авг 2022, 22:44
снеси всё нафик и нормально поставь и запусти от пользователя, а не рута... потом добавь нормально вирт машину...
volp
16 авг 2022, 23:17
16 авг 2022, 23:03
Как полностью вычистить все следы и конфиги , потому как уже неоднократно удалял и ставил разные версии.
Сотрудник
17 авг 2022, 10:04
volp писал(а):
16 авг 2022, 23:17
Удаление программы и компонентов
sudo apt purge virtualbox*
В домашней папке пользователя надо посмотреть папки: .config, .local/share, .cache (скрытые папки, включить отображение в файловом менеджере) и удалить папки virtualbox (если остались).
Как вариант установки Virtualbox, установить программу и компоненты из менеджера программ.
yarichin
17 авг 2022, 10:09
volp писал(а):
16 авг 2022, 22:44
Ваше sudo до одного места (ИМХО) . Там английским по белому (или чёрному) написано - root не является владельцем пакета. Так что сначала sudo chown .
Anonim19992
Благодарил (а): 18 раз
17 авг 2022, 10:16
Kernel: 5.13.0-30-generic x86_64 bits - у вас кастомное ядро?
